help! lost bolt during ebh installation
Discussion in 'Gen 3 Prius Technical Discussion' started by sailin3d, Feb 10, 2012.
  1. sailin3d
    sailin3d New Member
    san diego, ca
    while unbolting the windshield wiper tray (the metal one), one of the bolts rolled down the drain hole (driver side) :(
    I've tried taking apart the wheel well lining but could not find it. I've also tried rolling the car forward and back to try to shake it loose - wherever it is.
    Now when it roll down the drain hole, I only heard 1 thud... Any suggestions? Worst case, where can I get a replacement bolt/washer?
  2. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    Tape a magnet to a string. It should fall down the hole nearly the same as the bolt did.
    Also, a small piece of mirror and a flashlight can be helpful
    Bill
  3. sailin3d
    sailin3d New Member
    san diego, ca
    Thanks Bill. I would do that unfortunately its all metal under there :(
    Will keep searching.
  4. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    that sucks man. I only managed to lose one of the plastic clips when I was taking mine apart. The string and magnet sounds like a great idea.
  5. JohnPE
    JohnPE Junior Member
    Marlblehead, MA
    Two ideas:
    1) Buy one of those telescoping rods with a magnet on the end (Try Harbor Freight Tools) so you can shove the magnet down past all that metal.
    2) Leave the bolt where it is, and just remove one of the many other bolts of the same size and take it into any hardware store. They should be able to match it exactly.
