Help! Front 12 Volt outlet not working
Discussion in 'Gen 2 Prius Audio and Electronics' started by Rick Grahn, Jun 25, 2008.
  1. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    T,
    I asked the dealer that specific question since I have had my dash apart at least 2 dozen times. He said that it is very difficult to find and to reach. I told him of my experience with the dash work and he suggested that the service tech do it. I have taken my cars (two Toyotas) there as needed since I got them and they've always been truthful about that type of thing in the past...even giving me basic DIY instructions. He said it is often the first one to trip (figures!) when there is too much draw on the circuit. Interesting that a 15A fuse blew before either of the 7.5A fuses, but he thought that it may be the "first in line."
    Warrantee? Good question. My mileage is well over 100,000 miles so it didn't come up as an issue. Sorry I can't help you there.
  2. texdon
    texdon New Member
    26
    central Texas
    Thanks Rick, I'll let you, and others, know if it is covered under the warranty.
  3. texdon
    texdon New Member
    26
    central Texas
    Good news, bad news. After driving 63 miles to my closest Toyota dealership and waiting 2 hours (that's the bad news) it turned out that the front outlet was never plugged in and it was covered by warranty (good news). '08 - 700 miles.
  4. DougSlug
    DougSlug Member
    124
    Trenton, NJ
    Rick,
    Don't know if you are still monitoring this thread (I've been traveling and forgot to keep up with it), but...
    Do you happen to know the name of the fuse that blew? I would like to go back to the wiring diagrams and understand what happened, especially if this is not that uncommon a situation.
    Thanks,
    Doug
    2004priusgal likes this.
  5. Rick Grahn
    285
    Illinois
    Doug,
    Sorry, I have been away for a while. I do not know the name of the fuse. The paperwork does not specify. The tech said that it is deep in the dash and hard to get to.
    Sorry I could not be of further help.
    Rick
  6. jdchappie
    jdchappie JD on RR2
    78
    Southeast Kansas
    Has anyone found the location of the fuse referenced in this post ?
    $50.00 to change a fuse !!!
    It seems Toyota should provide the information or move the fuse.
  7. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
    Using my 2004 wiring diagrams (pages 66, 68, 314, 370, & M17) and back tracking FROM the outlet:
    Fr outlet > Pwr Outlet Relay (POR) , pin 3 > POR, pin 5 > 15A Pwr Outlet FR fuse > Junction Block and Wire Harness Connector connection 1B1 > Engine Room Junction Block (ERJB ) 3D1 > 100A DC/DC fusible link > ERJB 3M1 > Fusible Link Block F15(A) > 120A Main fusible link > Battery
    I don't see a "mysterious" 15A fuse; I think the Stealer was lying.
    2004priusgal and DLC82SV like this.
  8. cameljok
    cameljok New Member
    Arizona
    Hey Rick,
    I just had the exact same thing happen to me today. The power outlet went dead and I heard the pop so I knew it was an internal fuse. I checked position 19 and 21. What is odd is that position 21 didn't have a fuse but 19 did. I replaced the fuse and added the missing fuse but no luck.
    Did you find out exactly how deep in the dash is the fuse panel? I just bought the car from CarMax a few days ago so I figured I would take it to them to fix but if I can provide more data then I can prevent them from tearing apart the car trying to figure it out.
    Thanks,
    Bob
  9. nmobix
    nmobix Junior Member
    Hey Rick
    I know this thread is old, but I have the exact same problem that you had. I just checked the fuses in the driver's left knee and those outside in the hood. Everything is fine, however I have power only at the center console :(( Where was this MYSTICAL fuse located (the one that Toyota Dealer changed for you)?
    I hope to hear from you soon.
    Regards Kleves
  10. Ken Wright
    Ken Wright New Member
  11. Ken Wright
    Still a good thread even though it started in 2008. I have a 2009 Prius with the same problem and I was unable to get both working until I replaced both fuses and it MADE me do it in the correct order to work. What finally worked was to replace the console fuse first, make sure it is working, then replace the front fuse. Both are located under the driver's side left knee fuse box. Worked for me. I also asked my neighbor -a prius mechanic- about the mystery fuse, he said he dosen't know what that would be. He thought that dealer may be avoiding telling you about a simple fix like the outlet power wire becoming loose and being unplugged. Let me know if this helps anyone.[/quote]
  12. hiljak
    hiljak Junior Member
    23
    cincinnati
    there is no "mystery" fuse deep in the dash. That's just a plain lie. There is, however, a fusible link on the outlet itself. Troubleshoot the power outlet in this order:
    1. fuses 19 and 21 (check with an ohm meter while in place).
    2. pull the panel that holds the outlet, unplug it and check for 12v at the wire connector for the outlet (with power in vehicle "on", obviously). If power at the wire, the outlet itself is bad. I do not recommend repairing the outlet, just replace it.
    3. If no power at wire connector, wire between fuse and outlet connector bad/burnt/comprimised.
    cheers
  13. fasteddie
    fasteddie New Member
    Colorado
    I have the same issue. I pulled the panel that holds the outlet, unpluged the outlet and have power at the wire connector. I have determined that it is the outlet. Now I am trying to determine how to remove the outlet. Also, do I have to get a new outlet from Toyota or is there an aftermarket one that will work?
  14. Appreciative
    Appreciative New Member
    Thanks hijack. We had the same problem with our 07 Prius . I finally realized through al these posts that there were actually 3 different power outlet fuses. I checked and changes 21 and 12 but didn't realize 19 was also needing a fuse. 19 was for the console outlet that was the last to go. Anyway once I also noticed that 19 was possibly involved I change it and both outlets worked. I'm not sure how I missed it but these posts, especially hijacks alerted me to it. Thanks!!!
  15. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
    Both not working in my 04, but manual only has fuse #12??
    i will check... were all these fuses each mini white 25a?
  16. 2004priusgal
    76
    new jersey
    Upgrade
    Both power outlets not working in my 04, but manual only has fuse #12?? and its ok.
    i will check again 19, 21... were all these fuses each mini white 25a? as my #12 is. ? thanks
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,099
    6,966
    Texas Hill Country
    This is the basic circuit. There are three fuses and two relays not counting the fuse box 100 amp feed that supplies many other things as well. The ACC relay and 25 amp fuse can disable both outlets. Grounds for this circuit are also important but are not typically the problem.
  18. ugotkevin
    ugotkevin New Member
    Kansas City
    Same issue as many here. Fuses are fine, power outlet in the arm rest is fine but no voltage at the power outlet next to the glove box. This was my problem/solution:
    • Pull off the lower plastic trim piece under the glove box
    • Look behind the power outlet. Mine had become unplugged. Plug it back in. 20230925_100401.jpg 20230925_100300.jpg 20230925_100228.jpg
