Help! Getting codes for Generator Inverter Performance & Inverter "A" Cooling System Performance
Discussion in 'Gen 3 Prius Main Forum' started by Seth Holloway, Dec 19, 2023.
  1. Seth Holloway
    Seth Holloway Junior Member
    24
    Bessemer, AL
    Ok first let me say thanks so much for any and all the help that anyone provides. I live with and take care of my 89 year old mom and this is the only reliable car we have.
    I have a 2012 Prius with 154,000 miles on it. Been a really great car, have replaced the hybrid battery and had spark plugs and that whole housing replaced along with the manifold. Those are the two biggest repairs.
    Now the current problem. Lately I have been getting the temperature symbol on the dash, when running on the interstate. It would come on and then go away. I check the fluid level and it was low so I filled it up. Then recently as it got cold and started running the heat. I started to getting a sound on the inside behind the center console of rushing water. And the heater would work on and off.
    Then yesterday, I was driving it and I was stopped, when I went to put on the gas the electric engine didn’t kick on and I got the triangle of death, check engine light and hybrid engine failure drive to a safe place. So I pulled into a parking lot. I have Carista OBD on the car. So the first thing I did was check the codes and got which I didn’t know exactly what it was. I did a little research sitting in the parking lot.
    Basic OBD2:
    P0A7A (Permanent) - Generator Inverter Performance
    P0A93 (Permanent) - Inverter "A" Cooling System Performance
    P0A94 (Permanent) (Pending) (Confirmed) - DC/DC Converter Performance
    P0C3A (Pending) (Confirmed) - DC/DC Converter Temperature Sensor "A" Low
    P0C3F (Pending) (Confirmed) - DC/DC Converter Temperature Sensor "B" Low
    Hybrid engine:
    P0A94 - DC/DC Converter Performance
    P0C3A - DC/DC Converter Temperature Sensor "A" Low
    P0C3F - DC/DC Converter Temperature Sensor "B" Low
    ABS:
    C1259 - Manufacturer-specific code
    (tap to search)
    C1310 - Manufacturer-specific code
    (tap to search).
    I kept resetting the codes but they just kept popping right back up. I drove the car to auto parts store to get things checked out. When I drove it, it wouldn’t engage the electric engine but ran on the gas engine. At the auto parts store the first reaction I get of course a Prius what is that ??? So I knew I was out of luck. I did have them check the 12 volt battery and they said it was fine, but I am not sure because the guy didn’t seem like he new what he was doing. I didn’t ask them to check the codes because I knew they wouldn’t do it right and it was getting dark and I had my 89 year old mom with me. So my next thought was to take the leads of the 12 volt to see if it will reset things. And of course that didn’t work. I then noticed the engine reservoir coolant was low so I bought some fluid and added it. That didn’t fix things. So I drove it home so I could get my mom home. Then started to doing research and found out about the inverter system cooling going bad and how to check that. So this is where I am this morning. I am about to check that pump and the inverter cooling, also look around to see if I can see anything in the daylight. Below is a copy of all the OBD readings along with pictures. Any thoughts, ideas or advice of things I need to check or look for that might be causing the problem. Thanks so much, I need to get this back up and running so I can get my mom to doctors appointments and run errands.
    Freeze frame :
    Calculated load: 29 %
    Coolant temperature: 76 °C
    Intake manifold pressure: 28 kPa
    Engine rpm: 992 RPM
    Vehicle speed: 0 km/h
    Intake air temperature: 47 °C
    Absolute throttle position: 16 %
    Time since engine start: 179 sec.
    Number of warm-ups since diagnostic trouble code cleared: 0
    Distance driven since diagnostic trouble code cleared: 0 km
    Ambient air pressure: 99 kPa
    Battery voltage as seen by the engine ECU: 14.57 V
    Outside temperature: 11 °C
    Absolute throttle position D: 16 %
    Absolute throttle position E: 32 %
    Time run by the engine since diagnostic trouble code (DTC) cleared: 0 min
    Remaining live of hybrid battery pack: 51 %
    Basic OBD2:
    Hybrid engine:
    ABS:
    (tap to search)
    (tap to search)
  2. ChapmanF
    19,027
    Never mind the C1259 and C1310 from the brake ECU; those are just the brake ECU saying "I hear there are trouble codes for the hybrid system, go look at those."
    The other codes make me think the stuff in the inverter box probably got hot. The info that you copied from the freeze frame shows the engine coolant temperature; I bet if you scroll further down you will see inverter and MG temperatures also.
    Seth Holloway likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Check your inverter pump. Do you see coolant flowing in the reservoir?
    Autozone knows nothing about hybrid's. Doubtful they check the battery correctly.
