HELP Is my engine messed up?! Oil dry
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lex G, May 17, 2018.
  1. Lex G
    Lex G Junior Member
    33
    Wisconsin
    Four Touring
    That was my plan actually.
    Right now I wanted to make sure that the car, after having endured this close call with death, is still okay.
    I don't want to sink a bunch of money in the car right away, to find out that it dies the next year or sooner than that.
    I do have my "Car Apocalypse Fund" for in case anything bad happens to the car, but I don't want to burn through that and not have any money left in case I do have to replace the car.
    Right now, I think the spark plugs are do-able.
    I actually had watched a video on replacing the spark plugs. The female mechanic in the video mentioned items such as anti sieze. After watching her video, it seemed like quite a bit of work to replace all those parts myself. Personally I am fine with paying the extra money if it means that it doesn't get messed up by me.
    (In Wisconsin, if a mechanic or garage damages your car internally or externally, they by law have to fix the vehicle and return it to the state it was in before or better. I had this issue when a mechanic backed my car into someone else's car door. They ruined both the rear bumper and the rear passenger side taillight)
  2. Mendel Leisk
    42,376
    Opinions are split, on putting anti-seize compound on the spark plug threads. I've always used a bit in the past, but I think plugs installed at the factory are without anti-seize. Some spark plug manufacturers say to not use it. And: putting a lubricant on the threads, you would want to reduce torque value, and by how much. Maybe best to not use it.
    Things you should have:
    1. The appropriate long socket, preferably a "spark plug socket" which has a rubber insert that grabs the plug. Second gen size is 5/8" or 16 mm.
    2. Ratchet wrench extensions, say a 6" and 3".
    3. A decent quality ratchet wrench, 3/8" drive is fine, or 1/2" with a reducer. A regular AND a long handle ratchet wrench combo is good: for tough to remove bolts the longer handle is very helpful.
    4. Torque wrenches: for wheel lug nuts a 1/2" drive would typically be best, good to have. But for spark plugs, 3/8" drive will likely be better, have the torque range required.
    5. Some sort of compressed air is good to have, to clear the spark plug wells of possible debris. Maybe. The wells may be spotless, but if you can get something, do, just in case. Even just a wet/dry vacuum that you can configure to blow, for example. A good tact is to slightly loosen the plugs, so they're slightly up, then blow air into the well.
    Note: plugs nowadays (particularly the type spec'd for Prius) typically come pre-gapped, do not need adjustment, and should hold that gap for their lifespan. Manufacturers tend to caution against adjusting the gap, and cleaning should be limitted to gentle method, say old tooth brush and some carb cleaner.
    I'll attach second gen Repair Manual spark plug section. It's much better than 3rd gen manual btw. The latter is garbage, info all over, not concise.
    #42 Mendel Leisk, May 19, 2018
  3. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    Of course, one has to go with what one feels comfortable, but things like anti seize should not scare you. It's just some goop to prevent sprk plugs to be "welded" to the engine head where they screw in. It's sold in your local auto store at the register in tiny packets for $1 enough to last for one or two jobs. There is absolutely nothing difficult or risky in replacing one's own spark plugs. It's one of the simplest jobs there is, really. In the Prius they are a bit harder to get to than usual, but nothing terrible. A set of right tools for the job will set you back $40 at most and then you'll own a bunch of decent tools. You will need a spark plug socket, a ratchet drive and an appropriate extension for the spark plug socket. I use a 3/8" ratchet with a 6" (maybe 8", I am not sure) extension. Call me crazy, but I do not use a torque wrench on spark plugs. I just get them hand tight to where they hit the initial limit and then give them 1/4 - 1/2 turn over that to crush the crush washer against the mating surface on the head. That is all. I do use anti-seize (sparingly!) on the threads of the plug as the engine heads are aluminum alloy and spark plug threads are steel of some sort. Dissimilar metals can chemically weld to each other sometimes and a tiny amount of anti-seize prevents that. As I said, a 20 minute job including a 5 minute coffee break. But again, if you do not feel comfortable with this, don't do it. Your comfort level in this case will cost $100 and that's fine.
  4. Lex G
    Lex G Junior Member
    33
    Wisconsin
    Four Touring
    I'm guessing autozone would probably help me find the tools to get the job done for next time.
