HELP!! - I may have canceled my Blind Spot Monitoring
Discussion in 'Gen 4 Prius Main Forum' started by KimPrius3, Jul 9, 2016.
  1. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    I can't seem to locate my ON/OFF setting in the Settings screen for my Blind Spot Monitoring System. I believe I accidentally canceled it. Any help in rectifying this situation is most appreciated. I am a first time Prius owner.
    48,996
    are you sure there's not a button on the dash? that's where my wife's hycam is.
  3. Jim in NC
    Jim in NC Active Member
    217
    266
    28
    Myrtle Beach, SC
    It is in the vehicle settings screen in the upper display of your Prius (not the one in the NAV screen).
    I haven't played with that setting since getting the car, but when my vehicle was delivered to me the setting was OFF. I had to turn it ON in that screen.
  4. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Mine was on when I purchased the car. The Blind Spot Monitoring was under the Settings icon on the upper screen, controlled by the buttons on the right side of the steering wheel. Now when I go to settings the BSM doesn't appear anymore. I looked in the Owners Manual and it says when turning the BSM ON/OFF to be careful not to cancel it. Why is canceling even an option if you can turn it on or off???
    Silver Pine Mica likes this.
  5. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Which page? I'm trying to find where it says that.
  6. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Page 139. "Make sure not to cancel the systems accidentally." By "systems" it means the Blind Spot Monitor and the Pre-Collision System if equipped.
  7. sttkailua
    sttkailua Active Member
    190
    150
    Hawaii
    KP4,
    If others don't have a solution, take it back to the dealer.
    It is still new, and under warranty.
    I don't even want to try to press some buttons, and be in the same
    Situation!
    Good luck, and let us know the solution.
    stt
  8. voerman
    voerman Junior Member
    NC
    Four Touring
    Kim,
    When you get to the settings screen, the one with the clock, meter customization and vehicle settings on it, just scroll down with the down arrow button. You will see many more settings. Note that there is a windows style vertical scroll bar on the right side of the screen showing you that there are more screens. I think BSM on/off is on the second or third screen.
    To clarify - do not enter vehicle settings, just scroll down (or up) from the main settings screen.
    Lou
    krmcg and KimPrius3 like this.
  9. bisco
    48,996
    i think by 'make sure not to cancel accidentally', they mean not to shut it off and wonder why it's not working. which is probably what's going on here.
    KimPrius3 likes this.
  10. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    OMG!! Thank you so much!! I feel like "DUH" since I just went out and did exactly what you said. I was in a bit of a panic, but today Lou . . . you're my HERO
    OMG!! Thank you so much!!! I feel like such a "DUH" since I just went out and did exactly like you said. I was in a bit of a panic, but today Lou . . . you are my HERO!! (y)
    sttkailua and bisco like this.
  11. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Do not fear, voerman is here. He posted what to do on here and was spot on. Made me feel a bit "DUH" as it is really easy to turn systems ON/OFF.
  12. voerman
    NC
    Four Touring
    Kim,
    You are welcome. I went through the same thing when I first got my car! :-( One of the keys to navigating the Toyota menu system is noticing that vertical scroll bar on the right side of the screen.
    Lou
  13. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    That won't be my problem - "VEHICLE SETTINGS" has disappeared from my scroll list!! I'm back to the salesman (who is a mechanic too).
  14. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Lou
    I read something on here about using the key fob to change which door(s) will open. Currently the drivers side door handle only unlocks the driver's side. The passenger side door opens all doors and hatch. Someone said you could use the fob to change which doors open. Since I live in the country, I would prefer to have the driver and passenger door handle open all doors and hatch. I guess I'll do a search for this info. Thanks again.
    ~Ki
  15. alanclarkeau
    7,041
    7,580
    Yours seems to be the way it's done in USA - but mine is the opposite, driver's door unlocks all doors. And I'd like it the way yours is. It seems I need the dealer to change it. Mine only has unlock from driver's side too, but that's because it's our base model.
    I've tried all the tricks, one of which is to unlock the car, then hold the unlock and lock buttons on the "fob" together for 6 seconds, and if it beeps, you've swapped it to the other mode. But it didn't do anything for mine, though - maybe I need to hold the "fob" upside down seeing I'm "downunder"?
    krmcg likes this.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Did you remember to stand on one leg ?
    alanclarkeau likes this.
  17. bjmacke
    bjmacke New Member
    Oakdale, MN
    This is pure conjecture, but Australia's driver's side is our passenger side. If you enable the option it might apply to your passenger side door.
  18. wrprice
    415
    308
    Houston, TX
    Four Touring
    If his basic model only comes with one-door SKS, then that door will understandably be the driver door regardless of which side of the car that is. The function only modifies the behavior of the driver door (whether it also unlocks other doors or not).
    For cars with three-door SKS, the passenger and hatch door handle sensors always unlock all doors.
  19. Tideland Prius
    16,073
    By default, if you hold the driver's door for 2 seconds after it unlocks the driver's door, it'll also open all doors. However, I found it clunky and it doesn't seem to work reliably.
    Without fishing out the manual, are you able to hold both the LOCK and the PANIC button on the remote? If you hold them both simultaneously for a few seconds, it will change the lock sequence (based on the number of flashes of the red light on the key fob). The second option is "Global unlocking" which is the setting you want (there are 3 in total so if you want to revert to default, you'll have to perform this action twice more)
  20. voerman
    NC
    Four Touring
    Kim,
    I have not tried the key fob thing. I used Carista to change those settings in my car.
    Lou
