Help Me Name This Product
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Hybrid Effects, Mar 1, 2008.
  1. judas_prius
    judas_prius New Member
    32
    VA
    It would be easy enough to make a locking mechanism that would use a small piece of flat bar that passes horizontally through the grill, then turns to vertical when locked. A hood lock kit or something similar might do the trick.
    Since you are trying to keep the cold air out... you could call it
    "CryoLock" or "CryoWall".
    Another possibility for the material used... clear or frosted lexan. This would open up possibilities for some wild lighting effects.
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    As to the matter of affixing the as yet unnamed product to the lower body work, the go-fast boys use quarter-turn fasterers to secure engine cowlings, access panels, etc. One brand is Dutz, these folks have a representative sample:
    Pegasus -Self-Ejecting 1/4-Turn Fasteners
    (Franklin, you probably already know this, my apologoes if so.)
    "Dutz" is to quarter-turn fasteners as "Velcro" is to hook-and-loop fastenings.
    Some years ago I used a non-permanent plastic fastener that had some serious grab. It consisted of two identical adhesive base pads, each about 2 inches square. On each there maybe 144 tiny protrusions that for the life of me looked like itty-bitty incandescent bulbs. The globe was about 3/32" diameter, on 1/16" diameter necks, each bulb standing about 5/32" tall. Once the protrusions on the two pads were fully mated, while it was possible, it was all you could do to separate them with bare hands. They really gripped. I have no idea what they are called. I think I got them at an outdoor outfitter.
    It sounds like you're well into the final design. Opening and closing louvers appear not to be included, at least not in the initial iteration. Last night while searching for bits and pieces for a project, I got lost in the jungle of HVAC parts. They have some very interesting moveable louvers with small rotary action actuators: but they may be only 120v AC.
    There are some really sexy motors/actuators/controllers under the general search term "motion control."
    Lastly, and regrettably off subject, I discovered that there are fluid logic switches; little ones, big ones, complicated ones, lovely ones, apparently used in medical applications.These things are cool beyond words. Just for fun, try this:
    Custom Fluid Circuits
  3. Doc Willie
    1,717
    144
    Out there, somewhere
    Forward Thermal Deflectors.
    That was obvious.
  4. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Maybe rare earth magnets...they are incredibly strong and cheap.
  5. John CCP
    John CCP New Member
    59
    Old Orchard Beach, Maine
    Cool Check or Cool Block
    Cold Block or Cold Check
    Winter Muffler
    Cold Air Obstructor
    Engine Warmer
    Grille Block
  6. Bob64
    1,540
    93
    Virginia
    "FrostBiter" - bite back against the efficiency losses of winter!
    One other consideration: You may want to add a hole for the engine block heater plugs that people have had installed in the lower grill...
  7. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    HeatShield? WinterFront? ColdFront? WarmFront?
    If you wanted to make something fancy with better fog lights, and a thermostatically controlled opening, you'd have more room to play with if you took the lower grille out first.
  8. pmanza
    pmanza Fernsmom
    123
    Sacramento
    how about Bumper Blocker?
    Fernsmom
  9. Hybrid Effects
    Hybrid Effects Junior Member
    97
    Orlando, Fl.
    Areo-Deflector
    bug-smasher
    Areocloaker Then the Klingons could use it
    This thing is harder to name than I expected.
  10. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    No, really. The Demi-bra.
    It's like a bra, only much smaller... low-cut.
  11. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Dam-It!
    Winter Warrior AeroShield (WWAS Up, Yo?)
    Dammed-Right!
  12. Kablooie
    Kablooie Member
    273
    La Canada
    How about
    De-fender
  13. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    :rofl:
  14. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    I vote for the WWAS .
  15. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Quick Block or The Quick Blocker. It says alot in a short name .
    Ease of installation and it's purpose .You could also have upper and lower Quick Blocker as well .
  16. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I like Dam It
  17. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Glad to hear that and i wanna buy one as well .
  18. Doc Willie
    1,717
    144
    I like Cool Check. Many positive word associations.
  19. Bobbyb
    Bobbyb bobbyb
    62
    Long Island
    Also i would stick to using zip ties to secure it to the oem .You could have pre drilled holes 5 in all. The 4 corners and the middle cut off excess and push the locking part in the hole.With the ties black and the product black
    the look should be ok .The hole should be re enforced with grouments.
    A day like today i be removing some foam it will be 55 here in ny .
    So i thought you may want to offer several types with different amounts of blocking .Ok anymore of my ideas we will need to talk %.
    Also if you go into production overseas i work for a international Chinese
    company who imports from all over Asia into the states.
  20. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    This is a lot of fun. Here's a last proposal:
    Product name: Damm-It!
    The second 'm' should make the name unique and trade markable upon proper application and approval. The casual reader sees 'damn.' But no, there is a misspelling, Is it a typo or intentional? In either case, it pushes the limits of civil discourse in polite company.
    The 'Damm' spelling may be taken as is a faint allusion to the "Kamm Back" aerodynamic rear body design which the Prius arguably has.
    Product Descriptor: Aerodynamic Radaitor Inlet Blocking Shield -- ARIBS
    Damm-It! ARIBS
    Is that another intentional misspelling? Is this a politico-economic statement?
    Now really! That would be reading far too much into this simple exercise.