    (if all is well with the car, I do want to see how many miles I can put on the car. I have heard rumors of up to 500k miles)
    Right now with all of the work that has to get done or inspected on the car, the next step after spark plugs is to replace the engine air filter. I plan on taking baby steps with the amount of maintenance I do on my own car, until I feel confident to do more in depth repairs or replacements. (I saw a video on replacing the coolant, and the guy had to lift the car up and down numerous times for something like that.)
    I believe you mentioned in a previous post about how you bought spark plugs from autozone.
    I went on amazon and found spark plugs from various manufacturers.
    I know that the ones that originally come in the car are iridium.
    Is there a difference between the different brands such as Bosch, NKG, or Denso?
    I noticed that Bosch had a Double Iridium spark plug for about 7$. Is it okay to go aftermarket with spark plugs, or is OEM preferred again?
  5. Mendel Leisk
    42,376
    There is no special "OEM" plug, manufactured by or for Toyota. Toyota has specified a spark plug for the car. It's a specific, off-the-shelf plug, same as the ones you can buy. I wouldn't second guess them; just get the spec'd. plug. Through the dealership they will tend to be more expensenive, and might come in a Toyota box with Toyota part number, but inside: it's the Denso or NGK plug.
    This is from the 2009 Owner's Manual, page 465:
    (Note, you can dowload pdf manuals online. Google "toyota tech info", go to the "manuals" section, and fill in your car info.)
  6. Stimp
    Stimp Member
    53
    North Carolina
    Autozone here was offering a $10 gift card if you bought 4 NGK spark plugs last week, maybe that's still going. Laser iridium were between $8-9 each so it makes it as good a deal as anything online. I checked my plugs last week because a deal was right around the corner if they had needed replacing. Gift card would likely be enough for an air filter too.
  7. Lex G
    Lex G Junior Member
    33
    Wisconsin
    Four Touring
    I'll have to drive over to my local autozone then and see if that's still going on. I actually just put my order in on amazon for the engine air filter since I have amazon student.
  8. VFerdman
    1,200
    1,221
    Here are Denso spark plugs that are specified for your Prius on Amazon. Under $8 and free shipping. Go to Amazon and search the following:
    Denso SK16R11 Iridium Spark Plug
    Engine air filter requires no tools to replace. It's just four clips to pop the cover off, replace the filter (there is only one way it will go in) and pop the cover back on. That's a 7.5 minute job including a 5 minute coffee break :)
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    While you’re there and taking a coffee break, you could pull the dipstick, wipe it off, then check the level when done drinking coffee ;).
    Not a bad multi-tasking opportunity (y).
    josh2008 and VFerdman like this.
  10. VFerdman
    1,200
    1,221
    Excellent advice!
  11. Lex G
    Lex G Junior Member
    33
    Wisconsin
    Four Touring
    I've been checking the oil every time I enter the car. My mom told me I should be checking it before I leave to go places, and after.
    I've updated my spreadsheet to have multiple sheets where it will calculate the ratio of oil consumed, as well as mpg if I enter how many gallons I filled up with. I even saved the links to most of the parts for my car, incase I have to buy them later.
    Aaron Vitolins and VFerdman like this.
  12. VFerdman
    1,200
    1,221
    Many people here, including myself, are using Fuely to keep track of our gas consumption. It's a web service that you set up for yourself and enter the numbers every time you fill up. Fuely does the rest. You can see in my signature I include a relatively up to date Fuely score. My MPG since I bought the car is close to 45 mpg. You can set it up so you can text Fuely right from the gas station the numbers and it enters them into your account for you. This is what I do. I just text them every time I fill up.
    As for oil consumption, don't worry too much. What's done is done and all you can do now is hope it was fairly benign. My car has 190K miles on it. I bought last July with 175K miles on. It uses about a quart every 2K miles or so. Depends how much highway driving I do. I check the oil fairly often, but at least every 1K I never let it get too close to the bottom "low" indicator on the dipstick. I use full synthetic oil and add to maintain level between full and midway in between marks. I change the oil and filter every 10K miles. I do it myself and have been ever since I owned cars (around 16 years old). It's easy to do, saves money and gives you a chance to look things over under the car and under the hood. I am a big believer in maintaining my own car and really have very little trust in an average Jiffy Lube employee (or even a dealership employee).
