Help broken down on hwy right now
Discussion in 'Gen 2 Prius Main Forum' started by cvincent, Oct 28, 2012.
  1. cvincent
    cvincent Junior Member
    76
    arizona
    I am about 50 miles from El Paso and 350-400 from home, all the dash lights lit up and my scan gauge says p0a93 the inverter pump thing
    Nothing has been worked on or messed with so i should have no air in the lines etc
    Can I drive it like this to El Paso or home? Car seems to be running fine
    Car is under toyo warranty so i don't want to screw anything else up
    Should I just get towed in or what?
    Any help is great, thank you
  2. Patrick Wong
    18,210
    6,514
    Apparently your inverter coolant pump has failed. You can confirm this by looking for fluid turbulence in the coolant reservoir when the Prius is READY. Lack of turbulence means no pump action.
    If you continue to drive the car you run some risk of permanently damaging the inverter. Obviously, towing the car is your best solution.
    However if you are concerned about the cost of a tow and the ambient temperature in your area is very cool right now, you might try stopping at a store and buying a bag of ice. Place that on top of the inverter cover, with hopes that the ice and water dripping out of the bag will help to keep the inverter assembly cool. You might try returning to El Paso so that you can find a Toyota dealer there; but I would not suggest you attempt to drive 350 miles without proper inverter cooling.
  3. cvincent
    76
    arizona
    Hey Patrick, thank you
    I will stop the car and see if I have bubbles, where is this inverter coolant, is it the red coolant container across from the brake fluid reservoir? I also used the scan gauge to clear the code And have driven 10-15 miles and the code is not coming back on?????
    I was running 85-90 mph when the code came on and am now staying at 75
    I have no doubt it is going out i have been hearing a louder noise from the car for a while and thought it was the pump
    It is possible for it to work off and on when it is failing?
    Ok I just checked and no bubbles in that red fluid, temp here is 57
    This is an 08 with 102,000 miles
  4. Patrick Wong
    18,210
    6,514
    The inverter coolant reservoir is mounted on the side of the inverter, in the space between the engine and the inverter. If you see no turbulence in the fluid when the Prius is READY, then the inverter coolant pump is not running.
    I suggest you keep your speed down, and keep the AC compressor off if you can, to reduce the electrical load on the inverter.
  5. cvincent
    76
    arizona
    So
    Do you think as long as the code is not coming back on I am ok to make it to Tucson, I would really rather have precesion work on my car than any other dealership
    If the pump is not working i wonder why the code did not come back on? Does it wait until it gets hot
    Thanks so much for your help
  6. Patrick Wong
    18,210
    6,514
    The Prius diagnostic system has no idea whether the pump is running. It only knows when the inverter overheats. Therefore the DTC is not going to be logged until the inverter overheats again.
    I agree that Precision Toyota in Tucson is a good place to entrust service of your Prius; however you are taking a substantial risk by trying to drive across southern Arizona via I-10 in relatively warm weather.
    Andyprius # 1 likes this.
  7. cvincent
    76
    arizona
    Hey Patrick, thanks for that info, amazing the car does not know if the pump is running, I was just on my way out of El Paso, maybe i should turn around
    Could you read the other post i just put on here about the mig numbers i am running, if I can watch those should i be ok?
    Thank you so much for your help
  8. Patrick Wong
    18,210
    6,514
    I really think you should try an ice bag on your inverter and check/replace it periodically, if you are intent on making the drive to Tucson today. And, be ready for the possibility that you may be stuck on the side of I-10, somewhere in the middle of the desert.
    I do not know whether the temp numbers you are retrieving can be relied upon. I am more concerned about the inverter overheating, than the transaxle overheating. However if either overheats and fails, you will be looking at a healthy four-digit repair bill.
  9. cvincent
    76
    arizona
    Ok, I am headed back to El Paso, will put it in the dealer here, thank you for all your help, I will let you know what they figure out
