Help - Mileage Sucks
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by GaryJ, Dec 12, 2012.
  1. GaryJ
    GaryJ New Member
    26
    Maryland
    OK - I think I see the source of the confusion. You are looking at the EV ratio display I posted, which is indeed for a 22 mile round trip. Only problem is that I don't know the mpg values for that trip. I posted that pic because the EV displays had never been reset and were showing low EV ratios because we had the car for 3-4 weeks before I was able to start charging it regularly. The 58mpg was what my wife told me the car got on this morning's commute (11 miles), with the ICE on most of the time. It was kind of cold here this morning and she did use the heater. Car was in EV mode all the way, and it isn't particularly hilly here. I'll get a better handle on usage/mpg etc. tonight. Everything else being equal the total mileage on the display tonight should be about 44 miles, but EV ratio unknown at this point.
    Gary
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    I wish I could get 11 EV miles at highway speeds.
    When I start up now it displays 9.4EV miles available...
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Have you reset either Trip A or Trip B? You can use one of those to see the MPG of all trips since the reset.
  4. lensovet
    2,615
    496
    Burlington, NJ
    No, this is absolutely wrong. The EV ratio works the same way as the calculated mpg on the trip meters, except that it uses its own "trip meters"
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yup, just went out to my car and verified it EV driving Ratio (1) and (2) set (2) to zero on mine just now:D
  6. bisco
    52,886
    yes, i reset ev1 every tank up.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    well.....u could have tol me it was possible:mad:
  8. bisco
    52,886
    if you don't reset them, don't they both read the same?
  9. lensovet
    2,615
    496
    Burlington, NJ
    Yep
  10. bisco
    52,886
    wouldn't that make you question the purpose?
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you think? I never noticed EV Driving Ratio 1 AND 2 till today:confused:
  12. bisco
    52,886
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Holy screen ratio! Batman!
  14. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    There is no one living in his area? If I were closer, I would go check it out myself.
  15. Photau
    Photau Junior Member
    46
    Mastic Beach Village
    My tire pressure off the lot was 28/26psi
  16. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's pretty bad. It's hard to believe the tires would be allowed to get so squishy. That's very close to what would trigger the warning light (25% below minimum), which indicates being within the danger zone.
  17. bisco
    52,886
    must have missed the t/p when they did the new car multipoint check and clean up. good thing they don't charge for dealer prep.:cool:
    lensovet likes this.
  18. lensovet
    2,615
    496
    Burlington, NJ
    Hey an old thread where the OP disappeared without following up on the suggestions listed here…what a surprise!
  19. bisco
    52,886
    8 pages of my life, wasted.:censored:
  20. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I haven't followed this thread at all, since I have no PiP, but I think you feel my pain and frustration from people who complain about poor FE (before the PiP), often giving scant/no details (e.g. "help, my mileage sucks, I'm getting 35 mpg"). I'd have to ask a whole bunch of questions and others might spend time doing the same as well or throwing out a lot of guesses. Sometimes the OP would never return to answer a single one... or there'd be a lot of wasted time going back/forth and the OP would drop off. :(
    That was the impetus for Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat.
