Help! My driver's door won't open from outside!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jtlytle, Jan 9, 2012.
  1. jtlytle
    jtlytle Caution: Prius owner
    89
    Yesterday I noticed my door won't unlock and I had to use passenger's side to get in and push my door to open.
    I noticed the lock/unlock switch on the door stays locked, won't unlock at all.
    My car is 2004 Prius.
    Is it easy to fix by myself? I don't want to take it to the shop and spend thousand of dollars to get it to fix! I have tight budget.
    Hope any of you can help me out with it.
    Thanks,
    John
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Are you able to unlock the door from the inside, or is it stuck?
    Tom
  3. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    Sounds like the Door actuator motor is bad. I changed it myself on my 2007.
    Door Actuator - Auto Parts Warehouse
    http://toyota10.blogspot.com/2011/05/how-to-remove-toyota-prius-door-panel.html
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  5. jtlytle
    89
    Stuck! It won't unlock from inside.
  6. jtlytle
    89
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    This. I've had 2 fail. How I'm trading for a '17 c-4.
    Hope they have a better actuator now.
    When mine failed, they still "tried" to move for a while; sometimes won't lock, sometimes won't lock.....electrically.
    Edit: But neither of mine ever stuck mechanically. Once you get the inside door panel off, you might want to inspect the linkage first.
