HELP! My gas gauge is suddenly demon possessed!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FrankD, Sep 11, 2019.
  1. suirpe
    suirpe New Member
    france
    hello, i had the same issue on my 2006 prius, it is just the sending unit, it is located in the tank with the electric pump assembly.
    i have already fixed it myself, it is not easy, and maybe dangerous, because of the presence of gas vapors.
    do not inted to do it if you are not a mechanic with good tools and knowledge.
    you don't need to charge or change battery, or recalibrate anything, no level calibration. it just work after changing it.
    you will find explanations and pics here, at prius touring club it is a french website, teeling about prius and more (use a translator if needed).
    prius-touring-club vbf/showthread.php?t=6345
  2. suirpe
    suirpe New Member
    france
    i have just discovered that fuel tanks maybe different from the european models, i found it on this thread (prius chat) :
    the gas bladder: exposed!
    i am very surprised that you need to change the hole tank if the fuel pump or the sending unit (gauge) doesn't work !
    the sending unit costs only 80.
  3. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    So..an update....I changed the 12 volt battery, because they did send me a new one at no charge. Had the 33 month one tested and they said it was still good. I am still driving around with no issues...now at about 1/2 a tank...that is when it would start to go wonky...we will see.
    Thanks, Frank
    Skibob likes this.
