Help me select a prius...
Discussion in 'Newbie Forum' started by jdotPT, Sep 15, 2017.
  1. jdotPT
    jdotPT Junior Member
    44
    Charleston, WV
    2013 Prius Plug-in
    So I've decided I want to buy a prius. My initial budget was $10k to 12k. I've found that you can find some quite nice ones in the $12k to 15k range, 2012-2014 or so. I've done a fair bit it of research. I used to own a Honda Insight so I have somewhat of an idea of what I'm getting into (I understand the prius is nicer and drives better).
    So this morning I came across this: XXXX
    (oopps, apparently I'm not permitted to post links)
    Can someone help? :)
    This car is about 3-4 hours away from me. I was hoping that someone on here could offer some advice. This looks like cosmetic and/or stuff that could be fixed with parts from a junk yard. I realize the battery is back there but this doesn't seem to have affected the battery. Thoughts? For this price, I'd be willing to take a little risk...
    If this doesn't work out, expect a more detailed post asking for more advice. Thanks a ton for any assistance. This seems like a great community.
    Cheers!
    52,915
    welcome!
    can't help without a link, can you type in the web address?
  3. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Let's try this, site is
    bestrex
    (woudln't let me post a sneaky link)- I'm really sorry mods!
    Should be obvious which car it is. The prius for $3k. Sorry for the issue. I didn't realize I would not be able to post a link. (bottom left on my screen)
  4. Salamander_King
    Salamander_King Senior Member
    11,025
    8,981
    New England
  5. JC91006
    16,939
    8,647
    If you've never owned a prius, don't get a $3000 one
    Raytheeagle likes this.
  6. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Bingo. Yes. Again, really sorry for trying to break the rules here. I just got excited. (won't let me quote your text since it contains a link)
  7. Prodigyplace
    12,720
    11,852
    Central Virginia
    Since it mentions collision damage I would be concerned about chassis and alignment issues.
    No mention if it is a salvage title,
    RCO and Raytheeagle like this.
  8. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Very true. I think it states clear title though. The photos don't look bad at all. It was clearly rear ended. If the frame wasn't bent I think I'd be in the clear. With a $3k car I would just purchase liability coverage.
    My friend just pointed out that this is a prius I, which means it was likely part of a rental fleet. Frankly, this makes me feel even better. I could see a rental company having an across the board policy that they just sell and replace cars that are rear ended...
  9. bigrin
    bigrin Junior Member
    59
    Ann Arbor, Michigan
    2014 Prius v wagon
    If you have the time, go and check it out. If it powers up, see how it drives. If it drives well, don't worry about the mileage. With proper maintenance, these vehicles drive forever.
  10. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Well I called and the guy said it was gone after being posted for 2 hours. He apologized and said he's about ready to change his number he's had so many callers.
    Back to the drawing board...
    RCO and Prodigyplace like this.
  11. Kyleidoscope
    Kyleidoscope New Member
    Not sure what your budget is but I just picked up a basically brand new 2015 Prius for a little over 15k. It has 28,000 miles and is spotless with a regular maintenance record and original manufacture's warranty (it is also Certified Preowned). We mainly cared about something with low miles and a spotless record and CPO. But, in my research I saw you can pay as low as $13,000 and still get a great, almost like new car.
    Good luck!
  12. bisco
    52,915
    it's already gone from their listings. if you have a $10-12,000. budget, i would try to find something in that range, unless you're a good mechanic with electronic skills.
    RCO likes this.
  13. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Thanks everyone. I really appreciate your time and effort. I should probably make a new thread and may do that. So my budget is $10-15K. There seems to be A LOT of choices. Even certified ones. Many under 50k miles.
    So next big question... it seems the plug-ins are just as cheap or cheaper. I've done my share of reading on them so I'm familiar with the details. Since they are virtually the same price, is there any reason I should not get a plug-in? I mean- I like the idea of readily available parts for the regular (battery). But I feel like either one could reach 150k to 200k miles with little worry.
    Thoughts? Thanks!
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    If you are referring to a plugin Prius, it is basically the same car with a different, slightly larger battery, plugin charger and different software. It will have slightly better gas mileage in HV mode than the Prius due to larger battery capacity. @bisco is one person here with a plugin.
    bisco and RCO like this.
  15. bisco
    52,915
    if you already know the details, i would go for it.the only reason they are so cheap, is because toyota couldn't sell them, and dropped their pants to move them off the lots on the east coast, same as what has been happening with the current prime.
    #15 bisco, Sep 18, 2017
  16. Prodigyplace
    12,720
    11,852
    Central Virginia
    I believe the plugin has about 11 miles EV range when you plug in to charge. correct?
  17. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Prodigyplace- yep 11 miles is what I've heard/read. Which, my commute happens to be... (wait for it...) 5 miles one way. So I could in theory do A LOT of driving with EV only. So that is appealing to me.
    I really haven't read any horror stories about the pip gen I.
    @bisco and others: would you mind chiming in on any thought about this one? It's top of my budget really but completely doable from that standpoint. I like the color.
    Cars for Sale: Certified 2014 Toyota Prius Plug-In Hybrid for sale in Hanover, PA 17331: Hatchback Details - 457255102 - Autotrader
    For some reason- I had to go to the dealer's site to get the actual car fax. Here it is: https://www.carfax.com/VehicleHistory/p/Report.cfx?partner=DLR_3&vin=JTDKN3DP5E3060624
    #17 jdotPT, Sep 18, 2017
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    What's going on with that tire sidewall? I hope it is not curb rash. :eek:
  19. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    Brand new tires actually... I just spoke to the salesman.
    Also- I linked the wrong carfax report but I will fix.
    One of the things he mentioned was that they had resurfaced the rear rotors. Normally this wouldn't be a big deal but it seems rather odd for a prius of this year/mileage?
  20. jdotPT
    44
    Charleston, WV
    2013 Prius Plug-in
    So I may not have mentioned this. But where I live there are no good deals on a prius I want. I may very well be purchasing a prius before seeing it. It being certified an lower mileage I believe I'm okay with that.
    Is there any specific questions I should ask? Anything with the battery? This car averaged about 18k a year. I think that's a good thing as it did not sit. Sitting is bad for the battery I believe. It was also leased in the NY/PA area. Good temperature for the battery I believe. (as opposed like like AZ or somewhere)
    More thoughts? Thanks!
