Help! Harness needed if you are parting out a Plug in Prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ericbecky, May 21, 2026.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Help!
    I need to buy a specific section of wire harness from a Plug-in Prius (2012-2015).
    If you are parting out a Plug-in Prius, you may have this laying in the back. Or possibly still attached to the battery case or charge controller?
    Call or message me to discuss. 608-729-4082. I'm in Wisconsin.
    I'd prefer as much of the harness as possible. But we can sort that out.
    I took off the wire loom of one section, and had to repair/tape up a different section, so mine may look slightly different than yours.
    James Analytic likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    I just gave Jack a heads-up about this... Maybe he'll have something or know where to search?
  3. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I talked with him yesterday. He doesn't have what I need. But will ping me if something comes on his radar. He had some good advice as well.
    PriusCamper likes this.
  4. PriusCamper
    13,452
    5,430
    These first plugin Prius are very rare... I wish @bisco had sold his to me!
  5. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    With it being rare it can be a pain to find certain PIP-only parts.
    It's hard to filter through all the regular ads just to find the Plugin parts.
    Practicing my skills on a similar connector.
  6. PriusCamper
    13,452
    5,430
    I'm surprised no one has designed a universal plug where you stack the number of wires you need together to form the correct shaped plug. Suspect 3D printer owners have experimented with printing their own plugs... Of course in general making a specific shaped plug is super expensive when it comes to building the tooling to make the plastic pieces. For example it cost ACENbay.com more that $10K to have tolling made so he could manufacture his own voltage sensing harness that plugs into the ECM.
  7. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I bit the bullet and bought an entire harness New from Toyota. Under $1,000. Worth it for peace of mind long term. This car only has 53,000 miles on it.
    It has about 30 connections throughout the car. Second pic shows the harness laid out on my floor. The section that was most damaged circled in RED.
    #7 ericbecky, May 30, 2026
    James Analytic and bisco like this.
  8. bisco
    52,839
    that's something you hope isn't defective out of the box :eek:
    ericbecky likes this.
  9. James Analytic
    411
    63
    Michigan
    Was the actual connector pins corrosion the cause or somewhere else in the wiring? Great info in general.
    Also, do you by chance happen to have a confirmed source or know confidently what the out of specification ranges for Blocks, Bricks, etc. are that throw these related codes?
    Like upper and lower Cell, Block, Brick like based on DrPrius readings? I only have a reliable DrPrius and AutelMAXAP200 app to read live data from. Looks like all 56 cells have sense wires.
    From Jacks videos as well as my observations, appears that there is always a Delta SOC % above 0 and 5% Delta SOC is the max. I'm not certain regarding the Volt Diff and other metrics I can't see.
  10. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    It was corrosion at the pins.
    I don't know the specs ranges for throwing codes on the PIP.
