Help identify this chirping noise at startup and shut down please!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeffster06, Mar 9, 2024.
  1. Jeffster06
    Jeffster06 New Member
    Raleigh, NC
    It sounds something like a dolphin or porpoise trapped in my engine bay at certain times while driving but most pronounced when starting up or shutting down. I have a hunch it's air in the hybrid coolant system or maybe a bad pump but previous owner replaced it not that long ago. Also wondering if it might be a failed seal on the coolant cap but not sure how best to check it. Would love to know if anyone else has heard a similar sound and knows the fix. I've imbedded mp3 files for the sound at startup and shutdown. Thanks!
    Startup noise:
    Shutdown noise:
    #1 Jeffster06, Mar 9, 2024
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    Those are some weird links to Google that do nothing as far as I can tell.
    Jeffster06 likes this.
  3. Jeffster06
    Raleigh, NC
    I just changed the permissions on Google Drive. Please let me know if it's working now. Thanks!
  4. Tombukt2
    13,845
    2,515
    Durham NC
    I don't know sounds like a pretty normal 7:30 8:00 a.m. North Carolina startup and then on the shutdown is when I really hear the chirping but I can't imagine where that's coming from your eye should be taking you right to it even if you can't see it like right to the hood or right to the dash or something hard to explain I guess I guess you've had your friends and whatnot just for haha's take a look or listen or I don't know.
  5. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    Your audio files don't work...
  6. ChapmanF
    18,999
    Looks like they maybe worked for Tombukt2, so maybe it's more a matter of "the files are ok, but putting them on drive.google.com doesn't work for all of us".
    In the past I've found it simpler to just attach them to the post on PriusChat. One-stop shopping.
    But sometimes there's a headache where PriusChat won't allow attaching a certain file type, and then I just zip it and attach the zip file instead.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    The sound on the startup, if I'm picking the right sound, seems like the HVAC damper doors. They sometime groan.
    The shutdown sound that's a loud whirring, sounds to me like the coolant recovery tank pump pumping coolant into the coolant recovery tank.
    The first is common and harmless, but not really normal. The second is as it should be.
