Help buying a 2010 gen 3 tomorrow. Bad idea?
Discussion in 'Gen 3 Prius Main Forum' started by JCBen, Dec 6, 2023.
  1. JCBen
    JCBen New Member
    Massachusetts
    Tomorrow I'm looking at a 2010 Prius and I've been reading all about the warnings for gen 3s and 2010 specifically. I'd LOVE help from folks as I have a small window to buy a car and it's so daunting and I don't want to end up paying lots of money down the road or only having this car last a few years before it's too expensive to maintain.
    The article on Vehicle History for this year is one of the things that worries me the most. It has the headline "2010 Toyota Prius Review: An Unreliable Year To Avoid For The Popular Hybrid Car" and "The 2010 Prius only lasts around 150,000 miles with a lot of engine problems. At $7,494 – 12,430, it’s too much money when you may need to spend thousands to keep it running."
    - That seems like so few miles for a Prius! Is that true? Then I read forums of lots of 2010 owners that haven't had issues, especially if they keep up with oil changes, so I'm just not sure how worried to be.
    - The car I'm looking at has 92,000 miles on it, has had regular oil changes, and she said there hasn't been an issue at all with burning oil. Is it reasonable to think that if I keep up with oil changes every 5k that I could be in the clear for some of the main issues? Is the EGR system something I can be vigilant about getting cleaned and then that may not lead to the head gasket issue (not sure I'm understanding it right)? She's asking $9000.
    - I will be taking it to a mechanic to get checked before buying it. Are there things I can ask them to check specifically to see if I should expect issues? Any things that I should ask the owner about that she might not realize are signs of trouble?
    - Also, should I be expecting some kind of issue with the hybrid battery soon if it's only at 92,000?
    I'm also looking at a 2008 with 167,000 with a new 12v battery, new brakes, and they're asking $5,400. And a 2009 with 150k for $6500 with a new ABS system and "upgraded battery". I'm not sure if a gen 2 might be a safer bet even if they're a lot more miles but I'm not sure I trust the sellers as much.
    THANK YOU in advance SO SO much for your help on any of these questions. I'm very appreciative!
  2. JC91006
    16,936
    8,647
    run a carfax to verify the mileage. too good to be true
  3. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    A Gen 3 may be a good buy if you're willing to fix the common issues by yourself (lots of help here, and documentation is extensive) or if you have deep pockets. That being said, $9000 is a lot for a 2010.
    JCBen likes this.
  4. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hi Ben
    There is alas simply no way that buying a vehicle out of full warranty is not a gamble. You have to mentally accept that. A trusted seller is your best bet. For reliability buy 2 used cars. Nothing you can do with a used vehicle can ensure long inexpensive life. This is simply reality. And car prices are still ridiculously high.
    I'd buy the 2010 if it drives without issues, and if a knowledgable person with techstream shows it has no fault codes. Prius is a very very complex car. If you're unwilling to gamble for the sake of saving a few dollars on gas, buy a regular car. They are less complex and any mechanic can work on them, or you can replace them cheaper when they fail.
    JCBen likes this.
  5. bisco
    52,837
    Welcome!
    How much do you have set aside for repairs?
    Do you have to buy a hybrid?
    It sounds like a nice car but 14 year old cars are always potential problems and hybrids even more so due to the expensive complicated systems
    JCBen likes this.
  6. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    Under no circumstances or any conditions by the generation 3 It will be a great disappointment and cost can go through the roof if you're not careful and you become attached to it like you do your pet It happens to people avoid this at all cost You can probably do better on a generate You will do better on a generation too than the price is you're mentioning above but I'm assuming those are very clean cars and you have a certain standard you're needing to meet if you're going to buy something that old I kind of sort of understand your pain. The generation 2 will serve you 1000 times better than any generation 3 or a pair of generation 3s forget it I have a pair of generation 3 sitting right here just forget it save your hard-earned money if that's what it is. I just bought two generation twos one with nav both with leather both undented one with faded paint both running etc I paid $700 a piece for them separately but like 2 months apart the one I rebuilt the hybrid battery in which is something I don't very often do and the other one needed a break actuator which I still haven't installed yet. My 09 work vehicle is flawless but it is a work vehicle and it looks it The other two I just bought are extremely clean look ridiculous considering they're almost 20 years old they're very clean most people would be proud to drive them anywhere they're nice looking cars except the kid but I'm not getting my cars for kids. I give the kids something like a Yaris they have no use for the Prius The lights and warnings will take them down quickly.
    JCBen likes this.
  7. Leadfoot J. McCoalroller
    8,286
    7,795
    Pennsylvania
    2018 Prius c
    I hate to say it, but I think that's exactly what you're headed for.
    These cars are built to last about 15 years. A few make it to 20.
    If you need to buy a 2010 or earlier car to save money, I'd suggest getting the simplest, cheapest-to-fix thing you can find. It was also built to last about 15 years, and it should also be expected to have problems approaching that age.
    The difference is that with a simple Corolla/Impreza/Elantra etc. you'd have the flexibility of hiring any mechanic in town, including the cheapest ones.
    You don't get that with a Prius.
    Remember: the way a Prius saves you money is by not needing as much gasoline while you pour on the miles. If that's not how you plan to use the car, it won't do much to save you money.
    JCBen likes this.
  8. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Hybrid battery's lifetime is more by age than mileage so at about 14-15 years old now, could become a problem too. I'd be more likely to get the 08 or 09 than the 2010.
    JCBen likes this.
