help . Door locks. Prius v (lowercase v)
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Michele de Lucca-Lowrey, Apr 2, 2016.
  1. Michele de Lucca-Lowrey
    Michele de Lucca-Lowrey Junior Member
    39
    FL
    I have a 2012 bought in 2013 Prius v (lowercase v for the Prius v wagon) wagon that drivers side lock would work then not work with fob and now, I have to manually lock it and then all will lock electronically. When opening, all unlock except the drivers side..I have to reach in to manually unlock it. Seems kinda soon that problems like this and only ne door...again the drivers as others have had here the problem on older models.
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    734
    Boulder Hybids, Boulder, CO
    How many miles on the Prius v (lowercase v for the Prius v wagon)? Door actuators don't often fail until the car is well over 100k miles. Perhaps door glass was changed and whoever did it didn't put door back together correctly?
  3. Michele de Lucca-Lowrey
    39
    FL
    70k not 100k yet No window problems or replacement there.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Things fail. Not an expensive fix in any case. If that's the biggest repair in 70K miles, you're ahead of the game.
  5. Michele de Lucca-Lowrey
    39
    FL
    It is the actuator so wondering where the best rice for one is?
    Verdict....It is the actuator so wondering where the best price for one is?
