Help - Mileage Sucks
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by GaryJ, Dec 12, 2012.
  1. RBooker
    RBooker Member
    154
    56
    So far low temps have not impacted my average mpg. Purchased my PIP on October. After 1 months according to the computer I was getting 121 mpg (114 mpg fuelly). At the of month 2 the computer was sitting at 137 mpg (~850 total miles).
    Commute is short 3.6 miles. I park in an insulated garage on both ends of my commute (work garage maintained at 55 degrees). Weekends I errands are 10 to 12 miles RT. I can run up to 3 errands per day on the weekends.
    Weekdays I only charge at work only. Weekends I charge as often as possible.
    Most weekdays I can complete my commute without triggering the ICE even when the temps are in the 30 to 35 degree range. ICE warmup appears to be on a delay! 70% EV last time I checked.
  2. SJ PiP
    SJ PiP Member
    190
    35
    yup, cold in ny this week. perhaps it's better to switch off EV and save it for the road.
    seems unfair to single out PiP as all cars will take an mpg hit to heat up the cabin and defrost on cold mornings.
  3. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    That's the point- even with EV mode off- when very cold outside and the engine starts for heat or for traction- it sucks up EV miles for the first few min till it's warmed up... I burn through 3 or 4 EV miles (while only getting 48-50mpg too) without even being in EV mode on frigid days... something about protecting the ICE.
  4. GaryJ
    GaryJ New Member
    26
    Maryland
    This is an interesting post. Thanks. So if my math is right - 120 mpg in the morning and 76 overall then you must be getting about 32 mpg on your return trip. Is that right? Or is the 76 mpg your return trip value? This, in a nutshell, is why I started this thread. I was expecting to achieve about 50 mpg using HV only, and the EV add-on was a gift from the Prius gods. I've received a lot of really good advice on how to maximize my EV miles, but it is the low mpg on HV that's driving me nuts.
    Gary
  5. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    No that's something I haven't figured out yet. When I turn the car off on my commute home (depleted battery), I average 60MPG, so not sure how it gets to 76MPG after averaging those 2 values. This is why I made this post, so you can see what kind of route I am dealing with, and how much battery it gives me, as some of the car stats can be confusing.
    When I do a lot of highway driving without EV, I average around 55MPG, I never see numbers as low as 32MPG unless I did a really quick trip so the engine didn't have a chance to warm up.
  6. lensovet
    2,615
    496
    Burlington, NJ
    OP, we still haven't figured out why your EV miles are so low. Again, do you get the charge complete message every morning? What is the estimated range that's shown? What is the MPG number shown on the screen at the end of that morning trip when you turn off the car? Have you started charging as soon as you get home so that you can do your errands on electric? Have you thought about turning down the heater (or completely off) and using the seat warmers instead?
    Can you reset trip 2 on the EV ratio display on a weekday just before leaving the house and then snap a picture the following morning before leaving?
    usbseawolf2000 likes this.
  7. Electric Charge
    545
    133
    Syracuse, NY
    Yes, please give us more details, such as the estimated range when you unplug, especially the route speed limits, and trip/ev ratio details for each leg of the commute.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That's better than the 25-35mpg I get for the first few minutes in a non-PIP. :)
    usbseawolf2000 and lensovet like this.
  9. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
  10. ny_rob
    1,968
    814
    L.I.- NY
    Agreed, but I'm burning up my EV charge while still burning gasoline- if you calculated the combined cost of the gas and electricity during this warm-up stage- it's probably the same as your regular Prius getting 25-35 mpg for the first few min.
    It happened again this morning- and I was carefully monitoring the conditions this time...
    It was below freezing here last night, but when I left the house at 11am it was already 42deg outside. I has set the cabin temp to "LO" and turned the fan to "off" last night before shutting down. This morning I pressed the start button- "EV" and "ECO" indicators were illuminated- the display indicated "charge completed" and indicated I had 9.5mi for EV driving.
