Help diagnose a constant cylinder 2 misfire?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SB6, Oct 5, 2024.
  1. SB6
    SB6 Member
    324
    71
    2010 Prius II, 182k miles. P0302 since about 3-4 weeks ago.
    I tried swapping spark plug 2 and 3 and clearing the codes to see if it changed from P0302 to P0303, but no luck. Tried the same with coils 2 and 3, and it looked like the same result. I'm going to retry this to confirm.
    I tried blocking off the EGR valve with a metal spatula to see if the misfires smoothed out, but no luck (I think the code turned to P0304 after clearing codes and doing this test, for some reason).
    Engine coolant and oil seemed at normal levels, and not discolored. I haven't noticed any white smoke from the exhaust.
    182k miles now, as mentioned above. Around 140k I did my engine coolant pump, both coolants, PCV valve, spark plugs, and cleaned my intake manifold, throttle body, EGR pipe, and EGR (although I guess I didn't fully clean, just did the best I could and put it back together). No oil catch can. Also did my transmission fluid around the same time, if it matters.
    What tests can I do to see if it's something I can fix on my own, rather than having to fork over $3-5k for having someone replace the engine? Would appreciate some guidance. I'm not the best with cars, but by following videos and instructions, I've gone from screwing up a simple oil change to doing my own brakes, suspension, and "tune up" stuff mentioned above.
  2. Tombukt2
    Tombukt2 Senior Member
    13,839
    2,514
    Durham NC
    This is normal for this engine and this model Don't get too hung up on it because you can have a lot of money in it no matter who's doing the work Is the car in that nice of a shape to warrant winding up spending 3 to 5K If your time is free well so be it most people's time is not free they have places to be work to do etc so there's always that You're working on something that is pretty much planned obsolescence and executed very well by the likes of a company called Toyota and if you don't think they know how to enact plan obsolescence well you have another thing coming you're sitting in it Go back one year to a 2009 Prius and notice the huge difference in reliability and all of that Just one year it is amazing but a that's where we are anything you can do inexpensively I doubt it You see all the shops popping up around the country just to deal with this issue between 3:00 and 8K is generally what you're looking at Good luck the whole car isn't worth that at least not to me I have two sitting here please come get them
  3. Mendel Leisk
    42,309
    At 182k miles, with EGR semi-cleaned at 140k miles, and cylinder 2 misfire? Head gasket.
    how’s the oil consumption?
  4. SB6
    SB6 Member
    324
    71
    None noticed
  5. Mendel Leisk
    42,309
    You could score the Toyota gasket kit (includes head hasket), new head bolts, a tube of Permatex Ultra-Black and a 10 mm double-hex bit and have at it.
    Do a thorough EGR clean while you’re at it, and consider an oil catch can.
    full disclosure: never done anything like this personally.
    PriusCamper likes this.
  6. SB6
    SB6 Member
    324
    71
    Looking around on Google, it looks like I can do a compression test and a leak down test to test for the head gasket. Compression test looks doable for me, although if you have a good video or something for it, please do link it. Haven't looked into the leaks own test yet. I also saw something about getting an exhaust gas test kit for the coolant?
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,055
    6,927
    Texas Hill Country
    Knowing the symptoms can be useful. Has it shaked and rattled on engine starts only to clear up as it warms up? If so how long ago did this start and how often does it happen now?
    None of that is conclusive on early gen3 head gasket leaks. So much so I would not waste my time on a compression or leak down test.
    A quality dual view borescope is a decent hg verification tool.
    Early leaks are very small and depend on coolant pressure seeping into a cylinder as the engine cools. On a cold start, the plug may be fouled or may not.
    When it’s an advanced hg fail it may shake and rattle after warmup and be noticeable with the coolant gas test. At that point coolant reservoir drops can be observed. Even later white smoke may be observed in the back as the engine is rev’ed. At that point the odds are good a hg alone won’t fix it long term.
    Shudder video
    “Hey Walt… they want to wait and see if it gets worse…”
    Car Care Nut HG Borescope at 7:40
    #7 rjparker, Oct 5, 2024
    Brian1954 and Mendel Leisk like this.
  8. SB6
    SB6 Member
    324
    71
    Currently it's just constant knocking and shaking. Previously, I recall this happening just for a few seconds on startup maybe 2-3 times. If I recall correctly, each of those times was the first startup after I had the car apart for a while.
    I did not notice anything really building up to this, though. I drove to work one morning, and everything seemed fine. During lunch time I pulled out of the parking lot, and the engine started shaking and knocking a few seconds later, I'm guessing accompanied by low engine power, followed soon after by a flashing check engine light. I pulled over and used my Bluetooth scanner with Torque Pro, and got P0302. Cleared the code a few times after that, but the P0302 kept coming back, up until I tried to do the test blocking off the EGR valve a few days ago, which is the only time so far that I saw a different code -- P0304. I haven't yet tried anything else since then.
    What would you suggest I do? I've been hoping I could slowly diagnose and fix the car myself, but maybe it's best to just get rid of the car by selling as-is or parting it out? Thankfully I don't need this car anymore, so I can live with any of the above options
  9. ChapmanF
    18,994
    If this indeed is a constant cylinder 2 misfire as the thread title says, then the explanation probably isn't the "your head gasket leaked some coolant in while the car was off and you got misfires for a short time on startup" that usually leads people onto the head gasket story.
    Misfires, as always, are a fuel-supply problem, an ignition problem, or a compression problem.
    The famous brief shakes at startup head gasket issue is a failure of ignition; the cylinder charge with some coolant in it doesn't ignite. (If the leaked coolant is enough to cause hydrolock, then worse things happen.) That's the problem that reportedly is hard to see on compression or leakdown tests, because all that's happening is a small amount of coolant oozing through.
    On the other hand, if that's not the story here, then the only other way this could be a head gasket issue would be if the gasket is leaky enough to cause misfiring by bad compression. And that should not be hard to see on a compression or leakdown test.
    Or if it's not head gasket, it's back to the other causes of misfires. Other compression issues (burned valve, say), or ignition or fuel.
    You've tried swapping spark plugs and coils. Have you tried swapping fuel injectors?
    Is the misfiring really constant, or is there more of it at mid engine loads (not idle, not all out)? Although you did clean your manifold 42k miles ago, have you had it off since just to check the small passages?
  10. rjparker
    11,055
    6,927
    Texas Hill Country
    I would certainly swap plugs, coils and injectors around to see if the misfires move. A borescope inspection would be my first test after the plugs are removed, assuming they look good.
    The troublesome detail is the misfire already moved from 302 to 304. And there is some history of startup shakes that cleared. I have seen advanced hg cases where it misfires a lot but those were usually accompanied with white exhaust vapor someone behind observes as the engine is rev’d up. The vaporized coolant is not obvious from the drivers seat. The engine still runs and the misfires are not constant unless a plug has seriously gummed up and remains fouled, which happens. In these cases coolant level will drop if driven for any period.
