Help needed no drive
Discussion in 'Gen 2 Prius Technical Discussion' started by Ryanpalmer22, Dec 18, 2018.
  1. Ryanpalmer22
    Ryanpalmer22 New Member
    Watford
    ----UK----
    Can anyone help my Prius broke down this evening on my way home from work I pulled out of a junction and then heard a bang and lost all drive managed to get over to the side of the road every time I put it in drive or reverse I get the traction control light on and you hear like something is spinning hope it’s nothing to serious any ideas ?
    52,804
    sounds like you threw a rod
  3. fuzzy1
    10,690
    Does the dashboard show any error messages or symbols?
    Is the Check Engine light on, to indicate some diagnostic codes to be read?
  4. Ryanpalmer22
    Watford
    ----UK----
    No engine codes or warning lights just traction control light flashes if u push the accelerator pedal
  5. bisco
    52,804
    broken axle?
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    CVT belt? Whatever it is you are going to need a place to fix it. Like possibly changing out the transmission kind of place.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    You never opened the hood?
    Loud bang and no codes means it’s strictly mechanical. Maybe the chain in the trans snapped.
    That makes a rizzing sound when you push the gas pedal. Or diff section failed.
    Pretty rare. Less rare is piston rod through the side of the block because the engine was run dry of oil.
    Whatever it is it’s fatal and serious. How many miles.
    #7 edthefox5, Dec 19, 2018
    SFO likes this.
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
    No belt in trans just chain.
  9. Ryanpalmer22
    Watford
    ----UK----
    Yeh I’m always checking under the hood checking fluids and oil and all been okay only 80,000 on the clock
    edthefox5 and SFO like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Sounds like something broke loose between the engine and the front wheels. I didn't see any mention yet of CV joints. They usually give warning noises before failing completely though. But that would fit the symptoms you described.
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    In Hondas I would say broken axle.
    But it's hard to guess remotely what the bang sounded like. So it makes it hard to diagnose remotely.
  12. Ryanpalmer22
    Watford
    ----UK----
    Well update from Toyota it is indeed the drive shaft has gone but who ever has changed it before fitted an aftermarket one which is why it has lasted So it’s a big bill :-(
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Hopefully its not an inner shaft they tend to really beat up the differential gear when they fail catastrophically. Find out if its an inner or outer. If an inner I would get the inner shaft /diff seals replaced also. A leak there and you never know will kill your trans.
    jerrymildred likes this.
  14. Ryanpalmer22
    Watford
    ----UK----
    Well it’s gunna cost £1000 so guessing it’s the inner
  15. bisco
    52,804
    bummer! is it a salvage vehicle? 80k is low for axle already replaced
  16. Ryanpalmer22
    Watford
    ----UK----
    Nope 1 owner full Toyota service history and full mot
  17. bisco
    52,804
    still, you don't drop a new axle in a prius at 80k for no reason, fun mot or not
