Help me please!!!
Discussion in 'Newbie Forum' started by Cgarrison1, Jul 11, 2016.
  1. Cgarrison1
    Cgarrison1 New Member
    Lodi ca
    I have a 2005 prius. I have read all over for what the problem cam be. I hope some one here can help. I took my prius to the Toyota service shop and theye said they couldn't see me today. So, my triangle light the car light with the ! In the middle on the screen came on as well as one other one. I change the big batter and the 12v after reading here that that's the problem, but my problem still exist. When I shut the car off and turn it back on every thing comes on and ready but only goes to neutral. It won't go to drive. I disconnect the 12v like a forum said and plug it back in and the car starts again once. And drives normal. Until I shut it off. I took it in to read the codes and there are 0 codes. The service guy told me there is nothing wrong.
    52,855
    welcome! sorry for your troubles. which toyota dealership told you there was nothing wrong?
    how many miles on her?
  3. JC91006
    16,936
    8,647
    Wait, the dealership can't see you TODAY, but you're able to change your 12v and hybrid battery today? I must be in the twilight zone
    How can things move so quickly?
  4. Affordable Hybrid Repair
    Affordable Hybrid Repair Junior Member
    New Port Richey Fl
    When you say service guy, are you referring to a Toyota service guy because certain scan tools will not pick up codes and the factory scanner or a mini vci with techstream works best. Did you replace both batteries with known good ones ?
  5. JC91006
    16,936
    8,647
    @Affordable...........advertise much?
    usnavystgc likes this.
  6. strawbrad
    953
    1,007
    You have a high voltage leak. The codes are P3009 or P0AA6. It is the only fault that causes the one and only one start after a 12 volt reboot.
    Generic code readers will not read all the Prius codes.
    Brad
  7. Cgarrison1
    Lodi ca
    Lodi ca, read the codes and showed me the reading said 0 codes. 215k
  8. Cgarrison1
    Lodi ca
  9. Cgarrison1
    Lodi ca
    It was at a pep boys. And yes both batteries are good.I jüst went back and had them retested too
  10. Cgarrison1
    Lodi ca
  11. Cgarrison1
    Lodi ca
    I will take it by Toyota again today. See if they will read it this time. Every time I unplugged the 12v I can start it up again and drive. Should I not do that? How is the problem fixed and what's the average cost
  12. Cgarrison1
    Lodi ca
    Will replacing the big batter fix it.if that one is leaking?
  13. strawbrad
    953
    1,007
    Ask for the Sub codes. 612,613, or 614 are the options. The sub codes tell where the leak is coming from. You can try this test on your own. For a Gen II Prius, ing on & ready off is reached by pressing the power button twice with your foot OFF the brake.
    More info on the leaks.
    2004-2008 Toyota Prius with code P3009 or P0AA6 and info code 526, 613, 614 | TOYO Headquarters
    Brad
  14. Cgarrison1
    Lodi ca
