help? DTC C1256 Code
Discussion in 'Gen 2 Prius Technical Discussion' started by 2009 Rebuilt title Prius, Oct 23, 2019.
  1. 2009 Rebuilt title Prius
    2009 Rebuilt title Prius Junior Member
    Renton
    52,863
    welcome!
    sounds like you need a new brake actuator
  3. 2009 Rebuilt title Prius
    Renton
    Thank you! I appreciate it.
    how much do those run by? also where could I get one for cheap or cheap labor?
  4. 2009 Rebuilt title Prius
    Renton
    SFO likes this.
  5. bisco
    52,863
    they are around $2,500. at a dealer. some people have been able to find a local mech who will install a salvage unit for around $500. iirc.
  6. bisco
    52,863
    are there any symptoms?
  7. ChapmanF
    19,038
    While you're admiring all the digits after that dollar sign, do think on following that workup procedure from SFO before you decide for sure that part is what you need.
    SFO and 2009 Rebuilt title Prius like this.
  8. 2009 Rebuilt title Prius
    Renton
    wow that's basically a car but thanks for the info. It seems to be working fine though because did a scan because curious and recently bought it for 6k which was down the drain probably with this problem.
    I don't really know the symptoms other then after driving it for 5 to 10 minutes and hitting a stop light or sign it starts revving up and down for a minute and I put it in neutral to stop it and the drive like normal in the morning.
    #9 2009 Rebuilt title Prius, Oct 25, 2019
  9. 2009 Rebuilt title Prius
    Renton
    that's true and the dealership told me a diagnosis would be $160 just to find out what's wrong and nothing else so I posted on here to see what's the diagnosis and save a dollar.
  10. ChapmanF
    19,038
    Well, if you hadn't already posted the trouble code, that would be the first order of business, but you've already done that. SFO then posted the workup instructions for that code, which tell somebody how to find out whether the code was set because of an actuator problem or an ECU problem. That could help with deciding what to try to buy.
    Both parts are probably available on the salvage market for considerably less than new ones.
    SFO likes this.
  11. 2009 Rebuilt title Prius
    Renton
    Thanks, if it ever comes to it, I'll head to the junk yard in hopes of swapping out for a good one.
  12. ChapmanF
    19,038
    Have you been talked into figuring out what's broken before buying a replacement yet?
  13. tidesofthesky
    tidesofthesky Member
    61
    49
    Salem, OR
    I replaced my brake actuator with one I pulled from the scrap yard for $75. It's a fairly involved process. And then the brakes need to be bled with the techstream software afterwards. Totally doable diy project, but it is somewhat challenging if I remember correctly.
    Make sure to walk through the steps to diagnose the problem before taking any action. I bought my car with the issue and it had the red triangle on the dash with a slew of other lights as well and wasn't happy that I was driving it. So yours may progress in that direction if that is in fact the issue.
    SFO likes this.
  14. 2009 Rebuilt title Prius
    Renton
    I did a diagnostic with the Toyota dealership and they told me that the brake computer system has a current code (meaning can't be deleted) active and that the system didn't like how it braked in one put of it's lifetime and maybe need a replacement in the near future once it dies.
  15. 2009 Rebuilt title Prius
    Renton
    The car is working fine now but the Toyota dealership said it was a tickling time bomb and would probably end up like your car with the lights.
  16. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    If you paid the dealership for a diagnostic, that would include them attaching an OBD2 scanner to scan the vehicle for any stored codes (DTCs) in the ECUs, could you please post all of the retrieved codes in this thread.
    tidesofthesky and Raytheeagle like this.
  17. 2009 Rebuilt title Prius
    Renton
    I'll give them a call tomorrow morning
  18. 2009 Rebuilt title Prius
    Renton
    I contacted them and they stated the only code being C1256 and that the problem be addressed... not much help there from the call.
  19. ChapmanF
    19,038
    Ok, so they're too busy with work they'd rather do than follow their own diagnostic steps in their own manual.
    Fortunately SFO posted those steps earlier.
    If you had a laptop with Techstream it could do the step 2 of testing (read the accumulator pressure sensor). The rest you can do with a multimeter.
    The name of the game (as you can see from the outcomes of those steps) is "decide whether to replace the actuator or the ECU".