    The inverter pump in under the inverter. You're have to revome the inverter to
    replace it. Not a hard job, just takes time. It's the only way to get to the bolts.
    I remember seeing a video several years that someone removed the drivers headlamp
    assembly and wheel well cover to get to it, but I can't find it adn don't know where
    I bookmarked it...
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Inverter reservoir is on top of the engine right middle. Flow looks like minor turbulence.
    Inverter itself could be bad and may qualify for free replacement from the dealer.
    This was for my Prius v but is same
  5. Seth Holloway
    24
    Bessemer, AL
    I saw that info on several other posts and the info about the class action lawsuit also. I put the car in mateince mode and inspected the fluid in the inverter and it did move or shake which I understand indicates the invverter pump might be out also.
  6. Seth Holloway
    24
    Bessemer, AL
    I forgot to mention I am going to be looking into the warranty fix in the morning.
  7. rjparker
    11,116
    6,974
    Texas Hill Country
    Do you mean it did not move or shake?
  8. Seth Holloway
    24
    Bessemer, AL
  9. Seth Holloway
    24
    Bessemer, AL
    update time, called Toyota Cooperate told them the situation with codes and Vin # and they said the car was part of the recall and would have probably been part of the ZE3 and ZJB programs but they had been closed and moved to customer confidence program 3TE002 & 23TE03. And I got a case #. Then I did some google research on those two programs andd found the info from Toyota about those two programs. Then I found out their was a class action lawsuit against Toyota over these same problems Remy McCarthy, et al., v. Toyota Motor Corp., et al.. Under the programs and lawsuit if you get certain codes Toyota will fix the inverter and pay for the tow and a rental. I had Toyota customer care call the two local dealers and one said I would have to pay for a tow and the other never returned my call. So I contacted another Toyota dealer about 30 minutes away in another town and they took the case number, my VIN the program numbers, and said yes you are covered, I asked is towing and rental covered and they said yes. So I had it towedd down their yesterday, bonus they put me in a 2023 Prius Prime for the rental. They called me this morning and said that the 12 volt battery wasn't holding a charge and it needed to be replaced and would be 273.00 before they could do anything with it. At the time the car went down and I had it at home running codes and trying to diagnoise the problem myself the 12 volt battery was fine, but because of the holiday the car had to sit for 5 days and when I went out to have it towed yesterday the tow truck driver had to jump it of, we drove it got it on the flatbed towing truck got it to the dealer and it wouldn't crank again to get it off the flatbed we had to jump it again. Here is my question would the inverter problem cause damage to the 12 volt ??? Or was it because it sat for 5 days and turned real cold that would cause the battery to not hold a charge ??
  10. ChapmanF
    19,027
    You had P0A94, so the 12 volt battery wasn't getting charged at all (except when you jumped it) and it was powering the car while you had it turned on.
    Brian1954 likes this.
  11. rjparker
    11,116
    6,974
    Texas Hill Country
    12v battery was on life support which can work if run every day or two. They should have attempted to charge and load test the old battery. Now you have another 6-8 years on a new oem 12v battery.
    A friend bought a new battery in Aug, used the car a few times until mid September and now the battery is ruined from just sitting there with normal parasitic draw.
    #11 rjparker, Dec 29, 2023
  12. Seth Holloway
    24
    Bessemer, AL
    They did load test it and it wouldn't hold a charge, sorry thought I said this
  13. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    Did they charge it before load testing it? Probably not, based on the fact that I constantly hear that the dealers begin repairs by replacing the 12 volt battery.
    My friend's daughter took her Prius to the Toyota dealer because of a weak 12 volt battery. That Prius sat for so long that one cell reversed polarity in the hybrid battery, which was reconditioned in 2020.
    That 12v battery was purchased 4 years ago with a 7 year warranty sticker on it.
    The dealer said that the battery has only 1 year warranty. After a short conversation the warranty increased to 2 years. The dealer ended up putting in a new battery for $200 and $50 for labor. For new batteries, where there is no longer a 7-year warranty sticker, the warranty is now 1 year, as the dealer told me.
    How does the 7-year warranty work on older type batteries? I know they lasted for a long time. The battery installed in 2013 failed in 2021.
    In winter time, I start my Priuses once a week or every 2 weeks for a half an hour, then I charge the hybrid battery to 6 full bars and leave it sit there.
    #13 Carall, Dec 29, 2023
  14. ASRDogman
    8,066
    4,089
    1/2 hour is not enough to charge the 12v battery. You need a battery tender.
    It keep a trickle charge on the battery after it's fully charge.
    My new battery has a 7 year warranty on it. Maybe that is a new thing they are doing.
    Walfart has 1 year batteries.
