Help diagnose possible bad transaxle damper
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nick Seifert, Apr 26, 2025.
  1. Nick Seifert
    Nick Seifert Junior Member
    36
    Vt
    This is in a 2012 plug in prius, 194k miles on it. I've owned it since 86k, and done a lot of preventative maintenance. EGR was done ~40k miles ago, and was not clogged at all. OEM water pump 80k ago. Does not burn a drop of oil, or coolant. transaxle fluid has been done twice, engine and inverter coolant twice. Plugs were done 94k mi ago.
    Today, while my wife was driving, it made a loud noise, then kept making noise while driving, and seemed to lose power, but she was able to pull off and call me.
    When charged, and running as an EV, it's normal. no noises, no issues. So seems like it must be "upstream" of MG2. It is rougher than usual transitioning out of EV/ECO when the engine turns on. I will say, since i've owned it it has always had a bit of a judder coming off EV/ECO when the engine turns on, just a slight hesitation feeling. But it is now worse. If i baby the throttle so the engine comes on more gently, it is not as bad.
    I have not pulled codes yet, but there is no CEL on.
    I'm guessing one, or more, of the damper springs are broken. Any way to confirm this? or what other diagnostics would folks recommend?
    For the price of new plugs i'm thinking i'll just change them and be sure this isn't a misfire... Other ideas?
  2. ChapmanF
    19,016
    If springs have broken. there are likely to be spring fragments you can feel putting your fingers through the inspection handhold and downward (with the car off!!).
    I tend to think that a car where the damper springs are beaten to smithereens may be a car that had unaddressed engine problems for a while leading to that.
    Nick Seifert likes this.
  3. Nick Seifert
    36
    Vt
    Ok great, thank you @ChapmanF I will check this inspection window and report back. Fingers crossed for no spring chunks…
    I can’t speak for previous owner, but afaik I’ve taken good care of this engine. Possibly this is a plug in Prius thing, due to the fact the engine will kick on at high power draw in EV mode?
  4. ChapmanF
    19,016
    Looks like something autocorrected 'handhole' when I wrote it to 'handhold', but I guess you could tell what I meant.
  5. Nick Seifert
    36
    Vt
    ok. i pulled codes, the only one confirmed is U0146 - "lost communication with Body ECU". i'm using an older OBD2 scanner, so likely will buy a newer one to make sure this isn't a me thing.
    I removed a cover on the back of the flywheel, seems to be called the "starter hole insulator" per Page 11 of this book.
    There was also a little plastic cover on the back of the flywheel housing, at the bottom. I could not feel much through these... and don't have a boroscope to really check for pieces. however, when i moved the flywheel back and forth, it made a very loose sounding metallic noise.
    Is there another cover? i don't have a lift, so really couldn't see one, nor in any of the images in the link above.
    i'm going to swap plugs preventatively... about due anyway, but this is seeming unlikely.
    Any other suggestions to diagnose this myself?
    Also wondering if there are any ways to avoid shocks from MG1 if this is the issue... I can, for instance, not charge the battery so it runs EV less. or would running in B mode help? Hoping to avoid a sheared transaxle shaft...
  6. Nick Seifert
    36
    Vt
    With a "pro" scan tool i've confirmed: U0146, B1206, B2321. I don't know if these codes were present before or after "the event", but no CEL has been on for at least 1+ years.
    I swapped plugs. None were wet, and overall in OK shape. Center electrodes seemed fine, but ground electrodes all had some uneven wear, and a max gap of around .055. The old plugs were NGK OEM, but not double platinum, wear seems about normal for ~95k miles of use. No noticeable difference after installing the plugs.
    Still hoping for some input on any of the following:
    • Is there another way to confirm/check/diagnose if this is a degrading transmission damper? I can probably borrow a boroscope if this is the best way.
    • This is my daily, so wondering the best way to avoid shocks from the engine/MG1. Thoughts?
      • Mainly i'm planning to "save" any EV range i have as a "just in case", so i could limp it if needed.
  7. ChapmanF
    19,016
    I don't think there's much to be done there. The shocks in question are coming hundreds of times a minute, inherent in being a car. If the engine isn't misfiring they ought to be mild enough not to endanger the damper spings.
  8. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The sensation of the consequences of the destruction of the damper disk can be felt by you, you can hear uneven operation of the hybrid transmission and engine. When the springs are destroyed, there will be a clanking of metal. There will be metal burrs on the body, which can be seen when disassembling the hybrid transmission.
    Is this transaxle dead? | PriusChat
    #8 MAX2, Apr 27, 2025
  9. Mendel Leisk
    42,343
    Probably head gasket failure and consequentially damper springs broke.
    Did you clean EGR passages on the intake manifold?
  10. Nick Seifert
    36
    Vt
    Yes, as stated in the #1 post, done 40k miles ago. not squeaky clean, but none of the EGR passages were clogged. fully cleaned at that time. No coolant consumption, oil stays extremely clean, no oil consumption at all.
    Thanks for the Gen2 post, i hadn't looked over there. The Gen3 transaxle has a second planetary gearset, but don't believe this changes the symptoms. no uneven operation experienced, but if i really hammer the gas, i am now hearing a "clunk"... unfortunately this seems to be confirming my suspicions.
    I am going to try and borrow a boroscope this weekend and get a view inside the "bell housing" for the flywheel and damper and see the real story.
    As a reminder, this is a Plug in Prius. I thought i recalled that with the Lithium Ion battery there is a higher current available to MG2? I know the regular Gen3 will not get to 62MPG on battery / MG2 alone... so wondering if this is related to a difference with the Plug in Prius. That aside, with 194k miles this is no spring chicken :D
  11. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    The damper disc on Gen3 is slightly different from Gen2, and is not different at all from the Prius PHEV 2012-2015
  12. Nick Seifert
    36
    Vt
    I tried to get a borescope in the "bell housing" where this damper sits, but no luck. the camera head of the borescope i borrowed was too big, and not able to be articulated in a way that would let me see the location of the springs. However, while i had access i listened to the engine while it was turned off, definitely a rattling sound from that area. Likewise, when i move the flywheel by hand, it is making a loose clanking sound.
    I was not able to see any spring chunks in the bottom of the "bell housing", so my guess is i have at least one broken spring, but maybe still being held in place.
    Judging by some other posts, my symptoms are not nearly as bad enough to show up similarly to a misfire... i may try to find a better borescope, or may just wait this out and go easy on the gas pedal...
  13. Abarnabe
    Abarnabe Active Member
    172
    102
    Netherlands
    i
    did the issue worsened or is it the same after few months? I am experiencing something similar
