Help me out here.
Discussion in 'Gen 3 Prius Technical Discussion' started by LoomisMotorsports, Jun 21, 2023.
  1. LoomisMotorsports
    LoomisMotorsports Junior Member
    26
    Temecula, Ca.
    I’ve read through numerous threads about P0A80 and hybrid battery failures. They all seem to have the same issue. A scan of the hybrid battery shows at least one bad block with significant voltage drop.
    Well, my scanner shows them all pretty consistent. I’d argue they even look great for a 2013 with 220 on it. All within 0.2-0.3v. All the resistance values look within spec too. 0.025 - 0.027 ohms. Block 7 shows 0.030. Nothing really crazy. I’ve watched live data, temps look good, all blocks charge well and fast and all perform well under load. The variance is always within .2-.3v.
    My 12V battery was replaced in September 2021.
    My scanner shows it fluctuating quite a bit. 11.6-11.8 with the car off. Sometimes 12-12.10.. always 13.40-14.20 when the car is in READY mode.
    Just now, got out of the car, ign on but not in ready mode. ECU shows 12v at 12.05. Multi meter at the battery shows it at 12.5v.
    I’m going to take it to get load tested tomorrow, but I just don’t buy it that the hybrid battery is smoked.
    Any insight?
  2. Tombukt2
    Tombukt2 Senior Member
    13,859
    2,519
    Durham NC
    Who said that I mean you want your 12 volt load tested It needs to be able to pass that but other than that you
  3. Tombukt2
    13,859
    2,519
    Durham NC
    Have you looked under the hybrid battery silver cover you may be needing to do that.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    A P0A80 code will allow the car to continue to drive normally. Once the car detects which block is causing the problem a P30xx code will be generated specifying which block is the problem child and will put the car in limp mode. My suggestion is: Don't clear the P0A80 code and let the car progress to the next step so it can determine which block is the charge/discharge problem.
    Brian1954 likes this.
  5. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    What brand is the 12v battery? Do you drive the car for long distances to keep it charged?
  6. LoomisMotorsports
    26
    Temecula, Ca.
    So, the engine runs 100% of the time and the hybrid system doesn’t function. I don’t even get brake assist, at least not the normal amount. But watching the live data, the voltages fluctuate like normal. B+ is still at 13+ when the engine is running. But I never get a second code. I’ve noticed everyone with a second code has an obvious bad cell in their data. I apparently have zero bad cells.
    I did have the battery tested by Toyota today, at first, it said “GOOD RECHARGE”.. so they threw it on their charger. It failed on their charger, so they warrantied it and gave me a new one. I’ll keep you updated. Apparently it was weak and wouldn’t hold a charge well enough to pass.
    I should mention, I have a solar roof, so it should keep the 12v topped all the time.
  7. ASRDogman
    8,066
    4,086
    So they replaced the Hybrid battery???
    The solar roof doesn't charge the 12v battery. It's just to run the fan to circulate
    the outside air inside and inside air outside to keep the inside of the car cooler.
  8. LoomisMotorsports
    26
    Temecula, Ca.
    no, they replaced my 12v battery under warranty as I bought it in September 2021.
    a bunch of short trips yesterday and 40 miles round trip to work today and so far, no light. I don’t want to call it fixed quite yet, but it definitely drives a little better.
    interesting about the solar. I have remote AC too. There’s no way that solar outputs enough to run the AC system, so it’s gotta all tie in somehow.
    #8 LoomisMotorsports, Jun 23, 2023
  9. bisco
    52,854
    doesn't remote a/c start the engine?
  10. ASRDogman
    8,066
    4,086
    The 12v is a tricky thing on a Prius! I would put a charger on it though.
    4 amps or less for about 8 hours, overnight if possible. Then you KNOW there is
    From my understanding, the solor panels ONLY run the fan to circulate cabin air with fresh cooler air.
    And the remote a/c, starts the car to run the a/c, for 5-10 minutes.
  11. Mendel Leisk
    42,345
    The solar roof powered an exhaust fan, which kept the car interior cooler, which helped the AC a little, at start up.
    Ah, @ASRDogman beat me to it.
  12. LoomisMotorsports
    26
    Temecula, Ca.
    Remote AC only runs for 3 mins… but good to know I can leave that fan on for good and not tax my new 12v battery. It’s a TrueStart 45ah from Toyota btw. I’ll attach the test sheet.
    I’m happy to report the P0A80 hasn’t returned, yet. I’ll give it a week or so and let y’all know. Crazy that a slightly diminished 12v can throw that code.
    ASRDogman likes this.
  13. LoomisMotorsports
    26
    Temecula, Ca.
    Well, it’s not letting me. Any idea why my posts are being so heavily moderated?? Lol
  14. ASRDogman
    8,066
    4,086
    New posts people read. And everyone puts in there 2 cents worth. (y)
    3 minutes is enough to cool the car down to managable when you get inside.
    The Toyota battery is the best one for the car. Some use other batteries, but seem to have
    problems with them. Just put a 4 amp or less charger on it for 8 hours or so to give it a FULL charge.
    If the computers are not getting enough voltage/amperage from the 12v battery, they have problems
    booting up, and you will get errors, because something IS wrong. Each one expects "X" amount of juice,
    if they don't do it, they can't do their job correctly, but sometimes enough to switch on the Hybrid system.
    Then it tries to run all the computers AND charge a drained 12v battery that's trying to draw all the amperage
    from the system. Which is not designed to charge the 12v battery quickly.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Trumplican.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The amount of fake info on this thread is hilarious!
  17. Brian1954
    Brian1954 Senior Member
    2,679
    1,071
    South Central PA, USA
    The P0A80 trouble code is for the HV battery. The 12v battery can not cause that trouble code.
    Just drive the car for a few weeks, and the P0A80 code will probably occur again.
  18. LoomisMotorsports
    26
    Temecula, Ca.
    I had a brand new Toyota TrueStart battery in Sept 2021. It lasted a year and 8 months. Let’s hope this one goes longer. And yes, I charged it overnight two nights in a row. It would not hold a charge.
  19. LoomisMotorsports
    26
    Temecula, Ca.
    sorry Brian, this is simply not true. It happened to me back in 2021 when I bought this TrueStart battery that failed. The car already runs night and day better just from the 12v swap. As I said in the first post, all the hybrid battery blocks are functioning as they should. All within spec for voltage and resistance.
    jerrymildred likes this.
  20. LoomisMotorsports
    26
    Temecula, Ca.
    Such as?
