Help - Mileage Sucks
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by GaryJ, Dec 12, 2012.
  1. SJ PiP
    SJ PiP Member
    190
    35
    oh, my bad. i thought OP had EV when running short trips. actually i've never noticed HV only mpg on such a short trip.
  2. GaryJ
    GaryJ New Member
    26
    Maryland
    We had anecdotal data from a couple of regular Prius owners and a Civic hybrid owner that they were getting around 50mpg. So I guess our expectation was that we'd get that kind of mileage if we never plugged in the car. I think my wife and I are like you - we just drive normally. I'm getting the idea here that to get really good mileage the driver has to be monitoring the car pretty closely, which is a major change in approach for us!
    Gary
    JMD likes this.
  3. GaryJ
    GaryJ New Member
    26
    Maryland
    The morning and evening commutes don't involve significant uphill/downhill driving - we're in the DC 'burbs, not much change in elevation just driving around town. Since the battery is essentially depleted at the end of the evening commute I haven't been plugging it in until we're in for the night. The first trip out after evening commute is usually within about a hour or so.
    Gary
  4. GaryJ
    GaryJ New Member
    26
    Maryland
    Sure - I'll try to get one tonight at post tomorrow.
    Gary
    OK, I've uploaded a couple of photos of the EV Driving Ratio screen at this location. Let me know what you think.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I'm going to out on a limb here and disagree with everyone. You shouldn't have to anything special to get stellar fuel economy in the PiP. Just drive it regularly. For example, I drive 53 miles one way to work. I don't do anything special. I start out in EV and I drive on the freeway in EV. When I arrive, I achieve 75 mpg. Why? Because the 1st 11 miles were all electric.
    I suspect you are reading the numbers wrong. Your total commute plus errands is some 24 miles per day according to your post.
    Quick back of envelope calculations: 24 miles - 11 miles EV = 13 miles on gas / 50 mpg in HV mode = 0.26 gallons of gas used per day. 24 miles daily distance / .26 gallons = 92.3 mpg is what you should be getting.
    Thus, I think you were getting 620 to 630 mpg on your way to work. 10 miles to work means it's almost all electric with some ICE for heat. Anyway, an easy way to see if I am right is to divide numbers of miles driven by amount of gas you put in the car instead of reading the tiny display. If you're really lazy, then we can determine that with 1600 miles on your car and 92.3 mpg means you've only filled up the tank one time. If twice that means the tank is nearly full right now.
    JMD likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I bet in 53 miles your engine warms up. His never does.
  7. mmmodem
    2,732
    1,703
    Bay Area, CA
    10 miles driving home from work, I bet it does.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    mine does when I travel to work (2.7 miles)
  9. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    It is easy to caculate the MPG with a caculator. However if you have an iPhone there is a free app that tracks it over time. It is called Gas Manager. I just downloaded it from iTunes store and will start using it this week. I'm sure theer are other apps out there that people can suggest. Fuelly is often mentioned but it is only on Android.
  10. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I have a feeling its a heavy foot.
    Prius needs to be driven much slower than normal cars to get stellar MPGs. I would expect to get your MPGs if I let a teenager drive my car.
    There is no way you should see less than 200MPG on the way to work.
    Oh, and plug it in when you get home. Those evening trips with a cold engine are killing you.
    When charging it keeps the battery warm. You will also get 5 miles of charge rather quickly, maybe in 20-30 minutes.
    Those short trips should be all electric. But using heat will use the ICE.
  11. lensovet
    2,615
    496
    Burlington, NJ
    i call BS. i drive with a heavy foot, but i plug in whenever i can, and i have 74 mpg lifetime.
    cruising at 75-80 by the speedo (so 73-78 in reality) will easily get you 50 mpg on a warm engine. on a cold engine it will get you 49 mpg because at that speed it will warm up pretty damn fast.
    OP: I think you're missing a decimal point. We had someone else that ran into the same issue earlier. The car does NOT report decimal points. so if it shows 620, it is actually 620 mpg, not 62.0 mpg. If your commute is 10 miles in one direction, 62 mpg is unbelievably low. It means that the engine is running for like 8 of those 10 miles, if not more.
    my advice to OP:
    –do check tire pressure, just to be sure. if it's around 35, we can rule it out as the cause of this problem. if it's below that, do pump up the tires – they could have easily been at the wrong pressure coming off the lot.
    –do look closely at the mpg numbers you're citing. i'm sure you're just dividing by 10 unconsciously.
    –do turn down the heater. 75 seems really high. Set it to 70 if you feel like you really need it, OR use the seat warmers on HI – they warm up very quickly, use no gas, and are pretty damn toasty.
    –do plug in as soon as you get home. that way, you can run those errands on all or part electric.
    report back to us, would love to get down to the bottom of this. you are absolutely right, getting 53 mpg with 10 miles of EV every day is way too low.
  12. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I just love it that 53 MPG sucks! I can't wait until 99 MPG sucks.
    One wonders what his LAST car got when driven like this.
  13. hill
    9,022
    That's right, you don't need an EBH. And the Gen II doesn't need to get over 75mpg either:
    But good luck trying to do one w/out the other. Just sayin'
    If the ICE (internal combustion engine) is below 50 degrees, then the ICE is cold. That may not be cold to Maryland folks ... but it is to the Prius.
    That said, what's up with so many folks recommending "HV" mode, right after the same recommendation. Is there an echo? ... or is no one reading each other's posts ! :D
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I see that on many sites, we are all off researching to get our answers correct, and when we finally all post, they are like a chorus of similar answers, think of us as a barbershop quartet of advice. (I tend to post, then clean up and document my advice, but that just means someone quotes me unfinished, when my final edit says something different, ideally better)
  15. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I get about 60 mpg driving HV -- so are you flooring it from red lights or something? Are you racing up to the next red light slamming on the breaks and then flooring again? Seems awkward your MPG is so low. I also keep my tires inflated 42f/40r. I use EV for surface streets only, but I also charge at both ends. I hate using gas, but I have to on my commute (30 miles). Thinking of adding an additional battery pack.
  16. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    You can feel confident we're not getting a complete story. Something isn't right. This video I shot shows how effortless it is to get great MPG even at high speeds...
    chesleyn likes this.
  17. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    And if you have an L2 charger, it doesn't take long to top-off EV.
  18. fuzzy1
    10,691
  19. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    If you or someone else wants come up w/a modified version for the PiP, maybe there should be a thread to discuss the changes/additions and we can get it stickied.
    There were actually some minor changes made to what I originally posted. I think efusco or one of the mods added/altered a few things. I know I didn't boldface everything either.
    I haven't read this thread carefully and have no PiP but since he's doing the above, I suspect the ICE is running the whole time for that short trip and yes, short trips w/the ICE running will kill mileage.
    I posted a blurb about ICE running to provide cabin heat behavior on regular Priuses at Why mileage gets worse in winter | PriusChat. I don't have a PiP so I don't know how different it is from the regular Gen 3 Prius (ZVW30).
  20. GaryJ
    GaryJ New Member
    26
    Maryland
    Oh how I wish I could blame it on my eyes! The numbers I've been reporting are accurate. I must admit that when we first got the car I wasn't watching mileage that closely - I'm definitely not a hyper-miler. We drove off the lot with a full tank of gas and 88 miles on the car. We've put gas in the car several times - I can't give a completely reliable number, but say around 5 fill-ups. Maybe fill-up is the wrong word, because we usually top off when the gas gauge says about half empty. The last time we added gas I did the math on a calculator and the mpg was about 46.
