Help, My Car Came On By Itself!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, Jul 2, 2018.
  1. TwoPriusInTenn
    250
    66
    Tennessee
    2004, 296,000 miles
    My car has been doing 3 strange things lately. It has not been starting at all or has been restarting on it's own.
    1.)There are times when I put the key fob in, push the button and nothing happens. No display, nothing. It may take a few tries of reinserting the fob and it will eventually it gets with the program. 2.) There are times when the display does not light up. This generally involves unplugging the voltage sense lead on the 12 volt battery and waiting 30 seconds before plugging it back in. (I need to order another dash display).
    The most current problem is 3.) The car comes back on,on it's own without the key fob inserted. I walked out to the car earlier today and the radio was playing without the key fob inserted.
    Any ideas on why these are happening?
    Any ideas about how to remedy these?
    #1 TwoPriusInTenn, Jul 2, 2018
  2. JC91006
    16,877
    8,619
    sadly strange things occur when your 12v is bad. Check that and get it charged or replaced
    Aaron Vitolins likes this.
  3. TwoPriusInTenn
    250
    66
    Tennessee
    Thank you. 12 volt battery was just replaced 4 months ago. I checked the charging with my Techstream OBD. All appears fine.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    It sound like a sticky electrical contactor. Electrical contactors after my cycles get worn and pitted and don't make good contact or they don't release when they are suppose to. The ones I am talking about are in the HV battery. I'm no expert on Prius but have electrical background.
    Contactors at 2 minute mark.
    #4 padroo, Jul 3, 2018
  5. peecee
    peecee Member
    67
    39
    Annapolis, MD
    @TwoPriusInTenn Is there any difference when you don't insert the fob? I can't tell you the last time I put mine into the slot. Come to think of it, I don't know what purpose the slot serves. Does it resync the key or something?
  6. TwoPriusInTenn
    250
    66
    Tennessee
    It's 2nd gen. Key fob needs to be inserted to start, otherwise the key light flashes when start button is pressed.
  7. TwoPriusInTenn
    250
    66
    Tennessee
  8. bisco
    52,558
    only on non sks model, or if the switch is turned off or something is wrong. (low battery, fob programming)
    i'm amazed you made it to 300k!(y)
    SFO likes this.
  9. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I’m at 490k and I’ve never had it start on its own though with the display out I’ve had it not turn off and fool me. I had to start being really sure it was off, pressing the power button for three seconds and then sometime that only stopped the engine so I had to press the power button three times quickly to turn it all off.
    One thing I know is that it will not lock if it is not off! So that is my triple check.
    iPhone ?
    ITBland likes this.
  10. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    If this is a non-SKS basic Prius, the slot should not let the key go if the ignition is still on, unless it is forced, worn out, or he has the bad combo meter problem and when it is dark, it releases the key!
    Did you check with ignition on? Even a new battery can be/go bad. What is the voltage of the battery when the inverter is not trying to charge it? (after sitting overnight without getting a charge from the inverter.)
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Have you had to jump start the new 4 month old battery?
    I doubt the car is coming on by it’s own I bet what’s happening is the car has been on the whole time you just never realized it because the combo meter is dead.
    Before you walk away from what you think is the car off floor the gas pedal which Makes the ice come on. That way u can confirm the car us actually off.
    We don’t really care what the charging voltage is on the 12 volt battery we care what the sitting and load voltage is.
    Get a dvm. With CAR OFF Measure battery voltage at front jump points. Write that down.
    Then with CAR OFF turn on the headlights in high beam for 5 minutes and measure battery again.
    Report back here.
    My car with 2 year old yellow top measures 12.6 volts sitting and does not drop one volt in the 5 minute headlight high beam test.
    Raytheeagle and ITBland like this.
  12. TwoPriusInTenn
    250
    66
    Tennessee
    Thank you for your recommendation.
  13. TwoPriusInTenn
    250
    66
    Tennessee
    The culprit was a loose positive battery terminal. Problem solved. Working fine now.
  14. bisco
    52,558
    congrats, well done!(y)
  15. ITBland
    433
    278
    And many thanks for reporting the solution, it may help the next person!
    padroo likes this.
  16. edthefox5
    10,096
    4,836
    Clearwater, Florida
    And that’s why all charging and all 12 volt battery diagnostics should be done from the front jump points.
    A simple headlight load test would have found that in about 15 seconds.
    ITBland and padroo like this.
  17. padroo
    2,763
    2,253
    Another case of the 12 V. battery causing weird things in a Prius. Glad you figured it out.:)
    ITBland likes this.
  18. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    So, 12v batteries that are dying or have loose positive terminals cause weird symptoms, got it.
    BTW, it was the 12v after all, I was suspecting the female key hanger.