    Best of luck, I think you got away with a minor sin of letting the car run (almost) out of oil. It will be just fine.
  13. Lex G
    Lex G Junior Member
    33
    Wisconsin
    Four Touring
    Just looked into fuelly and it looks pretty useful. Probably gonna sign up and start using it.
    I just looked into the owner's manual for my prius but I couldn't find an oil filter listed. Autozone shows a whole list of them. I'm assuming I just go for one with good reviews and use it. The STP filter has some good reviews and mentions its rated for synthetic. Learning how to do an oil change would be nice to learn.
    The used oil disposal is more what I am concerned about. The Owner's manual mentioned it's not something you can get rid of in household trash. My question would be, where do I take it if I change my oil at home?
    The other question is when do you change your oil? So far I have learned to check before the sticker mileage and top it off inbetween since I have an older car. If I keep adding oil, at a certain point I will have to get rid of the nasty old oil. I assume the oil will turn a certain color when it is time to get an oil change. I'm also assuming it's better to change the oil when it reaches that color, even if it's before the sticker mileage. The question is, what color should the oil be when it is time to change?
    [edit] Internet says that color isn't much of an indicator, but dark brown is typically when it has to be replaced.
    #53 Lex G, May 19, 2018
  14. Patrick Wong
    18,214
    6,530
    This is the correct 2G Prius engine air filter:
    Toyota SLLC is sold in gallon containers.
    ATF WS has thinner viscosity than ATF T-IV. Use ATF WS only.
    A Toyota dealer will probably charge ~$100 to $150 for brake fluid replacement. Do not buy the brake fluid if you have the dealer do the work. That is like bringing your own steak to the restaurant and asking them to grill it.
    Your city may have hazardous household chemical recycling. Walmart and many auto parts stores will accept used engine oil for recycling.
    Change the engine oil at 5K mile intervals and frequently check the oil level in between changes. Don't worry about the color of the oil.
  15. VFerdman
    1,200
    1,221
    Amazon sells Genuine Toyota oil filters for pretty reasonable price. I go with that myself.
    In the state of Massachusetts, where I live it's the law that retailers selling motor oil are required to accept and recycle used motor oil. I bought one of those oil change receptacles sold in most auto parts stores (it's a flat reusable container that incorporates a funnel to accept used oil) for around $15 and that is how I bring my used oil back to the store I bought oil from and they take the container out back where they have a huge collection tank, dump the oil and bring back to me an empty pan which I take home and use next time. Had this particular pan for over 20 years now, I think.
    You change oil based on mileage, not color. I believe Toyota recommends every 5K miles. I do 10K miles because I use full synthetic.
    Mendel Leisk and Raytheeagle like this.
  16. priusb78
    priusb78 Member
    66
    50
    Nuremberg, Germany
  17. padroo
    padroo Senior Member
    2,763
    2,253
    You seem to be overwhelmed at the moment. I have found that it is best to tackle one of those jobs at a time if it is your first time doing it and by breaking it up into smaller pieces you won't be so overwhelmed.
  18. Lex G
    Lex G Junior Member
    33
    Wisconsin
    Four Touring
    I am feeling pretty overwhelmed but I am trying to get something done.
    Had to deal with a family emergency on Saturday and I'm going to be stressed from that for a while, at least until my in-laws get back.
    In my panic on thursday, I had unplugged my car chargers and now the cigarette lights don't charge my phone. I'm pretty sure it's a blown fuse so I bought the parts, just waiting until it's nice out to change them.
    Right now my mechanic appointment is in 2 hours. I'm just trying to make a list of things to do.
    Right now it goes
    Coolant
    Transaxle fluid
    Other fluids
  19. VFerdman
    1,200
    1,221
    Take it easy. Nothing in your car is urgent. Just take it one thing at a time and do not stress out about the car. It will be fine. Now you know what needs to be done and you have a plan to do it. So all is good. These cars are amazingly sturdy and take some measure of hard use. Many of them are used as cabs in cities like San Francisco and New York City.
    Raytheeagle, Mendel Leisk and malmon like this.
