Help identify part and mounting
Discussion in 'Gen 4 Prius Main Forum' started by Jason Dunstan, Aug 16, 2020.
  1. Jason Dunstan
    Jason Dunstan Junior Member
    Bowling Green, OH
    So I was trying to track down what seems to be an inverter loop leak of coolant, and while doing so, I found this part that seemed to be just sitting in the cavity in front of the radiator on its side. The reason I think it was on its side is because, A: it was loose, and B: it appears to have a smooth notch in it where the latch lever would make sense to protect fingers. Extra points if someone can get a picture of it mounted to accompany a verbal description of its orientation and mounting position.
    52,886
    2008 or gen4?
    krmcg likes this.
  3. Jason Dunstan
    Bowling Green, OH
    Oh, duh. Sorry. Is a 2017.
    also I experienced white smoke today :( so had it towed to a mechanic. I’m afraid it was leaking into a cylinder. Perhaps oil I guess. It wasn’t missing at all that I could feel.
    52,886
    sorry to hear it, how many miles?
  5. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    can you make a clear picture of this number?
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    White smoke could be the heat exchanger on the exhaust leaking coolant into the exhaust.
    jerrymildred likes this.
  7. Jason Dunstan
    Bowling Green, OH
    To respond to everyone.
    75k miles.
    That plastic part's number: 16562-37010
    White smoke caused me to take to mechanic, as mentioned, they identified the coolant leaking into the catalytic, as mentioned by Kithmo (I think that's what you referred to).
    Quoted $2k to replace, very little in labor. Seems the cat theft causes prices to be wild.
    Knowing it's not the motor leaking somewhere is a great comfort, but I'm struggling to find an affordable cat. I'd be happy to install it myself since it's all bolt on, but even the mechanic was only quoting an hour or two for install anyway. So probably easier to go that route.
    Is my only real option to buy a new cat?
    Thank you all!
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I think the high price is probably due to the Gen 4 not being as easy to steal, so there are less aftermarket ones available. Is $2k the dealer price ?.
  9. Jason Dunstan
    Bowling Green, OH
    I haven’t contacted the dealer yet because I expected theirs would be highest of all. Assuming I’ve been seeing the correct part across sites, new seems to have a range of about $1600-2200.
  10. GabrielD
    GabrielD Member
    179
    73
    Romania
    2014 Prius+ MPV
    Mambo Dave and krmcg like this.
