HELP!Engine Problem @23k
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PriusMeg, Jan 11, 2020.
  1. PriusMeg
    PriusMeg New Member
    South Florida
    2016 Prius v wagon
    I
    Newbie here- I'm so upset- my first brand new car- original owner, done all maintenance (at dealership) to a T. Went out of town for 10 days- upon returning and starting my car there was a very loud rattle that sounded like a reindeer was trying to climb out of the engine (clacking clattering type loud rattle) it lasted about 10 seconds. Was in a rush to get somewhere and when it stopped I proceeded to drive. Fast forward about a week later was driving in stop n go traffic and felt a mild shuttering/shaking in engine. Took to dealership to have checked- "no problems no codes". Now one more week later and the shaking is very noticeable especially at a cold start. Also- should note that when I take my foot off the accelerator I feel the car doing a tiny jolt as it goes into battery mode- definitely was not this harsh before . i brought a brand new car so I wouldn't have to worry about this type of things- I don't have time to deal with this. I don't feel safe in this car. I have extended warranty and I am reading that the coverage is voided if I continue driving the car when problem persists- but if Toyota is saying it's "all good" and I keep driving it I'm worried warranty won't cover whatever is wrong with this. As a woman, this dealership naturally just treats me like I'm being picky and crazy and there's nothing wrong. The shaking is very obvious and definitely not coming from the tires. If anyone could please share similar experience??? This car only has 26k miles!!!!
    amos likes this.
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Your Prius v is mechanically probably more like a Gen 3 Prius hatchback than a Gen 4. In other words, they didn't update the 2016 "v" cars when they did the 2016 hatchback. There's quite a bit of discussion about engine rattle upon cold starting in that section. I'd refer you to the Gen 3 section...haven't seen any discussion of engine rattle in Gen 4 (yet!)
    amos likes this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Did it sound like this?
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    If this is a brand new car, I would take it to the dealer for a complete inspection. Your situation doesn't sound good and your car is still under warranty.
  5. Classic Car Guy
    Classic Car Guy Active Member
    502
    135
    Northwest, USA
    I agree. Id go straight back to the dealer. That's the easiest, the safest and the right way to do it. You touch anything with the car it might conflict the warranty.
    Montgomery and PriusMeg like this.
  6. Mendel Leisk
    42,345
    Try to video the behavior if possible, if it's an intermittent thing, so you've got some proof, and something to show them. If you've got another dealership nearby, maybe try them too. Seems like you have two problems:
    1. Engine shaking. At 23/26K miles, it is very early, for EGR clogging, which is often the culprit.
    2. A dealership that doesn't want to know.
  7. PriusMeg
    PriusMeg New Member
    South Florida
    2016 Prius v wagon
    I
    No- not like that- less like a tractor sound - less repetitive more like a tumbling uneven clacking sound - I thought Toyota’s were supposed to be good- after browsing around on this forum I may have changed my minds on that. I'm wondering if lemon law would help me on this- this car has had issues from the get go- mostly cosmetic- now this!!! Still very upset
  8. bisco
    52,849
    is it the prius v wagon?
    PriusMeg likes this.
  9. PriusMeg
    PriusMeg New Member
    South Florida
    2016 Prius v wagon
    I
    Yes - it the base model Prius V 2016
  10. PriusMeg
    PriusMeg New Member
    South Florida
    2016 Prius v wagon
    I
    At dealership again - they are telling me there's nothing wrong with the car (can't replicate the problem) and now paying $150 diagnostic fee for them to "check further"
  11. JC91006
    16,936
    8,647
    I only have this problem whenever I start the car to move it in and out of the garage. When the engine doesn't warm up to temperature, it will cause this knocking when I start the car next time. So now I make sure I run the car around the block before turning it off
  12. bisco
    52,849
    is this the first time it's happened in 3 years?
  13. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    You better check up on the criteria for using the lemon law, you have a long way to go before it applies.
  14. PriusMeg
    PriusMeg New Member
    South Florida
    2016 Prius v wagon
    I
    Yes- well, it's been acting weird for about a month off and on depending on the temp outside.
  15. PriusMeg
    PriusMeg New Member
    South Florida
    2016 Prius v wagon
    I
    They told me the same thing again today- there's nothing wrong with it "can't replicate problem and no codes" after happily taking $150
  16. Mendel Leisk
    42,345
    Goes without saying keep all the bills, a log, and try to video the phenomena whenever you get the chance. Consider sounding out another dealership? Wouldn't hurt to talk to another place.
    dig4dirt likes this.
  17. Classic Car Guy
    502
    135
    Northwest, USA
    Wow. I don't know if the car is becoming the nightmare or the dealer.. "Phantasm"
  18. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    @PriusMeg
    Did you happen to see this post?
    Do you ever start your car and shut it off while the gas engine is running?
    Like musical cars maybe in your driveway?
    This is a very common problem with your engine, so if you can definitely say that above is not happening,
    then your problem is only common with much higher miles then you have....like closer to 100k miles or higher
    Raytheeagle likes this.
  19. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Meanwhile, ditch that dealer.
    Montgomery and Raytheeagle like this.
  20. amos
    amos Active Member
    376
    285
    los angeles
    Even f its a gen 3, its only 23k not supposed to have any ratlling noise nor egr issues.
