Help, charger stuck in car! Can't drive to repair shop.
Discussion in 'Gen 3 Prius Main Forum' started by Cheryl 90210, May 25, 2023.
  1. Cheryl 90210
    Cheryl 90210 New Member
    My charging cable is fully stuck/broken in my Prius socket. Is there any way I can override the safety feature so I can drive the car to the repair shop dor them to remove the plug? After unplugging the charging cable from the wall first and securing it to the car of course.
    Or do I have to tow it to the repair shop?
    Thanks for any advice.
  2. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    The regular gen 3 has no plug in cable to charge from th wall. I checked mine, no plugs.
  3. PriusCamper
    PriusCamper Senior Member
    12,512
    5,070
    Pacific Northwest, USA
    They clearly stated they have a Plug-in Prius in their profile... No big deal, they posted to the wrong forum, I'm sure @Tideland Prius will fix it when he gets a chance.
  4. PriusCamper
    12,512
    5,070
    If you were more specific of what city/region you live you'd probably find a PriusChat nerd on here who lives nearby who'd be happy to show up and get the plug out for you and it'd probably cost next to nothing... But if you just want to say you live in the USA you're gonna have to get it towed to a mechanic who's gonna charge you a small fortune because they know they can get away with ripping you off without consequence.
  5. JC91006
    16,748
    8,553
    90210, sounds like a famous zip code in Beverly Hills.
    Maybe ask a strong friend and see if they can yank/pull that plug out. Maybe there's something wrong with it and a little brute force will do the trick
  6. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    See post #6 in this thread:
    Charging cable stuck in PIP - Any ideas? | PriusChat.
    If you get it to release, it's been reported that the gasket seal can be removed from the plug. This will make it easier to plug in and remove.
  7. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    The forum clearly states plug in forum, no big deal.
  8. Johnny Cakes
    Johnny Cakes Senior Member
    1,044
    780
    Virginia, USA
    Did you cycle the door locks? Many plug-ins will lock the plug to the car when the car is locked. This prevents someone from "syphoning" your electricity at a public charging station.
  9. bisco
    51,655
    i agree, pull harder. you can't really damage anything if you're pulling straight out
