Help diagnosing loud road noise?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ethan Waldman, Jun 8, 2017.
  1. Ethan Waldman
    Ethan Waldman Junior Member
    45
    Vermont
    2011 Prius III
    79,XXX miles
    I'm trying to figure out the source of some loud road noise on my Prius. I think it's coming from the drivers side front wheel, but it's hard to tell. The noise starts up at about 25 mph and increases in intensity as you get faster. It almost sounds like loud tire noise. I can't feel anything in the steering wheel, so doesn't feel like a balance issue either.
    The tires are Michelin Defenders that I bought brand new from Sears in April and have put about 4k miles on. The car was aligned at the dealership about a week later and showed no major adjustments.
    I have a friend with a Prius V who offered to let me take his front wheels off and put them on my car, so I could take a test drive and see if the noise was still there. His wheels are the 16" and have 205/60/R16 tires (also Defenders), while mine has the 15" rims and 195/65/R15.
    First question: can this swap be done safely?
    Second question: If not, what should I do to diagnose the source of the noise. It's loud, and I think it's getting louder (though maybe I'm just hearing it more now that I'm focused on it).
    Aside: The same friend has a heat camera, so we took the car on the highway and then shot it at the hub area to see if one side got hotter than the other. They both stayed the same temp.
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    The noise might not be coming from a tire at all. Also consider a wheel bearing, failing CV joint or a brake rotor/caliper problem.
    Can you better describe the noise? Scrapping? Grinding? Whirring? Thumping? Can you record and post what you're hearing?
    Raytheeagle and tankyuong like this.
  3. Ethan Waldman
    45
    Vermont
    Hi Don, thanks for your reply. I had a friend in the car the other day who asked if I still had my snow tires on- the noise sounds like that. It has a tone that increases in pitch as I speed up. Definitely not a scraping or grinding sound. More of a RRRRRRRRRRR sound. I will try to record and post today.
    52,855
    any change to the sound as you turn corners at speed? if not, i would just rotate the tyres front to back and see if it's more or less noticeable. 80k is right in a wheel bearings wheelhouse. especially in salt country.
  5. grnd0
    grnd0 Member
    42
    26
    Wheel bearing. Lots of us have had the problem.
  6. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    You can swap wheels for a little while
  7. Ethan Waldman
    45
    Vermont
    The wheel bearing was my thought as well. Here's an audio recording where I get up to about 40 mph toward minute two: link.
    I'm uploading a video right now (slow connection) where you can hear it very clearly. Will post when it's done.
    #7 Ethan Waldman, Jun 8, 2017
  8. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Wheel bearing.
  9. solrunner
    solrunner Member
    114
    37
    Reston, VA
    I think I have a similar noise too. Tech told me wheel bearing. I have 34,000 mi / 3.5 years old. Kind of annoying but I'll probably wait until it totally fails or gets really bad.
  10. Ethan Waldman
    45
    Vermont
    Here's that video:
    Since it sounds like the concensus is wheel bearing, I have two followup questions:
    -Is $150 a reasonable quote for labor for the job?
    -I see a huge range of prices on RockAuto. It seems like the Timken is the highest quality (and price) replacement. Has anyone had any luck with one of the less expensive options?
  11. mrbigh
    3,686
    699
    Long Island, NY
    Why do you want to risk a job with a part of lesser quality? and I would replace both wheel bearings....
  12. Ethan Waldman
    45
    Vermont
    I don't want to risk the job with lower quality! Was just curious if the less expensive parts were truly lower quality. Why do you recommend doing both at the same time? And what do you think about the $150 quote in labor?
  13. Spindifferent
    155
    79
    Central Texas
    Dealer charged me $162.00 for labor to replace one wheel bearing. I thought that this was reasonable.
  14. ASRDogman
    ASRDogman Senior Member
    8,066
    4,088
    They usually go in pairs. So it one is bad, the 2nd is also or shortly will be.
