Help - got red triangle after briefly shorting 12v battery. Car starts. Advise?
Discussion in 'Gen 2 Prius Technical Discussion' started by SFGiant-and-Plugin-Fan, Mar 20, 2011.
  1. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    Anyone know what could be causing my red traingle, (!) and VSC lights to display? It happened after I briefly, accidently shorted the 12v battery against the frame. Is it safe to drive?
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Was your Prius in "Ready"" mode when the short occurred? If so you may have blown the fuse from the inverter battery charging circuit and driving your car is not advised as the little 12v battery will quickly run down.
    JeffD
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
  4. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    Thanks, I got a similar response to my post on the maintenance thread from Patrick Wong. I think I have an old low battery. Shorting may have just kicked it over the edge.
