Help Diagnosing Unintended/Uncommanded Acceleration Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nylion, May 2, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Since it wasn't a crash - it easily *could* have been though - but rather an "incident," separate people at NTSB were assigned to clear the report
    Since pilot error is usually the cause of most incidents, they naturally blamed the pilots the first time around.
    Once it became apparent similar issues were experienced by different flight crews, on the same aircraft, the database immediately flagged this.
    With further investigation, the sidestick was replaced, and Airbus introduced hardware changes (A resister to introduce a degree of damping to the signal) and software changes (Desensitize control inputs with Flaps 2 or Flaps 3 setting). This is supposed to be applied to all Airbus A320's of that series
    Since I have background with fly-by-wire and industrial process control (The same company, Honeywell, makes systems for both, with similar design), I don't automatically reject claims of odd behavior. I've seen enough odd problems caused by "simple" connector corrosion to personally determine that we're putting a bit too much faith in these systems
    Eg: these systems are not as infallible as the engineers and fanboys would like us to believe. Wild acceleration, such as Hemi V8 style acceleration from a Prius, is highly improbable
    But uncommanded acceleration, yes, I have no doubt it *can* happen, and as the fleet ages, *will* happen. Statistically, it *must* happen
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    What got my attention is that for a "common" database, the first report did not get updated with the latest findings, but was totally uncoordinated with the second report. Or as you clearly state, since it was not a crash, it got insufficent attention.
    The counterpart to this is how to pursue automobile issues of the same nature, like the one covered in this thread. If a proven Airbus problem gets "brushed off" as indicated in the first report, then it's got to be immensely harder to get real (but rare) auto issues identified and taken seriously. chogen2 listed all the similar statistics, but raw reports statistics does not tell us which ones were "real problems" vs. operator error. Obviously, most of those are indeed operator induced issues, but what percent are real? 0.01% or 5%?
    My starting suggestion would be a comprehensive "flight recorder" provided to the dealers that could be attached with the owners permission. Comments?
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    alright. so there are two throttle position sensors. one is on the accelerator pedal and the other is on the throttle body. their readings are matched up. if one mismatches with the other, there will be a code thrown and it sends you into limp-home mode.
    DH cannot think of any situation that would cause this problem and not throw a code.
    so it's not hardware. if it's software, as others here seem to be saying, then why is this only happening in this one vehicle?
  4. jayman
    13,439
    641
    Winnipeg Manitoba
    The TPS and pedal agreement is just to ensure relevant control input to output. Eg: if the throttle blade were to stick due to heavy deposits in the bore and on the blade, that would be similar to the industrial valve problem I discussed, eg "stiction"
    But if there is an internal failure in the pedal assembly, as Bob documented with that Gen I pedal assembly, there is no way for the computer to determine if it's a spurious signal or a genuine control input
    Since there are situations where the driver may have to floor it, the car is programmed to allow that sort of control input.
    The only way to determine if a control input is "valid" is to have 2-3 different sensors on the accelerator pedal assembly, with separate loop wiring back to the computer. Software "voting" would then be used to determine if the control input is valid
    That approach has obvious drawbacks. Even in the case of the Airbus incident with NorthWest Airlines that I discussed, the deposits in the sidestick potentiometer track were a common failure point. Eg a single mode failure that was - by design - impossible to avoid
    In that case, the aircraft responded to the spurious control input from the sidestick. If the sidestick would have failed in a full-deflection mode, a *very* dangerous event, there is an override button on the other sidestick. THe other pilot could have hit the override button, and assumed control again
    As a result of that Airbus incident, changes were made to the sidestick (Better sealing to keep trash out of the potentiometer tracks), the wiring (A resister was added to "dampen" spikes), and the software (Aircraft sensitivity in Flaps 2, Flaps 3, and Flaps Full settings was detuned)
    This problem may be rare for now, but as the fleet ages I'm sure we'll see more of these issues.
    IN case any lurkers are ready to pounce on this incident as a uniquely Prius problem, it isn't. My FJ Cruiser also has throttle-by-wire. Almost every new car and pickup has throttle-by-wire.
    I would imagine if the accelerator pedal assembly failed full input on a 2009 Dodge Ram hemi, there would be one truly spectacular burnout at a red light
  5. bwilson4web
    16,540
    Now that I don't have to fiddle with figuring out the FARS database, I have time to look at this problem properly ... after I get my GPS data extraction routine working.
  6. galaxee
    9,810
    471
    MD
    the accelerator pedal has two sensors, actually- one to send the input, the other to verify it is real. if there is a discrepancy, it sets a code.
    if there is a discrepancy between the accel pedal and the throttle body, it sets a code and drops into fail-safe mode.
    effectively, both accel pedal sensors would have to fail in a manner in which the output remains within the bounds and they both agree. the likelihood of this happening is ~0.
    now. if this is a software issue, it's either in the ECM or the HV ECU. if the car is still under warranty, the owner needs to go to the dealership and tell them if they cannot fix the car, because this is a SAFETY ISSUE (key words), he wants an even trade for a new car. both computers should be replaced. even if they only do one, if it happens again after the warranty expires and there is record of a complaint prior to warranty expiration, the other should be covered because the issue happened prior to the warranty expiration.
    if they open a repair order, and tell you it cannot be fixed, tell them you will not accept the car back and call the toyota customer experience center.
    you want to focus on the word "safety" and how you do not feel safe in the car.
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Wouldn't something mechanically snagging the pedal cause this?
