Help, I missed this when I took delivery
Discussion in 'Gen 3 Prius Main Forum' started by krazypriuslady, Apr 8, 2012.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    It seems like there would be an obvious scuff nearby for a crack like that to happen. However there is no way to prove that it happened pre-delivery. If the dealership offers to patch and paint for free, I think that would be more than fair. A new bumper is not likely to happen but you never know.
  2. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    I bet the dealer will fix it. I found a crack in my wheel cover over a month after owning my car. Brought it to the local dealer (not the place I bought it), and they replaced it for free.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    A wheel cover is cheap. A brand new bumper, not so much. I wouldn't be surprised if they offer to do a partial repair though.
  4. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Hope it leads to a fix. Just butter them up by saying that you will definitely buy from them in the future and also refer others to them bc they really value your business by fixing it.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hmm...well it sounds like the dealership is willing to help you, "If" Toyota okays it.
    So now you are at the mercy of Toyota.
    But at least the dealership is trying to get Toyota to cover it.
    Let us know the outcome...good or bad.
  6. krazypriuslady
    232
    metro Wash DC
    Here it is:
    the service manager got a reply from Toyota- they will not warranty it because they thought it was due to an outside force. So far, all this was by email.
    I asked if I could still bring it in for inspection and they were very ok with it. So the service manager and body shop manager looked at it with me. Right away, they could see damage under the spoiler, where it must have scraped onto a curb or something and caused it to flex more than it could. They said it was a slight scrape, as the scrape didn't go very far back adn damage the next section (I forget the name). I had a hard time even seeing the scratch, even when they had their finger right next to it, but I could sort of feel a indentation.
    They said that if we fix it and get another scrape, it will crack again, so either leave it or replace the bumper.
    I am very happy with the dealer even though it's not fixed. I feel that they gave me VIP treatment on this- 2 service managers and the body shop manager all looked at the pics during the day and all came to the same conclusion. At least I know now that it wasn't a spontaneous crack or material failure.
    So we still don't know who caused it or if was prior to delivery, but it's mine now. No repair offered or recommended. Since this is a common issue, the assumption is that we caused it and may never have heard or felt it.
  7. WE0H
    WE0H Senior Member
    3,247
    528
    Unfortunately the Prius is so very easy to bump the lower bumpers as it sits very low. Every rental Prii I have driven has had a damaged bumper either front or back bumper from a scrape to trashed lower edge. I have never seen one cracked like yours however.
    Mike
  8. WE0H
    WE0H Senior Member
    3,247
    528
    If you can push the crack together and get it to hold with packing tape or something while you glue the backside with PL400 or some other heavy duty construction adhesive, you stand a chance of doing a self repair that will look decent.
    Mike
  9. krazypriuslady
    232
    metro Wash DC
    2 questions:
    wouldn't the packing tape pull up the clear coat or something
    and 2) do you have to remove the numper or put it on a lift to apply the adhesive?
    I'm going in next week for my 1000 mile inspection (dealer perk) and maybe I could get them to help me while it's on the lift....
  10. WE0H
    WE0H Senior Member
    3,247
    528
    The paint should adhere to the plastic bumper well enough for packing tape to be removed later once an adhesive cures. Otherwise come up with some clamping solution with suction cups and a homebrew wooden frame that holds the suction cups or something along that thought :p Anything you can come up with that will 100% close the crack then get under the front end and see what you need to do to apply a very strong adhesive to cover the now closed up crack and say an inch around it just in case there is some stressed plastic around the crack. You best rough up the plastic, on the backside of course :p so the adhesive has something to grab a hold of. Now back to the packing tape, if you go that route, when you remove it pull it slow and keep it flat against the bumper so you are not pulling straight out away from the bumper. That will put the least stress on the paint where it is cracked. Just go real slow and be careful. Warmed up with a hair dryer would make the tape adhesive relax if you want to try that. Just go slow and watch for paint lifting. If it lifts a slight bit, stop and find another way to pull the tape. Now once all is done & repaired, it would be best to take touch up paint and seal the paint crack to keep dust & moisture out.
    See how easy that repair is ;) You can do it in your garage. Lock down the E-Brake so the car can NOT move. Put the jack under the car and lift it enough to get under there. But before getting under the car, put something under the tire that will hold the car up in case the jack fails. You don't want to get skinny that way or there won't be a tomorrow to admire your repair :( Piece of cake :) Make sure you take pics for all of us to see.
    Mike
  11. krazypriuslady
    232
    metro Wash DC
    Seriously Mike???? :rolleyes:
    All I have is the hairdryer.. I guess the crack will live on
  12. The Electric Me
    9,083
    5,801
    Well I'm glad you are happy with the support you got from your dealer.
    When you described your situation I was afraid you were up against it. I held out some hope that perhaps it would simply work out.
    But on the positive side, it seems you established a good relationship with your dealer, and it also sounds like you are doing okay with the reality of the crack.
  13. WE0H
    WE0H Senior Member
    3,247
    528
    EZ, you can do it. One day. Start early Saturday morning and you'll have it done by dinner time. Leave the car sit over night so you don't put any stress on the curing adhesive and on Sunday morning you are set to pull the tape or whatever you used to close up the crack. Then get out the touch up paint and seal it up. Sunday afternoon the paint will be cured and you are all set to go cruise around town :p
    Mike
  14. krazypriuslady
    232
    metro Wash DC
    thanks- I look around and almost every car has bumper damage, no matter how expensive and well treated. life in the big city...
    so it was bound to happen, just hoped to have a longer honeymoon with a pristine car. it's liberating in a way. bring on the spilled drinks, muddy dog paws, door dings and chips. I almost don't care anymore.. (I'm still feeling sad about it and being extreme):eek:
    and thanks mike.. maybe one day.. but ]not likely.. :)
  15. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Maybe now, knowing the verdict, do you know a good body shop, or a gear head friend or an auto DIY, who might fix it inexpensively.
    The advice to jack up the car and get under it, ven with some protection is a bad idea if you are not 100% comfortable with it.
  16. Tideland Prius
    16,670
    I had that for my smart fortwo. I don't know if it covers cracks in the bumper but it does cover any wear & tear item and any trips to the dealer is covered (no labour charges) for the first year or 15,000km. Otherwise, it's under the 4yr/80,000km new car warranty.
  17. subjective
    subjective Member
    203
    30
    In transit,a scooter sent to me had a crack in the rear fender about the size of the one in your spoiler. I repaired it by applying Loctite repair epoxy putty on the inside which made it stronger than new. This will hold it together and not allow it to get worse This Loctite product is available at any ACE HARDWARE.
    2 people like this.
  18. krazypriuslady
    232
    metro Wash DC
    what scared me off what scuffing it up and putting it up on a jack, which I do not own and have never used. I don't really know any DIY guys. Most people around here are lucky to have a driveway, let alone a garage. Anyway, almost everyone I know is content to have shops do everything.
    I might just try some adhesive if I can reach my arm under there while it's parked.
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    After seeing how dangerously low it can get to parking blocks, I've trained myself to park the nose 2-3 feet from curbs/parking blocks. Suggest you do the same.
  20. krazypriuslady
    232
    metro Wash DC
    but then my "butt" sticks out!!
