Help! My son keeps having the warning "!" light c
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Greenie, Jul 30, 2005.
  1. Greenie
    Greenie New Member
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Details please.
  3. Greenie
    Greenie New Member
    I'm new at this; just looking for some advice. Toyota dealership had this past week told us that THEY had been told by the manufacturer that an owner should just turn off the car for 5 or 10 mins and then re-start it when the warning light comes on if there;s no indication of why. My son is far from home and travelling back and didn't know whether he would wreck our Prius by driving it with the warning light on. Any ideas? Does this happen to others?? We have a new Prius as well but it only happened when I ran out of gas.....
  4. IsrAmeriPrius
    4,333
    Southern California
    Can you expand on the circumstances under which he is experiencing the warning lights. How long has the car been on, is it in city driving, highway driving, stop and go traffic? What other warning lights go on? What is the message on the MFD?
    It is true that the trouble warning lights will be reset when the car is turned on and off a few times, but that does not explain the cause of the warning signal.
    Has he taken the car to the dealer? Did they look up the trouble codes which are stored in the car's computers?
    There have been numerous discussions of such incidents, but it is hard to steer you toward possible solutions without knowing the particulars.
  5. Gen2
    Gen2 Member
    319
    This happened to me. After reading a few posts here I finally figued out that the gas cap was not tight enough. I had to turn it until it clicked many times. After that i had to use the car three times so it would automically reset the alert. No more warnings in almost a year. Hope this helps.
  6. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    If the cap IS the problem, my Honda Odyssey has the similar fuel cap, its manual says to tighten the cap till you hear at least three clicks. I do the same with my Prius.
  7. Greenie
    Greenie New Member
    Thank you three so much. All I know is that my son drove 4.5 hours all at once and the warning signal came on when he finally arrived. I think most of his driving was highway, pretty much. Then he left the car alone and I called the dealer. All they could say was turn it off and wait and try again. He did this and it was okay until halfway back (another 4.5 hr return trip) the warning light just popped on again. It IS possible it has to do with the gas cap since I think he filled it up, but I will also maybe take it in if that doesn't solve things.
    It was very kind of youall to share your knowledge with me. I couldn't reach the dealer on the weekend and we were nervous.
    Looking at all the postings re: diff. problems people have had with their Priuses makes me a little apprehensive. We're all glad we got ours, right?
  8. Gen2
    Gen2 Member
    319
    I am very glad I got mine. Anuthing with technology has problems and considering the extrodinary technology that the Prius represents, I think that Toyota did a good job with it. I sleep fine at night.
  9. galaxee
    galaxee mostly benevolent
    9,810
    459
    MD
    there are tons of simple reasons that light can come on. is this a second gen prius or the classic? you really can't say until you get the codes read. has he looked at the display when the light comes on? sometimes it will tell you what needs to be done. sometimes.
    and i think people are more likely to post a problem here for discussion than a good experience, although we do see posts of both... so I think you have a higher population of "problem" discussions here simply because people come here (like your post here) looking for an answer. in a number of (but not all) cases the solution may be a simple thing found in the owner's manual...
    we absolutely love ours, and have had no trouble whatsoever.
    it is a newer technology, so people are kind of afraid of any lights, etc that may come up that may indicate a problem. i say don't worry. just drive the car and enjoy :)
  10. DaveG
    DaveG Member
    806
    Vancouver, BC
    Is it a brand new car?
    If so, this may be the issue with the sealant used in the exhaust system "burning off" after the first few hundred miles of driving. If it's the same issue, it will stop after a few hundred miles.
    If it's not a new car and the light is coming on, take it to a dealership and get them to pull the code on it to tell you exactly what the problem is.
    Dave
  11. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    Re: Help! My son keeps having the warning "!" lig
    Recently I was baffled by the appearance of the warning light that looks like a key with an exclamation point. Eventually by coincidence I picked up my cell phone which was in the center console, and the light went out. I returned it to the console but in a different spot, and it stayed out. Weird.
    The instructions for the Smartkey system do say that you shouldn't keep it next to a cell phone. I wonder if anyone else has had problems with this. I try to have the phone in one pocket and the Smartkey in the other....
  12. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The exhaust burn illuminates the Check Engine light (CEL) , not the triangle of doom. I am assuming the lit indicator is the red triangle, right?
    There is another indicator with a picture of a car and the ! in the middle of it. That indicates the key is missing. Very common with SKS. The car will continue to run if you walk off with the fob, and you'll get three beeps outside the car when you close any door to warn you that you left the car running with the key not being in the car.
    This indicator would be pretty unusual without SKS, as you can't remove the fob from the slot with it running. Cellphones can interfere with the fob's transmission if too close, so that could also trigger the missing key symbol.
    If the gas cap is tight when a malfunction indicator light comes on (MIL) then see your dealer and have them pull the diagnostic trouble codes (DTC).
  13. lisaj59
    lisaj59 New Member
    Glendale, CA
    Thank you for clearing up the "key with the exclamation point" light!
    I too was baffled when I saw that.
    I love this site!!! :p
    Lisa
Loading...
