HELP! My Prius shrunk!!!!
Discussion in 'Honda/Acura Hybrids and EVs' started by TheForce, Jul 25, 2010.
  1. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    It just takes practice. Find a big empty parking lot and get used to finding the friction point. After that it's all coordination. :)
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Yeah, what Hyo said. Go practice out of the way of other people.
    I learned to drive a stick at 14. If a 14-yr old girl can do it, so can you! :thumb:
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well I think I have pretty much got everything down right now. I have not stalled the car for at least a week but I've come close a few times. I think I finally figured out how to shift through all the gears without making the car jerk too much. On my last commute to work I was able to pull 77MPG out of it. Once I learn to fully drive stick I will learn to exploit the car. If I can pull 77MPG now I'm sure I can reach 90MPG or even 100MPG especially since on my way to work I was able to get 83MPG.
  4. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    i miss my stick shift New Beetle. i picked the color my wife picked the transmision, never drove stick until I was married.
  5. Trollbait
    12,757
    You can also do this by letting up on the clutch, while parked, until you can feel it just starting to engage. With experience, you can also try rev matching the tranny and engine on shifts. Don't know how much it helps with efficiency, but it reduces clutch wear.
    It may not be inline with what you want out of the car, but someone has put a turbo on an Insight. The donor parts came from one of those Chevy/Geo/Suzuki cars, the Sprint I think.
    On another note, something I was wondering about. The Insight uses liquid cooling for the batteries, correct? If so, could the pack be replaced with a gen2 Prius pack, and remove the liquid system?
  6. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Isn't that a bit backwards? The wife always picks the color.
    I learned to drive a stick on a farm tractor (maybe 12), but I haven't had a car with a stick since '99 when my wife became part of the car purchase decision-making (altho she almost never drove the car, so now I'd do it differently, but the Prius doesn't come with a stick shift version).
    The battery pack is a different size and used differently. I think the computer would get confused at best, and it may not even communicate with the battery pack at worst.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    Very cool. At first i wanted to yell at u for not getting a Leaf, but after all is said and done, u will probably have less than$ 15k into it (half the price of the Leaf) and u wont have to wait over a year to do it
  8. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Jay,
    While you still have some days warmer than 60F, take a weekend drive to see what lean burn can do.
    Find an uncongested road you can cruise at 45-50 without lots of stops or hills. After the catalytic converter is warmed up, 100mpg and better should be easy once you learn to use a light foot on the Insight...that is probably second nature on your Prius so it should be no problem.
    Just want you to see a 100 mpg segment before the cold weather kicks in
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    No liquid cooling. I think I remember reading about someone using Prius batteries in the Insight.
    I've been thinking about it and I dont know if I want to get a Leaf. As of right now I think I would get a cheap MT Insight and convert it using the HPGC AC50 motor and Curtis 144v 650A controller that Curtis has on the drawing board for next year. With that setup and 180Ah or 200Ah CALB cells the Insight would be a really peppy little EV.
    Also I have just about gotten used to shifting through all the gears without making the car jerk. I'm getting about 77MPG round trip on my commute to work.. I have not tried any advanced Hypermiling with the car yet and I wont until I'm more comfortable with shifting.
    I'm currently about half way through this tank and its sitting at 69.7 and slowly climbing.
    I need to try to clean the EGR plate to see if I can fix a jerking issue I have with the car and I also think I need to get some shocks.
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I've all ready seen lean burn I think. I've seen 100+ with a light foot on level roads.
    100+MPG segment I can do but a 100+MPG commute to work aint going to happen this year.
  11. Chuck.
    2,766
    1,510
    I'm glad you have visited the lean burn zone.
    A 100+mpg work commute is possible if it's mostly highway....if you have many stops, then FASing will give you a good chance to do it anyway....cutting the ignition 2-3 seconds and coasting at least 0.10 a mile. I usually bump start by shifting in 5th....going under 15 is too slow to bump start....going 50 or faster I change the bump start by letting the clutch halfway, then do it a second time so the engine and clutch is not stressed as much.
  12. Trollbait
    12,757
    Ok. With the chemistry and cell size being the same, I figured the the voltage and amperage wouldn't be off enough to cause problems with the Insight ECU. Having entertained getting a manual Insight myself, I figured using cells from a salvaged Prius pack would be more economical than going through Honda. Of course, that would depend on me gaining the knowledge, or knowing somebody with it, on how go about doing so.
