Help identifying pumping noise? (not brake pump)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tekdeus, Jul 7, 2013.
  1. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    Hello, I've browsed the forums here but can't find a clear answer. I've made a video of the pumping sound in that seems to get "stuck on" repeatedly at occasional times while the car is in operation or at idle. Do you folks know what it is and if it should not be going on like this without stopping? The car is a 2004 Canadian model, assuming it has the coolant thermos. Thanks
    Thanks
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    It sounds like it could be your inverter pump. But, that is just a guess. Have you put the car in Ready Mode and checked for turbulence in the inverter fluid reserviour? Also, have you changed the fluid lately. It almost sounds like a pump with no fluid going through it or air stuck in the system.
    51,155
    does not sound familiar, i would have it checked out. how many miles on her?
  4. Tekdeus
    151
    Vancouver
    About 52,000 miles / 84,000 Km
  5. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    Ive heard something similar on two different vehicles. The problem was a stuck coolant flow control valve on both vehicles.
    Bumblebeetuna likes this.
