HELP it wont shut off
Discussion in 'Gen 2 Prius Main Forum' started by Wrecit, May 16, 2021.
  1. Wrecit
    Wrecit Active Member
    177
    113
    Pittsburgh
    2001 Prius
    I
    Ok have a 2006 and the dash died the other day. Have part ordered to fix it. Wife needed to go to store so figured no problem.
    She got to store and it will not shut off or release the key fob from the dash. It will go into park and other than dash seems to work fine but the start/stop button is not working. How do I shut her down.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Try holding the start button down for 30 seconds, if that doesn't do it then you'll need to disconnect one side of the 12v.
  3. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Just hold the power button down for about 5 seconds
    iPhone ?
  4. Wrecit
    177
    113
    Pittsburgh
    2001 Prius
    I
    You guys are gods thank you
  5. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    That is what happened to me when my 12volt battery died. I got a new one and it never happened again. Also make sure key fob battery is brand new!
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    It will progress to the point of not being able to shut off till you unplug the 12 volt. It’s easy there’s a thicker black wire that plugs into the 12 volt positive post Assy. Just unclick it and pull it out. It helps to keep the little red plastic over off the 12 volt battery.
    Paul Schenck likes this.
  7. Paul Schenck
    524
    307
    Fresno, California
    I’ve never had it get that bad and I let it go for three years though it didn’t do it every time.
    iPhone ?
  8. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Im lucky like that.
