Help connect OEM reverse camera to aftermarket radio
Discussion in 'Gen 3 Prius Audio and Electronics' started by Rob adame, Aug 9, 2021.
  1. Rob adame
    Rob adame New Member
    Los Angeles
    I just installed an aftermarket radio and have been having trouble figuring out how to retain my back up camera.I have been do a lot of research and they have been helpful on what I need but never give me enough confidence to snip wires.
    I have bought a 12v to 6v step down and a RCA cable.
    I located the camera harness (16 pins with 5 wires) but I can’t find any diagrams on what those wires are. I’ve also been trying to find the reverse trigger wire because most tutorials say I need it.
    I attached a pdf / photo with all the wire diagrams I have, can someone help me figure out how to do this?
    btw: I have a 2013 Prius not JBL with nav
  2. Rob adame
    Los Angeles
    Update: I have figured out how most of the process but I still cannot figure out what the wire colors in the camera harness are. There are two red wires, an orange, a white, and black wire. A total of 5 wires in a 16 pin connector, all the forms I see only talk about 4 wires.
  3. prius2010II
    prius2010II Member
    269
    23
    us
    Metra sells a cable adapter which will let you use a factory camera with an aftermarket HU.
    Montgomery likes this.
  4. rickster26ter
    rickster26ter New Member
    Greensboro, NC 27455
    @Rob adame - did you ever figure this out? My car is the same wiring, no yellow wire on that 16 pin connector.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    I would suggest to you both that you get an aftermarket harness. It eliminates the guess work.
  6. Montgomery
    2,254
    2,238
    Orange County, CA
    Here is what I am talking about. One end plugs into the new Head Unit, the other into all the old wires. That was it. Everything worked. Steering wheel buttons and reverse camera.
  7. thelast1
    thelast1 New Member
    Virginia
    Where did you buy this harness from?
  8. amarino
    amarino Member
    96
    70
    87
    The one in the picture looks like it is this from PAC:
    https://www.crutchfield.com/p_541RP4TY11/PAC-RP4-2-TY11-Wiring-Interface.html
    And you also need the camera adapter harness:
    https://www.crutchfield.com/p_541CAMTY11/PAC-CAM-TY11-Backup-Cam-Adapter.html
    Another brand to do the same thing is iDatalink:
    https://www.crutchfield.com/p_794ADSMRR/iDatalink-Maestro-RR-Interface-Module.html
    https://www.crutchfield.com/p_794HRRTO1C/iDatalink-HRN-HRR-TO1-Vehicle-specific-Harness-ADS-MRR-or-ADS-MRR2-module-also-required.html
    Please do your own research to confirm fitment for your exact car. Above is just an example.
    thelast1 likes this.