  9. Mendel Leisk
    42,332
    Yes. If you get it be prepared to clean the EGR, including intake manifold, soon. If you can DIY you’ll be fine. Pros who do this, properly and completely, without resorting to wholesale parts replacement ($) are scarce.
    my 2 cents: carbon-clogged EGR is the reason gen 3’s are blowing head gaskets. Cleaning every 50k would be optimum. Delaying first cleaning to 100k is a little less onerous, but…
    see top two links in my signature. On a phone turn it landscape to see signature.
    #9 Mendel Leisk, Dec 7, 2023
  10. JCBen
    JCBen New Member
    Massachusetts
    I don’t need a hybrid but I’d like to save on gas and also lower environmental impact of driving. I’ve had a Honda Fit for years and have loved it, it’s served me well, but it’s finally rusted out and I thought it would be good to go for a Prius for gas mileage and also a little more space.
    And I don’t have much set aside for repairs. Or basically I guess I’m trying decide if it’s worth it to get a hybrid for the gas and environmental impact or go with a Honda Fit again.
    Thanks for your help!
    Thank you so much! I haven’t ever worked on cars and I don’t feel confident in it but it’s something I could try. Is the DIY part of this something you need skill and knowledge for or can a novice do it?
    Thanks so much for your help
    Definitely don’t have deep pockets! And I don’t have experience or confidence working in cars but am up for learning some dig things if they’re fairly straightforward.
    #10 JCBen, Dec 7, 2023
  11. bisco
    52,837
    i'd go with the fit. saving the world is for those who can afford it, it's not cheap
    JCBen and JohnPrius3005 like this.
  12. bisco
    52,837
    merv is very entertaining! and there are tons of how to videos online:
    watch
    JCBen likes this.
  13. rjparker
    rjparker Tu Humilde Sirviente
    11,083
    6,943
    Texas Hill Country
    You may well be spending $10k in repairs over the next few years with a 2010 Prius. Just being without a car a few times is bad enough. The new car buyer back in 2010 got 13 years of benefits with low maintenance and gas savings. The used gen3 Prius buyer today overpays upfront and has to deal with the issues.
    https://priuschat.com/threads/new-2-me-prius-v.245339/page-2#post-3410784
    The worse thing that is happening too often is a bad head gasket is temporarily masked by a $15 can of sealer. The car runs fine for a month or two leaving the buyer with no recourse.
    #13 rjparker, Dec 7, 2023
    JCBen, JohnPrius3005 and Mendel Leisk like this.
  14. Mendel Leisk
    42,332
    Watch the video linked in top link in my signature; that’ll give some idea, though there is a lot of unnecessary coolant spillage.
    a caution: a gen 3 for sale with 140k, odds are better than even it’s already got head gasket letting go. And/or burning oil due to the low-tension piston rings and 10k oil change interval.
    Honda Fits are cool cars; it’s a shame Honda’s discontinued it here. :(
    JCBen likes this.
  15. bettergolf
    495
    370
    Sanford NC
    "It costs a lot of money to save on gas!"
  16. Tombukt2
    13,853
    2,515
    Durham NC
    No I'd go with the Toyota Yaris You can find them a lot cheaper than the fit The fits enjoying up I don't know what but sales I guess Honda's doing well whatever it is The Yaris is a much better deal and better engine as far as I'm concerned and then if you're buying an older yara's like an '09 or something like that you're getting the same engine basically that's in a generation too Prius that's not detuned and not connected to an electric motor transmission and no battery so basically it's a generation 2 Prius without the electronics and a Yaris can almost get 40 on the highway or the Prius will get 40 pretty much on a bad day full time The yaris can get it on the highway. I have and seen yaris's here in Central North Carolina with 495,000 mi on them clean is a pin running like a top these are generally fleet cars that come from trucking companies Hertz rent a car whatever some of them are clean as a whistle too like 3,500.
  17. Leadfoot J. McCoalroller
    8,286
    7,795
    Pennsylvania
    2018 Prius c
    You had the right idea the first time, go back for more!
  18. JCBen
    JCBen New Member
    Massachusetts
    Thank you all SK much for your help. The 2010 was a no go for me for a few reasons and you all convinced me that a 2010 isn’t right for me/worth it to take a gamble on right now!
    The 2008 with 167k on it for $5300 seemed pretty good though and I’m going to take it to a mechanic tomorrow. I’m going to make a separate post, but the battery has been serviced and certain problem cells replaced - he showed me the computer running them all at around 15 (whatever that means). Still deciding if I should wait and look for a Fit though!
  19. JohnPrius3005
    423
    235
    Stay away from Priuses with over 100k miles. Get a regular gas car.
  20. Tombukt2
    13,853
    2,515
    Durham NC
    I see you're up in Massachusetts You're a simple thing is you need to just come down south for a week I don't know what you could do mini vacation I don't know what you do for a living or how you'd work that out but you'd find the car down here for probably half of what you're going to spend there with none of the body issues so on and so forth ready to almost ready to go and you could make it that way and still have less than the $5,300 that you're talking about unless people see you coming down here in the south that 09 Prius is just not worth a lot because everybody down here is expected to keep up with the Joneses and have a 2023 back to about a 2016 Prius prime v whatever the heck when people see my '09 coming and pulling into the parking lot they don't even pay it any mind It's like somebody driving an old VW beetle 25 years ago It is completely not thought about and I like it that way that is the best. My 08 silver Prius flies so far under the radar people look at you crazy if you were to mention it.
