Help...I need some advice with no start issue!
Discussion in 'Gen 2 Prius Main Forum' started by StephenJ, Aug 22, 2025.
  1. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Okay so this is a 2007 Prius and it won't start. It started out having misfires and the plugs and coils were replaced. Then it started just running for a few seconds and shutting off and not restarting until the car is turned off and back on. Now it just won't start the engine at all, it doesn't ever engage to try to crank. Also, I noticed that when I turn the car off and take the key out, the picture of a car on the bottom right of the combination meter is flashing, when I put the key in it goes away, but with key out it doesn't matter if alarm is set or not, it still flashes.
    Along with the plugs and coils I put a new 12v in it, the other one was probably okay but it got drained down just from working on the car, scanning it etc.
    It has codes P0A0F (engine failed to start) and P3190.
    One thing that is unusual is that a couple days ago I noticed it was showing 1 blinking bar on the fuel gauge, but then the next day it shows 4 bars on the fuel gauge. I was wondering if there is a wiring issue going to the fuel pump???
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    So apparently you don't know if you have had . Imed put 3 gal in . Let it stand a few minutes with the gallons in and now ready and floor it ? Engines cranking now or attempting to start?
  3. pasadena_commut
    pasadena_commut Senior Member
    3,038
    942
    Southern California
    As long as you are sure that there is at least 12V at the fuse box under the hood when the car is READY you are in the usual boat for any car that won't start: air, spark, fuel. From the description, the car is out of gas, or if there is gas, the fuel pump isn't working. The fuel gauge on this car is never particularly accurate and since this is a new car to you you don't know if it ever gives good information. The OP did not say what the SOC on the HV pack is. Be careful in this situation not to experiment all the charge out of the HV pack, because if that happens most likely it will need to be towed to a dealer just to charge the pack enough so that it can turn the engine over.
  4. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Yes, so after making the post I did add gas just to see. I added 5 gallons and it put it all the way to the top full mark, do I don't think it was out of gas....unless it's just always showing 3-4 bars higher than actual.
    In any case, after adding gas and clearing codes it has started cranking back up. BUT it's running extremely rough.
  5. Tombukt2
    13,845
    2,515
    Durham NC
    Yes it is so now you troubleshooting that 3190 poor running just like a gas car .
  6. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Now the car won't go into ready mode. It was cranking up and running (although very rough) and now all the sudden it's not going into "ready". All the lights come on but it doesn't say "ready" and isn't turning over. The hybrid battery is low but not that low, it has like 2 bottom bars which is always enough to crank it.
    I put a new 12v in it yesterday and earlier today put it on a trickle charge to keep it from dropping while I test things....so the 12v is good and strong.
    Do you have any thoughts???
  7. bisco
    52,819
    do the brake lights come on when you press the pedal to push the power button?
    pasadena_commut likes this.
  8. pasadena_commut
    3,038
    942
    Southern California
    If it won't go to READY how does the OP know how many bars the HV pack has?
  9. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    IG-ON will show the hybrid vehicle battery charge level on the MFD.
    StephenJ likes this.
  10. Tombukt2
    13,845
    2,515
    Durham NC
    I know this so far walking up to Prius and looking to buy them Ive not had one yet that the HV battery in it did not crank the vehicle . I've had em barely 1 pink bar etc . If I make sure all ignition stuff is correct plugs MAF etc cracks rt up I floor it in drive sometimes tSkes 5 full min to green . But makes it even if battery health is questionable . All so far have driven off the premises . Like 9 of em. Now.
  11. Hayslayer
    Hayslayer Active Member
    534
    325
    The fuel level showing one blinking dot and then later showing 4 dots is indicative there was a loss of 12v power. Whether from a 12v battery change or whatever doesn't really matter. The fuel level defaults to one blinking dot until it calibrates itself, which may be 5 minutes or 5 hours. The good news is it's now indicating correct level.
    Now...when 12v is lost, all the ecus in the car go back to default values. This includes all the engine parameters that are 'learned' over the course of days or years of operation. This includes everything in the throttle body. One of the first things you need to do is clean the throttle body and throttle plate to remove any carbon buildup that may have caused a change in the plate positioning over the years. The 'learned' functions account for this, but since they've been reset to default, they may be too far out of range now. Also clean the temperature bulb and the MAF sensor inside the housing. That will get those components to match closer to the OEM default values, which are now in the ecu.
  12. Tombukt2
    13,845
    2,515
    Durham NC
    Yes and hopefully you don't have to do much cleaning because you're keeping this stuff clean with regular attention.
  13. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    When cleaning the tb can the plate be opened manually with the car turned off? Some cars it messes up the motor.
  14. Hayslayer
    534
    325
    yes, it can. I also usually wedge it open and scrub the inside with a toothbrush. Spray cleaner on the toothbrush and scrub the inside walls/ plate. Remove the MAF sensor from the side using a stubby screw driver and clean the heck out of the sensors also.
  15. Tombukt2
    13,845
    2,515
    Durham NC
    I just push it down w plastic rod etc blast it out push it down let it go a few times
  16. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Yes, the brake light come on but it's not trying to turn the engine on, everything looks seems normal but the engine never fires up.
  17. Tombukt2
    13,845
    2,515
    Durham NC
    The brake light comes on I hope all dash should lite up . And mostly go out you see Ready in green ??? Now step on the gas what happens ?
  18. bisco
    52,819
    i would put a volt meter on the jump point for a reading
  19. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    All the dash lights come on but it does *not* say "ready" in green and the engine never comes on. The hybrid battery is low enough that the engine should start running right away, but also I've tried giving it gas and it does nothing.
  20. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    It's currently at 12.5v I just put a new battery in a few days ago thinking that was a issue, it was pretty old. I've been keeping it on a trickle charge while working on it.
    I should prob clarify something....it's not just that the engine isn't cranking up, it's not spinning at all. If it was a gas car I'd say the starter isn't working.
    What all is involved in actually spinning the engine over to crank it? Should I check some fuses?
    #20 StephenJ, Aug 26, 2025
