Help diagnosing HV battery issue on 2006 Prius
Discussion in 'Gen 2 Prius Main Forum' started by pauljus, Jan 3, 2018.
  1. bisco
    52,822
    12.55 is excellent if the car was off for several hours. not sure how they test it. let's see what the report says. what does the warning on that label say about hybrid vehicles?
  2. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Give charging a try, I'm not one for throwing out serviceable parts. Only trying and time will tell.
    BTW, refer to the chart above, 12.55 V eq ~ 62% charge, not 89% (for an AGM battery.)
  3. pauljus
    pauljus New Member
    27
    Detroit, MI
    This is quite an excellent post - thank you! No offense taken; I came here seeking help and I am getting it! I apologize to you guys for my lack of knowledge, so thank you for bearing with me.
    So I will replace the 12v. Do you suspect that is what's causing all the error codes, including the P0A80 code? (hybrid battery failure)
    kenoarto likes this.
  4. pauljus
    pauljus New Member
    27
    Detroit, MI
    It wasn't off for several hours. She drove it for 10 mins a couple hours prior to having it tested.
    DO NOT test the starter, alternator, and/or 12 volt starting battery while it is in the vehicle.
    Remove these items from the vehicle before testing.
  5. dolj
    dolj Senior Member
    8,640
    4,391
    Most likely some of the others, but likely not the P0A80. The saving grace is that you do not have any P301x codes. But it could just be a matter of time.
    It might be that while sitting, the car self-discharged to the lower limits and running it brought it back up. Only time will tell. But just run with it and start saving for either a new HV battery or a updated car deposit. Whichever suits your circumstances, skillset, appetite for risk, etc.
  6. pauljus
    pauljus New Member
    27
    Detroit, MI
    I dont have a charger. If I get it done at the dealership, do I need to specify that they charge before installation. And how do I ensure the new AGM battery is not less than 12.9v?
    Thanks!
  7. dolj
    dolj Senior Member
    8,640
    4,391
    If you have to rely on the dealership or any other professional, they should know to do these things. You can ask they check the battery voltage and charge it up before installing. But at the end of the day you just have to trust in the professionals you employ.
  8. pauljus
    pauljus New Member
    27
    Detroit, MI
    Well, they it did come back with a P3000 code. I'm not sure if that's the actual code or if there is a subcode to that. I attached the printout from them.
  9. dolj
    dolj Senior Member
    8,640
    4,391
    Your attachment shows the P3000 highlighted, which I take it means there is a sub-code for it. P3000 is logged by the hybrid vehicle ECU and really just means that it heard from the HV Battery ECU that it (the HV Battery ECU) has a problem.
  10. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Invest in a Prius Aware Scanner that will give you the subcodes. There several to choose from such as:
    • ScanGuage II
    • Mini VCI
    • Denso Hand Held Toyota Tester II
    • ELM327 Bluetooth OBDII Scanner
    I have all four and like the HHTT II the best, but it's pricey at about $300 off eBay. The ScanGuage II was about $150; I bought mine at Autozone. The Mini VCI can be bought off eBay, but you need a laptop (running XP) to run it or good computer skills to get it to run on Win10 in a virtual box. The ELM327's are upwards of $3 to $20 on eBay, they work with Android Phones. I like these, but the ones I bought (the little blue ones..$3) worked on all the other cars, but not my Prius. Everything I read says to buy a more expensive one.
    Read up on these within the forum searching on Code Reader. In any case, you free yourself from the auto parts Stores and from the Dealers when you have one of these in your car or garage. It's nice to be able to better diagnose a vehicle and shut off codes when applicable.
  11. pauljus
    pauljus New Member
    27
    Detroit, MI
    @dolj @bisco
    So I had the dealership send me the subcode data for the P3000 code and also the test result of the HV battery block tests...please see the attachments.
    The prius tech said regarding the 12v being the cause for the codes: "Battery Voltage was 14 Volts when P0A80 was stored this would eliminate any possibility of the dtc being caused by 12V Aux battery Failure."
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Battery block 12 looks bad.
    If you had an Elm 327 OBDII Bluetooth reader you would have seen it within 30 seconds connecting it to the Torque Pro app.
    strawbrad likes this.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You have a failed HV battery. :( It's been slowly failing since the day it was built nearly 13 years ago. Extreme temps, whether it be hot or cold, can be the final straw to trigger the codes. For me, it was the summer heat and letting it sit too long unused.
    GOOD LUCK!
  14. pauljus
    pauljus New Member
    27
    Detroit, MI
    Thanks. Would re-balancing/charging help or is more than likely shot?
  15. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    In my opinion it is too far gone for balancing.
    I would move on to with her replacing the module or the entire pack.
    FYI, Toyota just dropped the price of a Gen 2 pack by approx $400. If you got a quote prior to January 1st, it should be less now. Unless they plan on keeping that $400 for themselves.
    SFO and kenoarto like this.
  16. pauljus
    pauljus New Member
    27
    Detroit, MI
    Thanks for the info.
    I think we will be using a rebuilt from hometown hybrids. Any thoughts?
    Thanks.
  17. strawbrad
    953
    1,007
    The P0A80 file contains the smoking gun. Battery block 12 contains the failed module and cell. This reading could be easily rechecked with a Prius scanner looking at live battery data while doing a forced charge and discharge.
    I would hold off on replacing the 12 volt battery, but I'm cheap.o_O
    You do need to start looking for a HV battery.
    Brad
  18. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I like Hometown Hybrids. It's been fun to see Jessica's business thrive.
    Honest, knowledgeable folks.
  19. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I don't know if Hometown does NEW Toyota packs, but it might be worth asking just to find out pricing.
    Report back here if you find out.
  20. pauljus
    pauljus New Member
    27
    Detroit, MI
    I spoke with her yesterday. New packs are $2399 + installation if you are outside of their service area. It comes with a 36 month/75k mile warranty.
