Help me understand Dr. Prius App Info
Discussion in 'Gen 2 Prius Main Forum' started by jazz-n-prius, Aug 1, 2021.
  1. jazz-n-prius
    jazz-n-prius New Member
    So Cal
    So I got the Dr. Prius App and a wireless Bluetooth OBDII adaptor. I am curious what everyone thinks about my vehicle's findings. I don't know a lot about the specifics so if y'all could help me understand the numbers that would be great. I can read the numbers but I don't know what is considered good, okay, or bad. I just like knowing what is going on and what I can expect from my vehicle.
    The picture below was taken while the vehicle was parked in my driveway and I had pushed the Start button 2x without the foot on the brake peddle.
    Thank you.
    #1 jazz-n-prius, Aug 1, 2021
  2. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    The number in the middle box called "voltage diff" is a good way to predict when you battery pack is going to throw error lights on the dash. A healthy pack will have a voltage difference of approximately 0.09v to 0.24v.
    As the pack ages that number will start moving up briefly into 0.30v range and then once it gets higher like an occasional 0.64v the dash lights come on and the pack needs to be rebuilt or replaced.
    Sanchan likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    +1 to Priuscamper.
    The battery ecu monitors the voltage of each of the 14 "blocks". Each block is made up of 2 "modules". Each sealed module has 6 nickel metal hydride cells at 1.2V each. Since all the cells and modules are connected in series, the entire pack is 1.2V x 6 (for 7.2V per module) x 28 modules total = 201.6V (nominal). The actual voltage for the pack will vary quite a bit as the State Of Charge changes.
    As stated one of the most important pieces of data is the Voltage Diff-erential. It displays the difference between the highest and lowest voltage levels of any of the battery blocks. On a new battery that might be around 0.1V. As the battery ages and deteriorates, its capacity decreases. As long as all modules remain fairly even, (say, around 0.3V under charge or discharge) then the pack (and car mpg) will still be reasonably good.
    When the difference gets higher for longer periods of time, then the ecu will set codes. A common failure is for a weak cell in a module to "short" and suddenly you have a block that is about 1.2V low under discharge, but with higher voltage when charging. Also the SOC will change from near full to empty and back fairly quickly.
    Sanchan, burrito and PriusCamper like this.
  4. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    If anyone knows, what are the critical criteria for internal resistance? What is a good level? What is bad and how does one use it to predict failure?
  5. PriusCamper
    13,455
    5,430
    internal resistance measure and battery capacity measure are similar... If your charge status screen fluctuates wildly you have low capacity / bad internal resistance and need to do some deep cycling of your battery pack to restore / recondition you NiMH pack: BU-807: How to Restore Nickel-based Batteries - Battery University
  6. Another
    1,819
    520
    Naples, Florida
    Is there some absolute value threshold of IR that is an indication of battery decline? What is the IR of a new battery?
  7. mr_guy_mann
    4,114
    2,012
    NJ-USA
    I just look for values to be fairly even- within a few milli ohms of each other- mostly I don't pay it much attention. If something is way off then I would start looking at the voltage sense harness and the battery ecu connection.
    PriusCamper likes this.
  8. PriusCamper
    13,455
    5,430
    It's more about all the modules still matching and working together as the pack ages because you can have really bad IR and still have a good battery pack that's never failed as long as all the modules are aging in the same way.
  9. dolj
    dolj Senior Member
    8,644
    4,393
    Wellington, New Zealand
    19 mΩ.
    I don't know if there is an absolute value threshold but from what I've seen any value up to the low 30mΩ mark seems to still work. You'd probably start becoming concerned if any starts getting to the mid 30's or higher. The higher the value the more heat will be a problem.
    As others have said in and of itself it is not something on which to focus. By the time the IR is getting high, other indicators will be shouting out louder.
  10. Another
    1,819
    520
    Naples, Florida
    From screenshots I’ve seen, elsewhere, Dr Prius changes the IR icon from green to yellow in the low thirties, so I was curious if anyone knew what was magical about that threshold.
    It appears from these comments that that criterion is not significant in and of itself especially if all cells are within a mOhm or two of each other?
