Help! Dealer just said I need both batteries replaced...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kristieq2, Sep 12, 2013.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    Where are you at? I might buy it.
  2. kristieq2
    kristieq2 New Member
    Niceville, FL
    I live in Niceville, FL.
  3. kristieq2
    Niceville, FL
    No, I haven't done a thing to it yet. Trying to really weigh out all options before I put any more money into it.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    Ahh, too far from me.
  5. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    I agree with getting a second opinion. The 12-volt could be the root of most of your problems. If you have time to wait before repairing, let people on this site help you, it could save you a lot of unnecessary expense. Please add your location to your profile, so someone could help you find a good honest Toyota repair place or further diagnose the issue. I know things only break when spouse is deployed. "Retired Army Vet"
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The worst time to sell the car is when it is a lawn ornament. Nobody is going to pay much for it in that condition.
    Let's not throw the baby out with the bath water. Register the VIN at Toyota Owners Official Web Site: Service Coupons, Owner's Manuals, Service Scheduling And More so you can see the dealer performed service history. I would expect to see the 12v battery replaced at least once. (At best I get 3+ years from one.) Exide, Bosch & Optima make direct fit batteries so you don't have to buy one from the Toyota dealer.
    If the 12v battery is shot further diagnostics aren't possible. Does it charge when a trickle charger is hooked up? Does it hold a charge?
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I'd at least try a new 12V battery before condemning it. Do be very careful with any jump starts until then, you can fry the inverter if you get the polarity wrong.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,391
    3,260
    Madison, Wisconsin
    kristieq2,
    I agree that you should at least give the idea of a new 12v battery a try.
    Or do you have a different, known good, 12v car battery and a set of jumper cables?
    If so you could put it in the back temporarily and call me.
    I can talk you through some options and ideas for diagnostics.
    usnavystgc likes this.
  9. kristieq2
    Niceville, FL
    It has been a while because I have been really busy, but I finally got the DTC readouts from the dealer.
    He said there were 4 main codes that triggered many others. The four are:
    1) P3000
    2) P3193
    3)P0A80
    4)P3018
    He said that the fourth code indicates that block 8 on the HV was bad...and that the 12v IS the original battery. So, I know a lot of you said to go ahead and replace the 12v first and foremost and that might fix some of the problems, but is it worth spending $250 for the 12v if the HV is indeed bad?
    Any info would be awesome and thanks again for all of the help!!
  10. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Is your car not worth the $250 a new 12v would cost to determine if the battery is the culprit. And you can buy one online for $180 to $200 total. Install it yourself and that's the end of it. Or bring it to one of the nice auto places and usually they replace batteries for free if you ask them.
    You could very well have a bad traction battery. It could also be perfectly fine and the 12v is causing electrical gremlins. What is your gameplan if you have a bad traction battery? Scrap the car? Fix it? Sell it? If you have another good battery laying around you could temporarily connect it to the system (remove the original) and drive slowly and safely around with it sitting in the rear. If that works, then it is just the 12v battery. Now this is dangerous since the battery mount be mountable in that little JDM hole and in the event of a collision you now have a 50 pound lead object being hurled towards the back of your head. Momentum is a killer... But for testing late at night on deserted roads, it might be worth saving $250 if you are really that hard up for cash.
  11. kristieq2
    Niceville, FL
    I guess what I meant to say is with these 4 codes is it possible that the HV battery is ok and the 12v is the real culprit? The one code says that module 8 is bad in the HV battery. If module 8 is bad is it still possible to have the HV battery operate properly with a new 12v battery?
    If the HV battery is bad we are going to sell the car, which is why I don't want to buy a $200 12v battery. I have no reason to spend the $200 on a 12v battery and then just wave goodbye to the car. In my opinion there is no reason to spend half the value of the car putting 2 new batteries in it just to get a couple more years out of it at this high of mileage.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is definitely possible, that's why we say replace the 12v.
    It will not operate "properly" with a bad module. It can however limp along for tens of thousands of miles. Anytime the cells get too out of balance, codes will be thrown. You can reset and ignore them, but know that you are running on borrowed time. To keep the cells more in balance, use the pack less. The Prius cannot be run with the ICE only, you always need the battery at a bare minimum to spin up and start the gasoline engine. If you putter around after that you should be fine for a while. If you are punching the acceleration, you will most definitely throw codes.
    Sell the car how? A dealership wont appreciate the new battery, but a private party will appreciate at least some, maybe half, of that value. If you are just going to crush it, then take the battery out and use it somewhere else. Lead is lead.
    Used cars are a gamble, and fixing them even more so. You have no control over the last owner. 200K is very early for a modern Toyota to break down, and I would have no hesitations putting in a $2000 Re-Involt battery and driving it another decade with nothing else but maintenance items.
  13. kristieq2
    Niceville, FL
    Ok well I went ahead and ordered a 12v battery just in case. I will post results when I get it installed next week. Thanks for all the help.
  14. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Hope you can return that 12V you just ordered. It won't cure what's ailing your Prius (IMHO).
  15. Patrick Wong
    18,200
    6,500
    The high voltage traction battery has a problem and this will not go away if you replace the 12V battery.
    OK, then you should cancel your order for the 12V battery and work on getting rid of the car.
  16. kristieq2
    Niceville, FL
    Okay you guys freaked me out, I cancelled the order for the 12v...Hopefully I can find a new owner for this car who will have the time and husband around to tinker with it. The dealer said they would accept it for a trade in so that is at least a start or an option. Otherwise I am going to try and post it on CL and see if I can't find someone who wants to put work into it.
    Thanks a lot for your feedback!
  17. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    I agree with Patrick. I would say from this thread that you're not a do-it-yourselfer when it comes to working on a high-voltage hybrid system. That is probably the only way to get an economical repair on your vehicle. Those codes indicate serious problems with the HV battery pack and possibly the ECU. There are four subsets of the P3000 DTC (123, 124, 388, and 389), but they all require a qualified hybrid mechanic to track down and figure out which one or ones it is. Maybe you can find one of these do-it-yourselfers that will make you a decent offer for your car. Hope it turns out OK.
  18. ericbecky
    4,391
    3,260
    Madison, Wisconsin
    Kristie,
    Again, feel free to give me a call and we can briefly talk. 608-729-4082
    (I'd call you but obviously I don't have your #)
    Or drop me an email with your number and a time to call. [email protected]
    Even if you decide to sell the car I may be able to help you with that.
  19. cthorsman
    cthorsman Member
    75
    27
    Maryland
    Tomas Zakarka (727)686-1943 for hybrid battery rebuilds in the Tampa/St. Pete/Clearwater, Florida area.
    He is probably too far away, but maybe he knows someone in your area.
    In my area I found several mechanics who provided prius hybrid battery rebuilds. At least one came to the vehicle. It would be much cheaper than the alternatives.
    Best of luck.
  20. ericbecky
    4,391
    3,260
    Madison, Wisconsin
    I think she sold the car.
    Someone likely got a great deal for a car that may have simply needed a 12v battery.
