help: going on trip,what's correct tire pressure????
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 12, 2011.
  1. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    HELP:
    Going from Florida to Vermont in the morning.:rockon:
    1] What is the correct front & rear tire pressure for interstate speeds 75+ MPH?
    2] What is the correct front & rear tire pressure for driving in the snow?
    `Thanks for any info.
  2. Redsnake
    Redsnake Can drive anywhere
    22
    Highlands Ranch, CO
    Referencing from other posts.... 42 Front and 40 Rear (cold) has been the popular recommendations. Check sidewall for max tire psi. Usually its 44 max.
  3. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    There is no "correct" pressure, many here use 42 front, 40 rear.
    I have used 44 front and rear for the last 2.5 years and I still have tread in my original tires, after 42000 miles starting from April '07.
    If you want more comfort, then you lower your psi and sacrifice mpg and tread ware.
  4. ski.dive
    959
    241
    What about tire pressure for the snow,any different? :confused:
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I use 40 front and 38 rear, but if you are going from a relatively warm climate to a cold one I'd put in 42 front and 40 rear. They will drop when you travel to a colder area.
    For snow, you want the same pressure, that is, lots of air in the tires. The tread will clear better.
    For sand, it's low pressure, for flotation.
    Just make sure you have proper tires for snow. The rubber should feel soft and have lots of siping.
  6. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Same pressure will work fine. Low pressure is not the best for snow. Small foot print is good. Lbs. per inch. gives better traction. H
