Help me identify a 10mm hex 'drain' plug?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jsorger, Mar 24, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Woman are an entirely different species. I simply don't understand how a woman can calmly, coolly, rationally, work on some complete F Bomb grease encrusted, used up piece of s*** and not even once use a mild expletive
    Inanimate objects *fear* males when males drop the F Bomb and shake the ratchet in a threatening manner. Some objects are dumber than others, you then have to recourse but to beat them senseless
    It also helps if your neck pulsates in an alarming manner while shaking the ratchet at the now-broken part
  2. jsorger
    jsorger New Member
    97
    So the order is definitely sleeve, bearing, spring. Verified this evening.
    Thanks for all of the help!
    Jonathan
  3. jayman
    13,439
    641
    Winnipeg Manitoba
    Happy to hear it worked out. Everything ok now?
  4. jsorger
    jsorger New Member
    97
    Yes. *gulp* (sound of me swallowing my pride as an engineer...)
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Knowing when to swallow your pride is a sign of a good engineer.
    Tom
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Yes, I second that!
  7. Patrick Wong
    18,210
    6,514
    Hi Jonathan,
    No need to swallow your pride. You've added new knowledge to the PC community by determining that transaxle parts exist that are not pictured in the exploded parts diagram! Thanks for that discovery.
  8. 2010_Prius_Owner
    2010_Prius_Owner New Member
    110
    24
    Philadelphia
    So how did the story end?
    Did Jsorger put the sleeve, spring and ball bearing back correctly?
    Did he put it back incorrectly and cause damage to the car?
    Did he have the car flat bedded to a dealer's shop?
    How does the story end?
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Yep, he did
