Help! Master Warning Light - what to do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rapid Dog, Sep 1, 2011.
  1. Patrick Wong
    18,210
    6,511
    Re: automatic headlight leveling system
    Glad to hear that you've narrowed the problem down. More likely the problem is with the level sensor mounted at the beam rear axle. This sensor allows the headlight ECU to adjust the headlight beams appropriately as weight is added to the rear of the car.
    Frequently the sensor will rust and get stuck.
  2. Rapid Dog
    Rapid Dog Member
    101
    SoCal
    Yes, actually called:
    Toyota Part: SENSOR SUB-ASSY, HEI
    Part NO.: 89408-47010
    or
    Cheapest I've found so far at:
    Toyota Parts Superstore
    Item Number MSRP Core Price Price 8940847010 $358.69 $0.00 $254.46 Rear suspension - Ride control - Height sensor
    Height sensor, prius - 2004-09 2004 - 2009
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi RD, I don't have that option on my prius so I don't know for sure, but I've read several posts here where people just clean up that part to get it working. Rusty and get stuck as Patrick says.
  4. Rapid Dog
    Rapid Dog Member
    101
    SoCal
    Yes, I pulled it and disassembled. This one is toast. Completely rusted solid. No fixing it. To add to it, a tooth is busted off in the corroded harness plug.
    That will need to be spliced in as well.
  5. Rapid Dog
    Rapid Dog Member
    101
    SoCal
    got a new/used one from a Cali car, took it aprta it looked like new.
    Installed and all is good. No more RED triangle.
  6. johnjohnchu
    johnjohnchu Active Member
    211
    104
