help! charging question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tami Topper, Nov 30, 2012.
  1. SJ PiP
    SJ PiP Member
    190
    35
    bigger battery, no active cooling? strange decision.
  2. lensovet
    2,615
    496
    Burlington, NJ
    tell that to Nissan lol
  3. CharlesH
    2,798
    1,166
    Roseville, CA
    I have observed that if I tap the timer button before I get home , the timer light will stay on after I turn off the car, and be in timer mode when I then plug in. I don't know if this is the case for multiple on/off cycles,
  4. El Dobro
    El Dobro A Member
    7,102
    3,282
    You have to hit the button each time to set the timer before you shut the car down.
    CharlesH likes this.
  5. Tami Topper
    Tami Topper ocd about mpg
    30
    Oregon
    is there truly a benefit to using the timer? charging stops once it is done right? and if there is any leakage from the battery, would charging start again if it is still plugged in?
  6. El Dobro
    El Dobro A Member
    7,102
    3,282
    The main reason for the timer is so you can charge the car during off-peak hours.
  7. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    From the Manual, page 93:
    By observing the following precautions, battery charge
    decline can be suppressed.
    ●Avoid parking the vehicle in areas with a high temperature under direct
    sunlight when the hybrid battery (traction battery) is fully charged.
    Do not accelerate or decelerate frequently and suddenly when driving in
    EV mode.
    Avoid driving near the top speed for EV driving. (
    P. 40)
    Leave a low level of charge in the hybrid battery (traction battery) when
    leaving the vehicle undriven for a long period of time.
    After confirming that EV mode has switched to HV mode, turn the
    “POWER” switch off.
    ●Use the charging timer function as much as possible in order to fully
    charge the hybrid battery (traction battery) immediately before starting
    off.
  8. bisco
    52,773
    the benefit of the timer is if you cannot charge just before leaving. if you pug in when you get home, and it sits charged for 8-12 hours or so, it will have a small long term negative effect on the battery. if you can plug in 3-6 hours before leaving, that's fine. also, if the battery is warm from charging when you drive off in cooler weather, that is a benfit to efficiency.
  9. Tami Topper
    30
    Oregon
    ok. it is all starting to makes sense.
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    About :50 into the video.
  11. Tami Topper
    30
    Oregon
    nice...i used the timer successfully last night!! :)
    lensovet likes this.
  12. SJ PiP
    SJ PiP Member
    190
    35
    i've noticed when i set the timer to start past midnight it finishes quicker than during the day (~2:20 total?).
  13. lensovet
    2,615
    496
    Burlington, NJ
    Is the EVSE on a dedicated circuit? If not, could be because of slightly higher voltage due to less draws from other devices.
    SJ PiP likes this.
  14. SJ PiP
    SJ PiP Member
    190
    35
    yes, the latter explains it
  15. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    After a short trip (3-4 miles) last night, I set the timer to finish at 7:20am. The battery was mostly charged already so I was just topping up for the 3-4 miles.
    The charging started at 3:14am (and finished at 4:09).
    So is this normal? Does the finish at timer mode assume you need a full charge?
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, normal. the charger automatically shuts off when battery is at "full" charge:D
  17. delrey
    delrey Member
    280
    Oh, that's not what I meant. I did expect the charge to take about an hour, so I was not surprised that it shut off at 4:09am. What I expected from the timer though, is that the charging should start about an hour before the finish time (because my battery level only needed about an hour to be topped up to full again).
    In other words, I set it to finish at to finish at 7:20 am and therefor it should have started charging around 6:20 am. Instead it did not take the current charge level into account when deciding when to begin charging. It actually started at 3:14am, almost 3 hours too early. This makes the finish mode of the timer a lot less useful -- I can subtract ~3 hours all by myself and just use the start time if that is all it is doing.
  18. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    That's why many here like to use the "start timer"... just subtract 3hrs from when you'd like to use the car and you're set....
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    The charging system in the PIP monitors the battery level (SOC) eight times during the charging session to determine how long the charger will charge. The timer therefore has no way to know when to finish.
  20. delrey
    delrey Member
    280
    Well it could certainly get a closer estimate - but now I understand how it works & I can do my own estimate.
    Either way it's approximately (3 hours * percentage of battery charge used).
    Thanks!
    Marina
