help! charging question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tami Topper, Nov 30, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    When I have .9 miles EV left my charge time is 2 hours and 34 minutes, but my line voltage is lower than 120 volts (107.0 volts) so my charge time will probably longer than yours
  2. lensovet
    2,615
    496
    Burlington, NJ
    keep in mind that the last 15-20% or so charge at a slower rate also
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    the last 10 minutes charge at half the wattage of the first 2 hours and 24 minutes:D
  4. lensovet
    2,615
    496
    Burlington, NJ
    well you're never starting from zero…or "negative" range for that matter (HV)
  5. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    You can press the timer after the car is OFF as well.
  6. gallde
    238
    131
    Tarrytown, NY
    The manual (and others) advise to delay the charge so it completes just before you need to use the car again. Does anyone know if this is as important if the temps are below freezing? That is, does the supposed degradation of the battery by leaving it charged for hours occur more (or only) at high temps or is it also of concern at low temps?
  7. lensovet
    2,615
    496
    Burlington, NJ
    I think the reason for charging just before leaving in colder temps is to just maximize EV range since battery output is limited by battery temp and charging raises it.
