Help, driver's side window will not work!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jtk51, Jul 8, 2012.
  1. jtk51
    jtk51 New Member
    Hi all,
    I replaced my auxiliary battery yesterday and everything was working fine. This morning my driver side window will not close back up. All the other windows are working fine. Any help? I drive a 2008 Prius btw with roughly 50000 miles
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Roll the window halfway down, then roll it up and hold the switch in the up position for a couple seconds. This resets the auto down/up feature.
  3. jtk51
    jtk51 New Member
    The window is already all the way down and is unresponsive to the power switch
  4. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    Try disconnecting the 12v, then reconnect, make the car Ready (requires two power button pushes), hold the switch down for a couple seconds, then hold the switch up. If it rolls up, keep holding it for two seconds after it seats to the weather stripping.
    If there is still no response, then that would be interesting.
  5. jtk51
    jtk51 New Member
    I just disconnected the ground wire for teh 12v battery and reconnected it. Turned it on and driver side window power switch is still unresponsive. Does it have something to do with a blown fuse? Where would the fuse be on the fuse box?
  6. ws309
    ws309 Junior Member
    22
    ventura
    i too have this problem except only the drivers window works
  7. hill
    8,986
    I take it all your warranties expired. Going on that, consider the fact that the actual window switches DO fail. It happened to us. It was the rear passenger one, in our case. Consider your self lucky. The service tech's will 1st check the main driver's door switch. Only after finding THAT switch ok, will they move on the the window in question . . . . thus, we got charged for TWO 'inspections'. Yours will only require opening up the drivers door for inspection/repair. Although our warranty covered the cost of the switch and its replacement, we had to pony up for the cost of the 'inspection'. (grrrr....) My switch blew during an aux battery swap out too.
  8. ws309
    ws309 Junior Member
    22
    ventura
  9. ws309
    ws309 Junior Member
    22
    ventura