    I rolled out of my downhill driveway without hitting the gas pedal, when I hit the street I gently pressed the gas- not exceeding 25% on the HSI display- and the ICE started and continued to run! I hadn't even hit 15mph yet. The first traffic light I hit is .6 mi from my house (on my 30mph posted street)- the ICE is still running- I'm indicating 46mpg for that .6 mile run so far. While at the light- the ICE is still running (remember no cabin heat or fan on) now the mpg drops to 42mpg by the time the light turns green. I hit the next traffic light- the ICE is still running, it keeps running till I get about the 3 miles from my house, then it finally shuts off. At that point it's indicating 48mpg for the three mile run and the EV range is down to 7.5 miles now. So in 3 actual miles it burned through 2 EV miles and ran on gas as well most of the time for a combined 48mpg total. That's with no heat, defroster, fan,, etc... on with an outside temperature of 40+ degrees with mostly back road driving.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Good point. :(
  12. Adam Leibovitch
    498
    102
    You can't take two average mpg and then average them based on miles traveled. You have to break down the trips into gallons used and miles traveled, then take an average of the total figures. Here is how you would calculate it for EC numbers.
    total trip = 42 miles @76mpg = 0.5526 gallons used
    trip out = 21 miles @120mpg = 0.175 gallons used
    Trip back = 21 miles / (0.5526-0.175) = 21 miles/ 0.3776 gallons used = 55.6 mpg
  13. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Sounds like some software is not written right for your driving style. I am not sure about the phv batteries when they are cold. Can you try the experiment again, but have heat on so the batteries warm up?
  14. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Part of the problem could be addressed by reading the last pages of the post "ICE in EV mode again". I found out that when you have a full charge and go downhill or do anything that recharges a full battery (I call it hyper-charging), that the ICE comes on. We theorize that this is to protect the Battery from overcharging. I have found that by acceleration on the downhill I actually can keep in EV. Of course of you have a to stop or break and hyper-charge the battery again it will trigger the ICE. This could be part of the problem but does not explain it all. Probably several things.
  15. lensovet
    2,615
    496
    Burlington, NJ
    Actually, I think we should let the OP answer these two posts first: #86 and #89 before continuing further discussion. otherwise we're never going to get to the bottom of the issue.
    retired4999 likes this.
  16. GaryJ
    GaryJ New Member
    26
    Maryland
    Absolutely getting the charge complete message. I checked this morning and the estimated EV range was 11 miles. Yesterday the mpg number at end of outbound commute was 48. That's on an 11 mile commute half on surface roads half on interstate. My wife drove the car so pretty sure she had the heat on but no other conditions of note (I don't have the guts to tell her to turn the heat off :)). Good idea about starting to charge as soon as we get home. That should help some. I'm also going to reset one of the EV ratio displays next time I get gas. I think the low ratio numbers on my display are skewed by the fact that I had to have an outside outlet installed for charging and so the first 2-3 weeks were all HV.
    iPad ? HD
  17. GaryJ
    GaryJ New Member
    26
    Maryland
    Damn, I hate it when I make a math error. I had a feeling there was something wrong with my method. Thanks!
    Gary
    iPad ? HD
  18. ny_rob
    1,968
    814
    L.I.- NY
    Don't need to have the heat on... this afternoon it was a pleasant 55+ deg outside, and the car was toasty warm inside- I had a full charge and the car was in the same position in my driveway (the spot I use to charge-up) as it was in the morning. This time as I left the driveway- the ICE never came on- drove 3+ miles to the pizza place, and the 3+ miles back home- the whole time the ICE never came on. Drive my mom to church and back later on at 5pm- it was 42 outside... but the car was still warm from the afternoon sun- again the ICE never started for the 5.4mi trip. I'm convinced it's the overnight cold soak at or below freezing temps that's causing the ICE to fire up a soon as I leave the driveway in the mornings, because when I make the same run in the afternoon the ICE never fires up.
  19. bisco
    52,883
    you could be right. it hasn't gotten cold enough here and my car is in an unheated garage.
  20. bisco
    52,883
    1) was she in ev or hv?
    2) is the ev all used up when she gets to the end of the eleven miles?
    3) are you resetting a trip meter to get the trip mpg or are you not resetting and just reading it or are you reading the screen that comes up after you turn the car off?
