Help identify the problem
Discussion in 'Gen 2 Prius Main Forum' started by Chalipa, Sep 24, 2020.
  1. Kiwibird
    Kiwibird Junior Member
    56
    Sydney
    i-Tech
    Exact code after good scanning is P0AA6-305
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Are you sure it was INF 305, it sounds off. Which OBD2 reader retrieved the above DTC P0AA6 (aka P3009) with INF 305?
    Notice in techstream (image below) how 'Detail Code 2' has an INF (subcode) of 526. and 'Detail Code 3' has INF 612
    Though dated, here is the workup for DTC P0AA6/P3009 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/3009526.pdf
    Below is a visual, combine this with the INF and it can help guide you towards the problem area.
    Raytheeagle and Kiwibird like this.
  3. Kiwibird
    56
    Sydney
    i-Tech
    I tested the AC compressor for leaking power by disconnecting the cable then clear codes and tried driving but code comes back again...
    I tested the invertor by using voltmeter connecting ground to car body and positing to the body of the invertor (synergy drive box) but no voltage detected...
    Last 2 things I need to test is the transaxle but not sure how to test this one? Then last thing is the battery... If someone knows how to test the Transaxle please
    Thanks
  4. ChapmanF
    18,530
    That's guaranteed to show you no voltage detected: the inverter box is bolted to the car body. :)
    Testing for HV leakage has to be done by following the procedures in the repair manual (or closely equivalent, as in reading them and designing equivalent tests).
    Kiwibird likes this.
  5. Kiwibird
    56
    Sydney
    i-Tech
    Do you have that procedure handy please?
  6. ChapmanF
    18,530
    Elektroingenieur kindly put effort into a wiki page with a lot of the ways one can access the repair manual, all described in one place.
