Help finding accessories
Discussion in 'Gen 4 Prius Main Forum' started by Smaug1, Aug 6, 2018.
  1. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I'm looking for a couple accessories and I can't seem to find them through toyota.com. (USA website)
    One is the privacy cover for the hatch, so people can't see what's in the trunk.
    The other is the little rubber corners that go in the hatch to keep things from sliding around. (espeically boxes)
    My mom's 2016 Prius has these, and I think they're Toyota parts, but I didn't see any reference to them when I was buying mine.
    Thanks!
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
  3. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I just checked now; thanks for the reference. However, the accessories I'm looking for aren't there. I'm a bit surprised that the trunk cover at least, is not a factory option...
  4. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The privacy cover came with my 2016 as standard. It was hidden in a relatively small black cloth envelope in the trunk and unfolds for installation (four loops that attach to 6 plastic "Ts"; two near the rear seat back, two on the hatch lid and two on the lower rear of the car.
    JeffD
    Smaug1 and pilotgrrl like this.
  5. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    My 2016 Three w/ATP came with the soft tonneau cover. I believe the higher trims came with the hard tonneau covers.
    Smaug1 likes this.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    Starting in the middle of 2017 they removed the cover and hardware from the Two Eco. As far as I know, the Two still comes with the flexible cargo cover.
    That means there is no Toyota cover for the Two Eco, if that is the trim you have.
  7. Prodigyplace
    12,712
    11,848
    Central Virginia
    It is standard on all trims except the Two Eco.
    If you have a Two like your profile says, it should have come standard with a flexible cargo cover in a storage bag. There should be 2 hooks behind the rear seat to fasten the cover. The Two Eco has different trim without these or the other mounting hardware..
  8. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I have a regular Two. Didn't come with it. I'll ask the stealership when I go back to get my sunglasses.
  9. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    That's stupid.
  10. Prodigyplace
    12,712
    11,848
    Central Virginia
    They removed it mid-2017 when they added some safety features. I would not expect there was much weight savings deleting the cover & hardware.
  11. alanclarkeau
    7,045
    7,593
    This is where my boot/hatch cover was stored when I first saw the car.
    I wouldn't worry about using it - it's pretty hopeless. Mine has been in the wardrobe almost 2 years - I'll put it back in 12 months if I change cars.
    20160805_171018_resized.jpg 20160805_171203_resized.jpg 20160805_171038_resized.jpg 20160805_171059_resized.jpg
    Smaug1 likes this.
  12. alanclarkeau
    7,045
    7,593
    These solid covers are much better - but not offered on PRIUS. It's offered on the budget Corolla and Yaris, but only a poor version on PRIUS which is a much more expensive car.
    Smaug1 likes this.
  13. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Might be time to hit up the aftermarket via FeeBay.
  14. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I found the cheap cargo area cover. The porter suck it under the all weather hatchback cover. He also didn't bother to put on the all weather parts that Velcro to the back of the back seats.
    That's one less thing to buy. Thanks for the reminder to check there!
    Prodigyplace likes this.
  15. Prodigyplace
    12,712
    11,848
    Central Virginia
    There are also all weather parts that Velcro to the areas between the rear seats and the cargo floor.
    Smaug1 likes this.
