Help me identify this part (front underside)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Tom2101, Jul 26, 2023.
  1. Tom2101
    Tom2101 New Member
    Four Touring
    I have a 2017 Prius Four Touring. After riding once too many onto parking lot cement barriers (that separate parking spots), I've done some damage to the front underside of the car. The panel under the car on the passenger side in the front is torn off (partially). The similar panel on the driver side is a little damaged. I hope to repair this myself but I'm having difficulties identifying the part(s) I need Prius PassengerSide Front.jpg Prius DriverSide Front.jpg . Help!
  2. JohnPrius21
    JohnPrius21 Junior Member
    24
    Los Angeles
    Four Touring
    Looks like there are some part numbers on the intact cover, try starting there. Or just head over to the parts department at your local dealer.
    iPhone ?
  3. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
  4. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    If both those pieces are directly in front of the tires; it's the wheel well liner. The front half separates from the wheel well liner; but it's sold as one piece. Around $70, when I had to replace mine - similar damage.
    That second picture, you can probably drill a small hole and zip-tie it back into place.
    Hope this helps...
  5. Tom2101
    Tom2101 New Member
    Four Touring
  6. JohnPrius21
    24
    Los Angeles
    Four Touring