  8. galaxee
    9,810
    471
    MD
    yes, but that is different from the sensors failing. that is something pulling the pedal down outside of the driver's control. which is interpreted as a valid signal, because... technically it is. something is physically changing the position of the pedal.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Ok, this thing about the accelerator pedal has been bugging me. I am also thinking about the intermittant problems with the Airbus fly-by-wire sidestick, as in neither case was a code stored
    The Prius accelerator pedal sensor schematic
    Some of the possible DTC associated with the accelerator pedal
    However, thinking of that pedal assembly Bob took apart, a *common* or single mode failure, very similar to what happened to the Northwest Airlines Airbus sidestick controller, may very well impact the signal output uniformly and *not* meet the requirements to set a DTC
    The car actually would think the pedal was physically moved. Like in the case of that Airbus having the uncommanded roll, the pilots probably both yelled "Wth!" but the aircraft behaved as if it was a valid control input
    This would be a very unusual and rare failure, as it was for the Airbus and as it probably is for the Prius - or any vehicle with throttle-by-wire. However, it's not statistically impossible
    In the case of Airbus, since safety was an overriding priority, all sidestick controllers had to be inspected for wear and foreign material, eg spilled coffee. Changes were made to the wiring (Resister added to dampen voltage spikes) and to the software (Aircraft "detuned" to be much less sensitive in Flaps 2, Flaps 3, and Flaps Full)
    Similar issues are present in the fly-by-wire Boeing 777. The control column sensors call for routine inspection and servicing
  10. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    As far as I know, NHTSA might order an investigation if enough of the same/similar issues are reported by drivers. The auto manufacturer might initiate their own w/o NHTSA's order. This is how many recalls come about.
    I'm unclear if there is an absolute threshold in terms of absolute numbers or a percentage that might be the trigger.
    Unfortunately, some of the "unintended" acceleration issues are user error (driving stepping on the accelerator instead of the brake) or floor mat issues.
  11. dogfriend
    7,512
    1,191
    Carmichael, CA
    I recall in the case of the Ford Explorer / Firestone tire issue, the trigger was that the Firestone tires fitted on the Explorer had a much higher trend separation failure rate compared to other tires of the same type. When they investigated further, the "bad" tires were mostly a single size that came from a single Firestone factory, so they initially recalled just that size produced at that factory. Later, when it was determined to be a design flaw, Ford recalled addtional sizes of the Firestone tires.
    So, in triggering an investigation, they are looking for a higher incidence of the problem compared to other similar cars.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    On the first point, I suspect the seriousness of the issue also heavily weights the trigger
    On the second point, yes there is enough "noise" that even NHTSA may conclude driver error
    To bring up the example - again - of the Airbus with the sidestick problem, this was an *extremely* rare problem for the fleet. However, an uncommanded roll, especially in a takeoff or landing phase, could have fatal consequences
    Even though the Airbus is designed with an "override" button on the sidestick, so the other pilot can take control from an errant sidestick, the momentary delay in doing so could be pretty serious
    The NTSB database entries for the same tail number of the Airbus illustrate how quickly they escalated the seriousness of the incident. It went from being a pilot issue to being a major hardware/software inspection and repair issue fleet-wide
  13. bwilson4web
    16,540
    WANTED: NHW20 accelerator assembly.
    Suggestions?
    I think it is time to get one and take it apart to see how it goes together. Alternatively, ask the original poster if they would be willing to swap a salvage with their accelerator assembly for detailed analysis?
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    Bob
    Now you're talking. As far as pinouts, the Gen I accel pedal sensor you took apart hints it has a lot in common with the Gen II. Although two hall effect sensors are involved, a failure of the common shaft could cause problems
    Apparently, according to the shop manual, later models (+2005??) will monitor for "noise" like the kind you recorded with the full range travel. There is a DTC for that, but like all things, there is always a chance of a failure mode not anticipated and/or monitored for
  15. nylion
    nylion New Member
    167
    61
    Seattle WA
    I don't think it is just my car. There are other reports that seem credible. The problem with this sort of incident is that the average person becomes so involved with dealing with controlling the car, that the quality of observations diminish. I am sure this same issue occured at least two other times. However, during those events I was entering an interstate and didn't have time to process and analyze. This latest event when I was stopped at a traffic light, so I was under a lot less pressure.
    I am a software professional and deal with bugs daily. I don't fix em, just decide whether others should. I don't think this is purely software. It could be. I have encountered bugs that occurred once in millions of operations. But this feels like a combination of events. That's probably why it is so rare.
  16. nylion
    nylion New Member
    167
    61
    Seattle WA
    Clearly you don't have any real world experience with this. I brought the car to the dealer and, as expected, they found no codes. Toyota won't pay for a replacement ECU, much less a new car if they can't get evidence of the issue, either through system error codes or reproducing the problem by a dealer mechanic. My only option is to sue Toyota, but then I am in the same bind. As of now, I can't offer reasonable proof that this problem exists. It's just my word.
    I did file a report with the NHTSA. That may or may not do any good. Sadly, without a free lawyer or more evidence I can't do any more.
  17. galaxee
    9,810
    471
    MD
    um, ok, if you insist. good luck.
  18. nylion
    nylion New Member
    167
    61
    Seattle WA
    My car is still under warranty. I am not sure how swapping the accelerator assembly would fly. I also don't have the mechanical skills to do the swap. I am willing to do it, but unless someone can do it for me, I don't see how it will get done.
  19. dogfriend
    7,512
    1,191
    Carmichael, CA
    You aren't going to get the dealership to fix this problem because they probably think you are a crackpot. You have a couple of options:
    1. Continue as normal, maybe it will go away, maybe it won't
    2. Try to reproduce the same conditions when the problem occurred - forcing the failure and hopefully taking measurements to determine Wth is going on
    3. Shotgun approach to solve problem - clean (or replace) TB, examine (or replace) accel pedal, inspect all connectors to ECU, etc.
    4. Trade it in on another car.
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    This comment is silly. Galaxee has more real world experience than you can imagine.
    Tom
