Help installing built in DVD headrest
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Beano39, Mar 15, 2012.
  1. Beano39
    Beano39 Awesome Guy
    24
    Southern California
    Hey guys i am going to install built in DVD headrest monitors into my 2007 touring prius. I have posted questions about this before, but want to know if anyone has detailed info on how to install these myself. Ive been told there is an amp under my drivers seat where i can do all the wiring, but im not sure & dont want to screw things up. If anyone knows how to do this or has a wiring guide or anything like for this, that be real useful. Also, if anyone knows how to get the seat back off to feed the wires down, let me know that as well. I have the leather interior & the seat backs seem seamless. & it if it helps, its the power acoustik HDVD-9 model twin monitors.
  2. drew935
    drew935 Member
    168
    22
    Nor Cal
  3. cnschult
    cnschult Active Member
    772
    96
    Michigan
    i just removed my entire interior to remove my carpets, under the drivers seat is a DENSO nav head unit (if equipped), under the passenger seat is the JBL premiums sound system amp (if equipped). although I had no problem other people report that there are very sharp things under the seats, so if you're going to be running wires down there make sure to buy cable sleeves (nylon or the plastic ones you see protecting all the cables everywhere down there). Make sure there is enough slack in your cables, when you are done lie on the back seat and look down with a flashlight, have someone else move the seats fully forward and fully back several times and make sure that nothing is even close to catching. Too little slack and the wires may get damaged when the seat is moved fully forward or backwards. Too much slack and a backseat passenger may catch their shoe on it and pull the cable loose. Make it just right.
